Hi All,
I've been playing with mouse disabled option lately.
It seems that when it is turned ON. I can still get the mouse cursor appearing in GameEx by moving the mouse.
Left mouse button is disabled but right mouse button reacts like 'back button' in GameEx.
The scrolling mouse button still works and scroll the Mame game list in Gameex
Is there a way to totally disable the mouse ?
All buttons should be deactivated, as well as mouse scrolling button and cursor.
Thanks in advance for your comment
Jontox
Hi All,
Jontox
yes in the config app, under Input settings choose disable mouse input (4th option down)
I've already done that Michael.
What I was describing is the resulting behavior when the mouse is presumably disabled.
:mellow:
I have mouse disabled as well, and, although I don't use a mouse with my cabinet, I have noticed that when I bump the mouse, it does show up for a while at least. I haven't found a way to disable it completely in GameEx.
only way i can think of doing this is some code in gameex its self, that basicly sends the mouse pointer to the botton right of the screen and holds it there while in gameex. this would make the mouse not show on screen
