Just started using GameEx recently and haven't been able to get it to work on my computer. It will start up fine, but as soon as i use the arrows keys to choose a selection GameEx exists to the Log Screen. I have tried different resolutions 800x600, 640x480 - different color depths 32, 16 - tried all of the default themes. Pretty much everything i could find in the forum i tried and still no luck. Any help would be greatly appropriated, I think this is an awesome program - i just can't get it to work on my box.
Here are some specs:
Win98 SE
EPIA-M MiniITX Motherboard
256 Mb RAM
2 Gb CF HD
Here is the Log output:
19:15:21.7 3/18/07: GameEx: Version 7.83: Starting Log
19:15:21.7 3/18/07: Operating System Platform: Win32Windows
19:15:21.7 3/18/07: Operating System Name: Windows 98
19:15:21.7 3/18/07: Operating System Version: 4.10.67766446
19:15:21.8 3/18/07: Checking for versions of .net Framework installed
19:15:21.8 3/18/07: .net Framework 2.0 Installed
19:15:21.8 3/18/07: x86 Family 6 Model 9 Stepping 8
19:15:21.9 3/18/07: Running Randomize()
19:15:21.9 3/18/07: Loading PlugIns
19:15:22.0 3/18/07: Checking for applications to Launch On Startup
19:15:22.0 3/18/07: Initialising Video/MNG DLL's
19:15:22.0 3/18/07: Running Misc startup tasks
19:15:22.0 3/18/07: Setting Menu types
19:15:22.0 3/18/07: Opening Configuration File
19:15:22.0 3/18/07: Getting Configuration Values
19:15:22.0 3/18/07: Using Theme: Default - Default
19:15:22.0 3/18/07: Checking for alternate Image Directory for Theme: Default - Default
19:15:22.1 3/18/07: Launching HideOS.exe
19:15:22.1 3/18/07: Hiding Taskbar
19:15:22.1 3/18/07: Using Cabinet Friendly Control System
19:15:22.1 3/18/07: Is Media Center running?
19:15:22.1 3/18/07: Checking/Creating LCD Registry values
19:15:22.1 3/18/07: Check Media Center Exit/Start Mode
19:15:22.1 3/18/07: Media Center Mode 0
19:15:22.3 3/18/07: Snap Delay set to: 2
19:15:22.3 3/18/07: Get other settings
19:15:22.3 3/18/07: Mouse Input is disabled
19:15:22.5 3/18/07: Desktop set to Hide ICONS and set Background to Black
19:15:22.5 3/18/07: Backing up Registry Wallpaper Settings
19:15:22.5 3/18/07: Set: Find emulator artwork on best match basis
19:15:22.7 3/18/07: Start work for Form
19:15:22.7 3/18/07: Getting Original Screen Size
19:15:22.7 3/18/07: Initializing Component
19:15:24.2 3/18/07: Loading Controls.ini map file
19:15:24.5 3/18/07: Loading Custom Emulators
19:15:24.5 3/18/07: Loading Emulator 1: Nintendo NES Games
19:15:24.8 3/18/07: Loading Emulator 2: Nintendo SNES games
19:15:25.5 3/18/07: Using 2D Animations
19:15:25.5 3/18/07: Using General Font: Trebuchet MS
19:15:25.5 3/18/07: Using Title Font: Trebuchet MS
19:15:25.6 3/18/07: Initialising DirectDraw
19:15:25.8 3/18/07: Creating DirectDraw Device
19:15:25.8 3/18/07: Using Device: VIA/S3G UniChrome IGP
19:15:26.0 3/18/07: Setting Resolution to 640x480 16 bit color
19:15:26.2 3/18/07: Creating DirectDraw Surfaces
19:15:26.2 3/18/07: Creating Primary Surface - Full Screen Mode
