Hello...every time i launch magic engine (both .99 and 1.x) it runs in demo mode though gameex. However, when i run the program by itself, its unlock (i did purchase key for 20 bucks)
Any ideas what the problem is when it launchs magic engine?
On a side note, is there a way to change the button layout? I know magic engine default admin controls are 1-9, etc... however, coin, start are 1,5, 2, 6 respectivly and i would hate to change that for all programs (using ipac2) Thanks.
!) I have an unlocked version of MagicEngine also. I had to delete the .cfg (or .ini if it was) file after installing the key to make it work in both environments.
2) As far as I know, there isn't a way to change admin controls - only joystick button assignments.
Hope that helps!
