I just updated to v7.95 this evening. I did not change any settings, I just installed the installer as usual. After completion, I ran the executable (as usual) and GameEx errored out. I rebooted and started GameEx again and let it go to demo mode. It seemed to be working fine, but then when I alt-tabbed out to put it in the background (which I have been able to do without problems from day 1), it crashed. Any thoughts?
log.txt:
20:36:20.2 3/23/2007: GameEx: Version 7.95: Starting Log
20:36:20.2 3/23/2007: Operating System Platform: Win32NT
20:36:20.2 3/23/2007: Operating System Name: Windows XP
20:36:20.2 3/23/2007: Operating System Version: 5.1.2600
20:36:20.3 3/23/2007: Checking for versions of .net Framework installed
20:36:20.3 3/23/2007: .net Framework 1.1 Installed
20:36:20.3 3/23/2007: .net Framework 2.0 Installed
20:36:20.3 3/23/2007: AMD Athlon XP 3000+
20:36:20.3 3/23/2007: 2.16Ghz
20:36:20.3 3/23/2007: Running Randomize()
20:36:20.3 3/23/2007: Loading PlugIns
20:36:20.4 3/23/2007: Checking for applications to Launch On Startup
20:36:20.4 3/23/2007: Launching and not waiting: c:\emu\winlirc\PowerOn.bat
20:36:20.4 3/23/2007: Initialising Video/MNG DLL's
20:36:20.6 3/23/2007: Running Misc startup tasks
20:36:20.6 3/23/2007: Setting Menu types
20:36:20.6 3/23/2007: Opening Configuration File
20:36:20.6 3/23/2007: Getting Configuration Values
20:36:20.6 3/23/2007: Using Theme: TalkingBull Arcade Theme V1.0
20:36:20.6 3/23/2007: Checking for alternate Image Directory for Theme: TalkingBull Arcade Theme V1.0
20:36:20.7 3/23/2007: Launching HideOS.exe
20:36:20.7 3/23/2007: Hiding Taskbar
20:36:20.7 3/23/2007: Is Media Center running?
20:36:20.7 3/23/2007: Checking/Creating LCD Registry values
20:36:20.7 3/23/2007: Check Media Center Exit/Start Mode
20:36:20.7 3/23/2007: Media Center Mode 0
20:36:20.7 3/23/2007: Video previews on. Warning: Only recommended on modern systems
20:36:20.7 3/23/2007: Custom Game Device Input enabled: Getting custom codes
20:36:20.7 3/23/2007: Snap Delay set to: 3
20:36:20.7 3/23/2007: Get other settings
20:36:20.7 3/23/2007: Desktop set to Hide ICONS and set Background to Black
20:36:20.7 3/23/2007: Backing up Registry Wallpaper Settings
20:36:20.7 3/23/2007: Start work for Form
20:36:20.7 3/23/2007: Getting Original Screen Size
20:36:20.8 3/23/2007: Initializing Component
20:36:21.0 3/23/2007: MAME Path is: C:\Emu\MAME
20:36:21.0 3/23/2007: Model 2 Path Path is: C:\Emu\Model2
20:36:21.0 3/23/2007: Model 2 EXE file is: emulator.exe
20:36:21.1 3/23/2007: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
20:36:21.1 3/23/2007: ZiNc Path is: C:\Emu\ZiNc
20:36:21.1 3/23/2007: ZiNc EXE file is: ZiNc.exe
20:36:21.1 3/23/2007: Use ZiNc on. ZiNc.exe will launch PSX games
20:36:21.1 3/23/2007: MAME EXE file is: mame.exe
