I am running registered GameEx. I updated HK's LED plugin from 1.87 to 1.90. When the system boots, I receive the following error.
Once I hit "OK", the error comes back up 4 more times. After the last one, GameEx loads normally and the functionality appears normal.
I don't mind using 1.87 but I wanted to report what was happening for review. I am pretty sure that there were no other changes to my system other than that change to 1.90. The plugin is great! I am, though, using the Groovy Game Gear Novagem's with the LED-Wiz, not the Electric Ice buttons. Not sure if that makes a difference or not.
Here is my log:
19:15:41.8 3/15/2007: GameEx: Version 7.71: Starting Log
19:15:41.8 3/15/2007: Operating System Platform: Win32NT
19:15:41.8 3/15/2007: Operating System Name: Windows XP
19:15:41.8 3/15/2007: Operating System Version: 5.1.2600
19:15:41.8 3/15/2007: Checking for versions of .net Framework installed
19:15:41.8 3/15/2007: .net Framework 1.1 Installed
19:15:41.8 3/15/2007: .net Framework 2.0 Installed
19:15:41.9 3/15/2007: Intel® Pentium® 4 CPU 1.70GHz
19:15:41.9 3/15/2007: 1.69Ghz
19:15:42.0 3/15/2007: Running Randomize()
19:15:42.1 3/15/2007: Loading PlugIns
19:15:42.1 3/15/2007: Loaded Plugin:"LCD/LED Plugin" Version 1.90 By Ben Baker
19:24:26.0 3/15/2007: PlugIn: "LCD/LED Plugin" Initialized OK
19:24:26.0 3/15/2007: Checking for applications to Launch On Startup
19:24:26.0 3/15/2007: Initialising Video/MNG DLL's
19:24:26.1 3/15/2007: Running Misc startup tasks
19:24:26.1 3/15/2007: Setting Menu types
19:24:26.1 3/15/2007: Opening Configuration File
19:24:26.1 3/15/2007: Getting Configuration Values
19:24:26.1 3/15/2007: Using Theme: Default - Tron
19:24:26.1 3/15/2007: Checking for alternate Image Directory for Theme: Default - Tron
19:24:26.1 3/15/2007: Launching HideOS.exe
19:24:26.1 3/15/2007: Hiding Taskbar
19:24:26.1 3/15/2007: Is Media Center running?
19:24:26.1 3/15/2007: Checking/Creating LCD Registry values
19:24:26.1 3/15/2007: Check Media Center Exit/Start Mode
19:24:26.1 3/15/2007: Media Center Mode 2
19:24:26.2 3/15/2007: Snap Delay set to: 1
19:24:26.2 3/15/2007: Get other settings
19:24:26.3 3/15/2007: SlikStik support enabled
19:24:26.3 3/15/2007: Using DirectInput for keyboard input
19:24:26.3 3/15/2007: Start work for Form
19:24:26.3 3/15/2007: Getting Original Screen Size
19:24:27.4 3/15/2007: Initializing Component
19:24:28.1 3/15/2007: Initialising Windows Media Player Component
19:24:28.2 3/15/2007: MAME Path is: c:\mame
19:24:28.3 3/15/2007: MAME EXE file is: mame.exe
19:24:28.3 3/15/2007: ROM Paths are: C:\Mame\roms;C:\Mame\roms
19:24:28.3 3/15/2007: Catver.ini is located at: C:\Mame\catver.ini
19:24:28.3 3/15/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
19:24:28.3 3/15/2007: History.dat is located at: C:\Mame\history.dat
19:24:28.3 3/15/2007: nplayers.ini Not Found
19:24:28.3 3/15/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
19:24:28.4 3/15/2007: Loading Controls.ini map file
19:24:28.4 3/15/2007: Snap Path is: c:\Mame\snap
19:24:28.4 3/15/2007: AVI Snap Path: Not Found
19:24:28.4 3/15/2007: Flyer Path is: c:\Mame\flyers
19:24:28.4 3/15/2007: Cabinet Path is: C:\Mame\cabinets
19:24:28.4 3/15/2007: Title Path is: C:\Mame\titles
19:24:28.4 3/15/2007: Panel Path: Not Found
19:24:28.4 3/15/2007: Manual Path: Not Found
19:24:28.4 3/15/2007: Icon Path is: C:\Mame\icons
19:24:28.4 3/15/2007: Marquee Path is: c:\Mame\marquees
19:24:28.5 3/15/2007: Loading Custom Emulators
19:24:28.5 3/15/2007: Loading Emulator 1: Nintendo 64 Games
19:24:28.5 3/15/2007: Loading Emulator 2: Nintendo SNES games
19:24:28.7 3/15/2007: Using 2D Animations
19:24:28.7 3/15/2007: Using General Font: Trebuchet MS
19:24:28.7 3/15/2007: Using Title Font: Trebuchet MS
19:24:28.7 3/15/2007: Initialising DirectDraw
19:24:28.8 3/15/2007: Applying GameEx is Loading Image
19:24:29.0 3/15/2007: Creating DirectDraw Device
19:24:29.0 3/15/2007: Using Device: Primary Display Driver
19:24:29.3 3/15/2007: Setting Resolution to 640x480 32 bit color
19:24:29.3 3/15/2007: Creating DirectDraw Surfaces
