I just started using game ex and I gotta say its great. But I am having problems getting Rocknes to work through it. I have been messing with it for 2 nights now and would appreciate some help or advice.
An error screen pops up titled Rocknes saying sorry the file "game" was found.
I checked in the configuration and the rom path is correct.
Thanks in advance. I really enjoy all the features and would love to have it fully operational.
ShoPow
Post your config. The best way to do this is to open C:\program files\gameex\config\gameex.ini and find the relevant section. Then cut and paste here.
If you enable debug mode you can see what command line GameEx is about to use to launch RockNes. The best thing to do is figure out how to launch RockNes yourself from a cmd prompt and then get GameEx to conform to what you know works.
Since RockNes is giving you an error, it sounds like you either need to add [ROMPath]\ to the file, or perhaps you need to add quotation marks. It'll be easier for us to spot what's wrong if we see your confg.
Ok I decided to reisntall all my emulators cause I had stuff everywhere. I like my files kinda organized. I believe my settings were exactly the same as before and now it works. But I have another question. When I exit the game by pressing esc is there a way to go directly back into Game EX, instead of going to the Rocknes screen that I have to exit again?
Enable keyboard mapping in the config. That causes GamEx to monitor and override the behavior of ESC and the media center back button. On the negative side this means you may have trouble using the menu in the emulator if you need to for some reason.
-- Rob