20:36:21.1 3/23/2007: ROM Path is: C:\Emu\MAME\roms
20:36:21.1 3/23/2007: Catver.ini is located at: C:\Emu\MAME\DAT\Catver.ini
20:36:21.1 3/23/2007: controls.ini is located at: c:\Emu\MAME\DAT\controls.ini
20:36:21.1 3/23/2007: History.dat is located at: C:\Emu\MAME\DAT\History.dat
20:36:21.1 3/23/2007: nplayers.ini is located at: c:\Emu\MAME\DAT\nPlayers.ini
20:36:21.1 3/23/2007: MAMEinfo.dat is located at: C:\Emu\MAME\DAT\mameinfo.dat
20:36:21.2 3/23/2007: Loading Controls.ini map file
20:36:21.2 3/23/2007: Snap Path is: C:\Emu\MAME\snap
20:36:21.2 3/23/2007: AVI Snap Path is: C:\Emu\Mame\MAMEMNG\ingame
20:36:21.2 3/23/2007: Flyer Path is: C:\Emu\MAME\flyers
20:36:21.2 3/23/2007: Cabinet Path is: C:\Emu\MAME\cabinets
20:36:21.2 3/23/2007: Title Path is: C:\Emu\MAME\titles
20:36:21.2 3/23/2007: Panel Path is: C:\Emu\MAME\cpanel
20:36:21.2 3/23/2007: Manual Path: Not Found
20:36:21.2 3/23/2007: Icon Path is: C:\Emu\MAME\icons
20:36:21.2 3/23/2007: Marquee Path is: C:\Emu\MAME\marquees
20:36:21.2 3/23/2007: Loading Custom Emulators
20:36:21.2 3/23/2007: Loading Emulator 5: Nintendo NES (NEStopia)
20:36:21.2 3/23/2007: Loading Emulator 6: Nintendo SNES (ZSNES)
20:36:21.4 3/23/2007: Using 2D Animations
20:36:21.4 3/23/2007: Using General Font: Trebuchet MS
20:36:21.4 3/23/2007: Using Title Font: Trebuchet MS
20:36:21.4 3/23/2007: Initialising DirectDraw
20:36:21.5 3/23/2007: Creating DirectDraw Device
20:36:21.5 3/23/2007: Using Device: Radeon X1300 Series (Omega 3.8.252)
20:36:21.5 3/23/2007: 307mb video memory available
20:36:21.6 3/23/2007: Setting Resolution to 1024x768 32 bit color
20:36:21.6 3/23/2007: Creating DirectDraw Surfaces
20:36:21.6 3/23/2007: Creating Primary Surface - Full Screen Mode
20:36:21.6 3/23/2007: Creating Back Buffer
20:36:21.7 3/23/2007: Version 2 Theme being used. Loading.
20:36:21.7 3/23/2007: Loading Button Data
20:36:21.7 3/23/2007: Loading Font Data
20:36:21.7 3/23/2007: Loading Layout Data
20:36:21.7 3/23/2007: Loading Taskbar Data
20:36:21.7 3/23/2007: Loading graphic Surfaces
20:36:21.8 3/23/2007: Creating Surfaces Misc and Dialogs
20:36:22.0 3/23/2007: Creating Surfaces Volume
20:36:22.0 3/23/2007: Creating Surfaces Arrows
20:36:22.0 3/23/2007: Creating Surfaces GameEXlogo Text
20:36:22.0 3/23/2007: Creating Surfaces Toolbar
20:36:22.1 3/23/2007: Creating Surfaces Backgrounds
20:36:28.6 3/23/2007: Creating Surfaces Toolbar Controls
20:36:28.6 3/23/2007: Creating Surfaces GameEx Logo
20:36:28.7 3/23/2007: Creating Surfaces Home & Exit
20:36:28.7 3/23/2007: Creating Surfaces Snaps
20:36:28.7 3/23/2007: Creating Surfaces Menu and List Bars
20:36:29.1 3/23/2007: Creating Fonts
20:36:29.1 3/23/2007: Creating Menu Font
20:36:29.1 3/23/2007: Restoring Menu Font From Cache
20:36:29.5 3/23/2007: Creating Game Font
20:36:30.0 3/23/2007: Creating Font Black