19:24:29.3 3/15/2007: Creating Primary Surface - Full Screen Mode
19:24:29.4 3/15/2007: Creating Back Buffer
19:24:29.7 3/15/2007: Loading graphic Surfaces
19:24:30.0 3/15/2007: Creating Surfaces Misc and Dialogs
19:24:30.2 3/15/2007: Creating Surfaces Volume
19:24:30.2 3/15/2007: Creating Surfaces Arrows
19:24:30.3 3/15/2007: Creating Surfaces GameEXlogo Text
19:24:30.3 3/15/2007: Creating Surfaces Toolbar
19:24:30.3 3/15/2007: Creating Surfaces Backgrounds
19:24:32.4 3/15/2007: Creating Surfaces Toolbar Controls
19:24:32.5 3/15/2007: Creating Surfaces GameEx Logo
19:24:32.5 3/15/2007: Creating Surfaces Home & Exit
19:24:32.5 3/15/2007: Creating Surfaces Snaps
19:24:32.5 3/15/2007: Creating Surfaces Menu and List Bars
19:24:32.7 3/15/2007: Creating Fonts
19:24:32.7 3/15/2007: Creating Menu Font
19:24:32.8 3/15/2007: Restoring Menu Font From Cache
19:24:33.5 3/15/2007: Creating Game Font
19:24:34.3 3/15/2007: Creating Font Black
19:24:34.6 3/15/2007: Creating Font Black Small
19:24:34.8 3/15/2007: Creating Game Font Faded
19:24:36.0 3/15/2007: Creating Title Font
19:24:36.1 3/15/2007: Restoring Title Font From Cache
19:24:36.9 3/15/2007: Fonts Created Succesfully
19:24:36.9 3/15/2007: Starting GameExtender Publisher
19:24:37.0 3/15/2007: Text/Language: English
19:24:37.0 3/15/2007: Applying Language/Text
19:24:37.0 3/15/2007: Initialising Bass Audio Library
19:24:37.3 3/15/2007: MAME CMD options: -triplebuffer -nowindow -joy
19:24:37.3 3/15/2007: Attempting to load game list
19:24:37.7 3/15/2007: Loading last used Game List
19:24:37.7 3/15/2007: Setting Music Volume
19:24:37.7 3/15/2007: Loading music
19:24:39.2 3/15/2007: Creating DirectSound Device
19:24:39.2 3/15/2007: Trying: Primary Sound Driver
19:24:39.2 3/15/2007: Loading Sound Files
19:24:39.5 3/15/2007: DirectSound Device Created Successfully
19:24:39.5 3/15/2007: Creating ICONS
19:24:39.5 3/15/2007: Restoring Cached ICONS from File
19:24:43.9 3/15/2007: Gamepad/Joystick disabled
19:24:43.9 3/15/2007: Initialising DirectInput for Keyboard support
19:24:44.3 3/15/2007: Playing intro sound file
19:24:44.3 3/15/2007: Initializing MCE Remote
19:24:44.4 3/15/2007: Initialization OK! Starting GameEx!
19:24:44.4 3/15/2007: Testing Main Loop Once: Processing Frame
19:24:45.4 3/15/2007: Testing Main Loop Once: Main Loop ran successfully
19:25:25.6 3/15/2007: Exiting GameEx!
19:25:25.6 3/15/2007: Saving Settings
19:25:27.5 3/15/2007: Disposing Plugins
19:25:27.5 3/15/2007: Checking for applications to Launch On Exit
Thanks for any help!
HooPZ
This error is related to the reading of Mame's cfg files which is a recently added feature. It could be caused by a variety of things..
- The version of Mame. Since I have added support for the latest version of Mame, older versions of Mame may have a different xml structure for their cfg files.
- You have key mappings in your cfg files that I have not taken into consideration. My plugin can only handle simple key mappings, as I havn't had the opportunity to test more complicated mappings (Eg. multiple key mappings).
- If your not using custom key mappings in Mame, I suggest you delete all the files in <MAMEFOLDER>\cfg. That may solve the issue.
Provide me with more info and I may be able to fix the bug. Otherwise I can always add an option to turn off support for custom key mappings.
I didn't think I had many/any custom key mappings but I looked in my config folder and there were quite a few there. I moved that folder out, restarted, and everything was fine. I certainly appreciate your help and the plugin is awesome!
Does this mean, though, that I can't use any customer configs? I'll modify a couple of "minor" things and see if/when it gives me the error again.
Thanks Headkaze!
Like I said it could be the version of Mame your using or multiple key mappings I'm not sure. But this plugin should work if you map buttons to something else in Mame. The last feature I added was for this so there hasn't been much testing for it. It works for me that's about all I know :)