19:15:26.2 3/18/07: Creating Back Buffer
19:15:26.3 3/18/07: Loading graphic Surfaces
19:15:26.5 3/18/07: Creating Surfaces Misc and Dialogs
19:15:27.0 3/18/07: Creating Surfaces Volume
19:15:27.0 3/18/07: Creating Surfaces Arrows
19:15:27.0 3/18/07: Creating Surfaces GameEXlogo Text
19:15:27.0 3/18/07: Creating Surfaces Toolbar
19:15:27.1 3/18/07: Creating Surfaces Backgrounds
19:15:27.8 3/18/07: Creating Surfaces Toolbar Controls
19:15:27.8 3/18/07: Creating Surfaces GameEx Logo
19:15:28.0 3/18/07: Creating Surfaces Home & Exit
19:15:28.0 3/18/07: Creating Surfaces Snaps
19:15:28.0 3/18/07: Creating Surfaces Menu and List Bars
19:15:28.3 3/18/07: Creating Fonts
19:15:28.3 3/18/07: Creating Menu Font
19:15:28.7 3/18/07: Creating Game Font
19:15:29.0 3/18/07: Creating Font Black
19:15:29.3 3/18/07: Creating Font Black Small
19:15:29.7 3/18/07: Creating Game Font Faded
19:15:30.0 3/18/07: Creating Title Font
19:15:32.0 3/18/07: Fonts Created Succesfully
19:15:59.4 3/18/07: Text/Language: English
19:15:59.4 3/18/07: Applying Language/Text
19:15:59.5 3/18/07: Initialising Bass Audio Library
19:15:59.6 3/18/07: MAME CMD options: -triplebuffer -nowindow -joy
19:15:59.6 3/18/07: Attempting to load game list
19:15:59.9 3/18/07: Loading last used Game List
19:15:59.9 3/18/07: Loading Start Page
19:16:00.2 3/18/07: Setting Music Volume
19:16:00.2 3/18/07: Creating DirectSound Device
19:16:00.2 3/18/07: Trying: Primary Sound Driver
19:16:00.2 3/18/07: Loading Sound Files
19:16:00.4 3/18/07: DirectSound Device Created Successfully
19:16:00.4 3/18/07: Initialising DirectInput for Gamepad support
19:16:00.4 3/18/07: Unable to create a joystick device
19:16:00.5 3/18/07: Initializing MCE Remote
19:16:00.5 3/18/07: Initialization OK! Starting GameEx!
19:16:00.6 3/18/07: Testing Main Loop Once: Processing Frame
19:16:02.4 3/18/07: Testing Main Loop Once: Main Loop ran successfully
19:16:07.2 3/18/07: 21 Consecutive Exceptions Occured: Exiting
19:16:07.2 3/18/07: First Exception:
19:16:07.2 3/18/07: Error in the application.
19:16:07.2 3/18/07: at Microsoft.DirectX.DirectDraw.Surface.ReleaseDc(IntPtr hdc)
19:16:07.2 3/18/07: at GameEx.GameEx.mainform.DrawGameTextSelected(Int32 x, Int32 y, String textstring, Boolean notrans, Boolean forfade, Boolean forfade2, Boolean overidelscale)
19:16:07.2 3/18/07: at GameEx.GameEx.mainform.DrawV1SelectedItemText()
19:16:07.2 3/18/07: at GameEx.GameEx.mainform.DisplayFrame()
19:16:07.2 3/18/07: Last Exception:
19:16:07.3 3/18/07: Error in the application.
19:16:07.3 3/18/07: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
19:16:07.3 3/18/07: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
19:16:07.3 3/18/07: at GameEx.GameEx.mainform.DrawGameTextSelected(Int32 x, Int32 y, String textstring, Boolean notrans, Boolean forfade, Boolean forfade2, Boolean overidelscale)
19:16:07.3 3/18/07: at GameEx.GameEx.mainform.DrawV1SelectedItemText()
19:16:07.3 3/18/07: at GameEx.GameEx.mainform.DisplayFrame()
19:16:09.4 3/18/07: Exiting GameEx!