20:36:30.1 3/23/2007: Creating Font Black Small
20:36:30.2 3/23/2007: Creating Game Font Faded
20:36:30.9 3/23/2007: Creating Title Font
20:36:31.0 3/23/2007: Restoring Title Font From Cache
20:36:34.3 3/23/2007: Fonts Created Succesfully
20:36:34.3 3/23/2007: 254mb video memory left available
20:36:57.9 3/23/2007: Text/Language: English
20:36:57.9 3/23/2007: Applying Language/Text
20:36:58.0 3/23/2007: Initialising Bass Audio Library
20:36:58.2 3/23/2007: MAME CMD options:
20:36:58.2 3/23/2007: Attempting to load game list
20:36:58.6 3/23/2007: Running: mame.exe -help
20:36:58.6 3/23/2007: Running: C: C:\Emu\MAME\mame.exe -help > C:\Emu\MAME\help.txt
20:36:58.8 3/23/2007:
20:36:58.8 3/23/2007: Detected MAME Version as: 0.113
20:36:58.8 3/23/2007: Now Outputing mame.exe - Help
20:36:58.8 3/23/2007: --BEGIN--
20:36:58.8 3/23/2007: M.A.M.E. v0.113 (Mar 5 2007) - Multiple Arcade Machine Emulator
20:36:58.8 3/23/2007: Copyright © 1997-2007 by Nicola Salmoria and the MAME Team
20:36:58.8 3/23/2007: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
20:36:58.8 3/23/2007: several arcade machines. But hardware is useless without software, so an image
20:36:58.8 3/23/2007: of the ROMs which run on that hardware is required. Such ROMs, like any other
20:36:58.8 3/23/2007: commercial software, are copyrighted material and it is therefore illegal to
20:36:58.8 3/23/2007: use them if you don't own the original arcade machine. Needless to say, ROMs
20:36:58.8 3/23/2007: are not distributed together with MAME. Distribution of MAME together with ROM
20:36:58.8 3/23/2007: images is a violation of copyright law and should be promptly reported to the
20:36:58.8 3/23/2007: authors so that appropriate legal action can be taken.
20:36:58.8 3/23/2007: Usage: MAME gamename [options]
20:36:58.8 3/23/2007: MAME -showusage for a brief list of options
20:36:58.8 3/23/2007: MAME -showconfig for a list of configuration options
20:36:58.8 3/23/2007: MAME -createconfig to create a mame.ini
20:36:58.8 3/23/2007: For usage instructions, please consult the file windows.txt
20:36:58.8 3/23/2007: --END--
20:36:58.8 3/23/2007: Loading last used Game List
20:36:58.8 3/23/2007: Loading Start Page
20:36:59.0 3/23/2007: Setting Music Volume
20:36:59.0 3/23/2007: Creating DirectSound Device
20:36:59.0 3/23/2007: Trying: Primary Sound Driver
20:36:59.0 3/23/2007: Loading Sound Files
20:36:59.4 3/23/2007: DirectSound Device Created Successfully
20:36:59.4 3/23/2007: Creating ICONS
20:36:59.4 3/23/2007: Recreating ICONS
20:36:59.9 3/23/2007: Initialising DirectInput for Gamepad support
20:36:59.9 3/23/2007: Looking for Device: GP-Wiz
20:36:59.9 3/23/2007: Device Created
20:37:00.0 3/23/2007: Playing intro sound file
20:37:00.0 3/23/2007: Initializing MCE Remote
20:37:00.0 3/23/2007: Initialization OK! Starting GameEx!
