Hello all,
is any1 running the latest game ex and getting a bunch of .xml errors? I can't run anything past 7.73. anything past that I get all kinds of erros at startup and my buttons don't light anymore. Any way to fix that?
Hello all,
Im assuming this is to do with the LedWiz plugin and not GameEx as such? The latest release includes the latest LedWiz plugin. Can you post any screenshots or anything, so maybe HK can help, or me if its not related to the plugin?
Ok,
Here's what I did Tom I uninstalled and reinstalled (I even wiped the folder) Game Ex will start without errors now. The problems occur when trying to configure the led-wiz plugin. Here are some screenshots of the fatal errors. Hope I helped :) Also is there anyway to change the default colors of the buttons from white. I guess Mame is the only emulator with color change support. Thanx
I'm going back to version 7.73 until I hear from you on the subject ;) Take Care. Thanx for this great frontend. On the flipside it's your fault I have made Randy wealthy. :) The Led-Wiz plugin is very easy to configure and use so I have outfitted all my cabs with electric ice buttons. I even have a single controller project in the works. :)
No worries. Hopefully headkaze can help or provide an older version of the plugin so you can use the latest GameEx.
This problem is the LCDPlugin NOT GameEx. Can you please zip up your Mame config files (<Mame Folder>\cfg\*.cfg) and attach them to a post here. This is a bug I need to fix.
Ok here are the Mame .cfg filez zipped. I went back to version 7.73 now screen saver won't run either :blink: Is Mame the only emu with lighted button support?
cfg.zip
