Quick theme Question & possible theme editor bug?
Im just wondering if it is possible to change the colour or text on a theme to yellow?
cant seem to find a way of doing it
also a possible theme editor bug?
when i open theme editor and use the open box that comes up when theme editor opens i select the theme and get a error message
"error accoured while attempting to open the theme" it does this with all the V2 themes but when i open via the file menu i have no problems
thanks Michael
I've heard of that bug before, but I can't seem to reproduce the problem here. What's even stranger is that the method called by both the Welcome screen and menu system for opening a theme is the same. So I can't understand why one way works and the other way doesn't.
To change the text color, go into the Theme Options, select "Text Color".
There is a newer version of the Theme Editor (1.76) that will be released when Tom adds support for module layouts. Then every screen in GameEx will be able to have a custom layout. MameWah layout importing should then work properly too.
i've got the same problem. i can change options, but the changes are only shown by starting the themeeditor new. and i cant change the textcolour, too. how are the colours defined in the theme.ini?
i have only just started geting the problem in the last week or two if you have any ideas on fixing it im willing to help out
yeh i also cant change the colour it dosnt seem to save the settings
The first thing you can try is the latest version. See if there is any change.
seems to have worked il let you know if there is any problems
thanks, Michael
thanks Michael
Hi, just to let you know, somehow a corrupt themeditor.exe got into the gameex install, however this should be ok in the latest versions of GameEx.
thanks! this one is ok.