20:37:00.0 3/23/2007: Testing Main Loop Once: Processing Frame
20:37:00.6 3/23/2007: Testing Main Loop Once: Main Loop ran successfully
20:40:00.0 3/23/2007: Starting Attract Mode
20:40:00.4 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe capbowl -rompath C:\Emu\MAME\roms
20:43:03.8 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe bongo -rompath C:\Emu\MAME\roms
20:46:07.6 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe gondo -rompath C:\Emu\MAME\roms
20:49:11.3 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe cosmogng -rompath C:\Emu\MAME\roms
20:52:15.3 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe jjack -rompath C:\Emu\MAME\roms
20:55:19.0 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe imsorry -rompath C:\Emu\MAME\roms
20:58:22.6 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe megatack -rompath C:\Emu\MAME\roms
21:01:26.5 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe cracksht -rompath C:\Emu\MAME\roms
21:04:30.7 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe ms5pcb -rompath C:\Emu\MAME\roms
21:07:34.6 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe bladestl -rompath C:\Emu\MAME\roms
21:10:38.3 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe pang -rompath C:\Emu\MAME\roms
21:13:42.1 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe marvins -rompath C:\Emu\MAME\roms
21:16:45.9 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe boxyboy -rompath C:\Emu\MAME\roms
21:19:49.6 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe trckydoc -rompath C:\Emu\MAME\roms
21:22:53.5 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe cobracom -rompath C:\Emu\MAME\roms
21:25:57.5 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe lrescue -rompath C:\Emu\MAME\roms
21:29:01.2 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe loffire -rompath C:\Emu\MAME\roms
21:32:04.9 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe megazone -rompath C:\Emu\MAME\roms
21:35:08.7 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe ar_sprg -rompath C:\Emu\MAME\roms
21:38:12.7 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe silkroad -rompath C:\Emu\MAME\roms
21:41:16.7 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe 3stooges -rompath C:\Emu\MAME\roms
21:44:20.7 3/23/2007: Running: cmd.exe /c C: C:\Emu\MAME\mame.exe kikikai -rompath C:\Emu\MAME\roms
21:45:36.8 3/23/2007: MAME process ended: Exiting attract mode
21:45:40.2 3/23/2007: 307mb video memory available
21:45:58.7 3/23/2007: GameEx has detected a problem or change in your display such as running under remote desktop
21:45:58.7 3/23/2007: GameEx will now reinitialize the display
21:45:58.7 3/23/2007: 307mb video memory available
21:46:03.5 3/23/2007: 307mb video memory available
21:46:20.5 3/23/2007: 21 Consecutive Exceptions Occured: Exiting
21:46:20.5 3/23/2007: First Exception:
21:46:20.5 3/23/2007: Error in the application.
21:46:20.9 3/23/2007: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
21:46:20.9 3/23/2007: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
21:46:20.9 3/23/2007: at GameEx.GameEx.mainform.DrawBackground()
21:46:20.9 3/23/2007: at GameEx.GameEx.mainform.DisplayFrame()
21:46:20.9 3/23/2007: Last Exception:
21:46:20.9 3/23/2007: Error in the application.
21:46:26.0 3/23/2007: Exiting GameEx!
21:46:26.0 3/23/2007: Saving Settings
21:46:27.3 3/23/2007: Disposing Plugins
21:46:27.3 3/23/2007: Checking for applications to Launch On Exit
21:46:27.3 3/23/2007: Launching and waiting: c:\emu\winlirc\PowerOff.bat
That looks odd. Does it do this consistently? Ie was it just a one off?
It did it the first time I started it up. I reset the computer (actually, that's what "PowerOff.bat" does), then relaunched GameEx without any other utilities loaded (JoyToKey was loading) to verify that it wasn't conflicting. It loaded up just fine, so I went to dinner and when I came back it was still playing. So, I alt-tabbed out to relaunch JoyToKey, but it immediately caused this error on alt-tabbing.
I haven't had this problem before, so yeah, it's something new. Thanks for looking into it!
Okay, I'll give it a try. Thanks!
Edit: I ran GameEx for several hours in demo mode and no crash! I also played a few games through Zinc, Model2 and MAME without error. I was also able to alt-tab out and return. Thanks for the quick fix!