19:16:09.4 3/18/07: Saving Settings
19:16:11.0 3/18/07: Disposing Plugins
19:16:11.0 3/18/07: Checking for applications to Launch On Exit
Hello Tom,
Thanks for the quick reply. The latest version i could find on the site was 7.83, and that is what the log was generated from.
Thanks,
Sean
Hi, Im pretty sure this issue is fixed in the latest version. Go grab it.
Thanks,
Tom
Nope no luck still seems to be doing the same thing, as soon as i press the down arrow key to go to the next menu choice, it crashes.
Here is the latest log file:
20:14:12.4 3/18/07: GameEx: Version 7.84: Starting Log
20:14:12.4 3/18/07: Operating System Platform: Win32Windows
20:14:12.4 3/18/07: Operating System Name: Windows 98
20:14:12.4 3/18/07: Operating System Version: 4.10.67766446
20:14:12.6 3/18/07: Checking for versions of .net Framework installed
20:14:12.6 3/18/07: .net Framework 2.0 Installed
20:14:12.6 3/18/07: x86 Family 6 Model 9 Stepping 8
20:14:12.6 3/18/07: Running Randomize()
20:14:12.6 3/18/07: Loading PlugIns
20:14:12.7 3/18/07: Checking for applications to Launch On Startup
20:14:12.7 3/18/07: Initialising Video/MNG DLL's
20:14:12.7 3/18/07: Running Misc startup tasks
20:14:12.7 3/18/07: Setting Menu types
20:14:12.7 3/18/07: Opening Configuration File
20:14:12.7 3/18/07: Getting Configuration Values
20:14:12.7 3/18/07: Using Theme: Default - BlueEx - Arcade640x480
20:14:12.7 3/18/07: Checking for alternate Image Directory for Theme: Default - BlueEx - Arcade640x480
20:14:12.8 3/18/07: Arcade Mode is on
20:14:12.8 3/18/07: Launching HideOS.exe
20:14:12.8 3/18/07: Hiding Taskbar
20:14:12.8 3/18/07: Using Cabinet Friendly Control System
20:14:12.8 3/18/07: Is Media Center running?
20:14:12.8 3/18/07: Checking/Creating LCD Registry values
20:14:12.9 3/18/07: Check Media Center Exit/Start Mode
20:14:12.9 3/18/07: Media Center Mode 0
20:14:13.1 3/18/07: Snap Delay set to: 2
20:14:13.1 3/18/07: Get other settings
20:14:13.2 3/18/07: Mouse Input is disabled
20:14:13.3 3/18/07: Desktop set to Hide ICONS and set Background to Black
20:14:13.3 3/18/07: Backing up Registry Wallpaper Settings
20:14:13.3 3/18/07: Set: Find emulator artwork on best match basis
20:14:13.5 3/18/07: Start work for Form
20:14:13.5 3/18/07: Getting Original Screen Size
20:14:13.5 3/18/07: Initializing Component
20:14:14.7 3/18/07: Loading Controls.ini map file
20:14:14.8 3/18/07: Loading Custom Emulators
20:14:14.9 3/18/07: Loading Emulator 1: Nintendo NES Games
20:14:15.1 3/18/07: Loading Emulator 2: Nintendo SNES games
20:14:15.9 3/18/07: Using 2D Animations
20:14:15.9 3/18/07: Using General Font: Trebuchet MS
20:14:15.9 3/18/07: Using Title Font: Joystix
20:14:15.9 3/18/07: Initialising DirectDraw
20:14:16.1 3/18/07: Creating DirectDraw Device
20:14:16.1 3/18/07: Using Device: VIA/S3G UniChrome IGP
20:14:16.4 3/18/07: Setting Resolution to 640x480 16 bit color
20:14:16.6 3/18/07: Creating DirectDraw Surfaces
20:14:16.6 3/18/07: Creating Primary Surface - Full Screen Mode
20:14:16.6 3/18/07: Creating Back Buffer
20:14:17.0 3/18/07: Loading graphic Surfaces
20:14:17.2 3/18/07: Creating Surfaces Misc and Dialogs
20:14:18.0 3/18/07: Creating Surfaces Volume
20:14:18.0 3/18/07: Creating Surfaces Arrows
20:14:18.0 3/18/07: Creating Surfaces GameEXlogo Text
20:14:18.0 3/18/07: Creating Surfaces Toolbar
20:14:18.0 3/18/07: Creating Surfaces Backgrounds
20:14:18.5 3/18/07: Creating Surfaces Toolbar Controls
20:14:18.8 3/18/07: Creating Surfaces GameEx Logo
20:14:18.9 3/18/07: Creating Surfaces Home & Exit
20:14:18.9 3/18/07: Creating Surfaces Snaps
20:14:18.9 3/18/07: Creating Surfaces Menu and List Bars
20:14:19.2 3/18/07: Creating Fonts
20:14:19.2 3/18/07: Creating Menu Font
20:14:19.6 3/18/07: Creating Game Font
20:14:19.9 3/18/07: Creating Font Black
20:14:20.3 3/18/07: Creating Font Black Small
20:14:20.6 3/18/07: Creating Game Font Faded
20:14:20.9 3/18/07: Creating Title Font
20:14:22.8 3/18/07: Fonts Created Succesfully
20:14:50.0 3/18/07: Text/Language: English
20:14:50.0 3/18/07: Applying Language/Text
20:14:50.1 3/18/07: Initialising Bass Audio Library
20:14:50.3 3/18/07: MAME CMD options: -triplebuffer -nowindow -joy
20:14:50.3 3/18/07: Attempting to load game list
20:14:50.5 3/18/07: Loading last used Game List
20:14:50.5 3/18/07: Loading Start Page
20:14:50.9 3/18/07: Setting Music Volume
20:14:50.9 3/18/07: Creating DirectSound Device
20:14:50.9 3/18/07: Trying: Primary Sound Driver
20:14:50.9 3/18/07: Loading Sound Files
20:14:51.2 3/18/07: DirectSound Device Created Successfully
20:14:51.2 3/18/07: Initialising DirectInput for Gamepad support
20:14:51.3 3/18/07: Unable to create a joystick device
20:14:51.3 3/18/07: Initializing MCE Remote
20:14:51.4 3/18/07: Initialization OK! Starting GameEx!
20:14:51.4 3/18/07: Testing Main Loop Once: Processing Frame
20:14:53.2 3/18/07: Testing Main Loop Once: Main Loop ran successfully
20:15:44.9 3/18/07: 21 Consecutive Exceptions Occured: Exiting
20:15:44.9 3/18/07: First Exception:
20:15:44.9 3/18/07: Error in the application.
20:15:45.0 3/18/07: at Microsoft.DirectX.DirectDraw.Surface.ReleaseDc(IntPtr hdc)
20:15:45.0 3/18/07: at GameEx.GameEx.mainform.DrawGameTextSelected(Int32 x, Int32 y, String textstring, Boolean notrans, Boolean forfade, Boolean forfade2, Boolean overidelscale)
20:15:45.0 3/18/07: at GameEx.GameEx.mainform.DrawV1SelectedItemText()
20:15:45.0 3/18/07: at GameEx.GameEx.mainform.DisplayFrame()
20:15:45.0 3/18/07: Last Exception:
20:15:45.0 3/18/07: Error in the application.
20:15:45.0 3/18/07: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
20:15:45.0 3/18/07: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
20:15:47.7 3/18/07: Exiting GameEx!
20:15:47.7 3/18/07: Saving Settings
20:15:49.2 3/18/07: Disposing Plugins
20:15:49.2 3/18/07: Checking for applications to Launch On Exit
Sorry, your version is OK. The error in the log is not a bug in GameEx by the look at it. Its an error on your system. I would try latest drivers/udates etc. If that does not help let me know.
Your issue should be fixed in 7.90
