I have GameEx set to load on system startup in xp. The shortcut is in the startup folder. Though with this newest release, it crashes every time. I can load it up afterwards just fine though. Here is the log:
21:18:21.9 6/17/2005: GameEx: Version 4.07: Starting Log
21:18:21.9 6/17/2005: Operating System Platform: Win32NT
21:18:21.9 6/17/2005: Operating System Name: Windows XP
21:18:21.9 6/17/2005: Operating System Version: 5.1.2600
21:18:21.9 6/17/2005: Running Randomize()
21:18:21.9 6/17/2005: Running Misc startup tasks
21:18:21.9 6/17/2005: Hiding Cursor
21:18:21.9 6/17/2005: Setting Menu types
21:18:21.9 6/17/2005: Opening Configuration File
21:18:21.9 6/17/2005: Getting Configuration Values
21:18:21.9 6/17/2005: Using Theme: Default - Default
21:18:21.9 6/17/2005: Checking for alternate Image Directory for Theme: Default - Default
21:18:21.9 6/17/2005: Applying Language/Text
21:18:22.1 6/17/2005: Snap Delay set to: 2
21:18:22.1 6/17/2005: Is Media Center running?
21:18:22.1 6/17/2005: Check Media Center Exit/Start Mode
21:18:22.1 6/17/2005: Media Center Mode 2
21:18:22.1 6/17/2005: Get other settings
21:18:22.1 6/17/2005: Launching HideOS.exe
21:18:22.8 6/17/2005: Hiding Taskbar
21:18:22.8 6/17/2005: Start work for Form
21:18:22.8 6/17/2005: Getting Original Screen Size
21:18:22.8 6/17/2005: Loading ICON
21:18:22.8 6/17/2005: Initializing Component
21:18:22.9 6/17/2005: Using General Font: Verdana
21:18:22.9 6/17/2005: Using Title Font: Verdana
21:18:22.9 6/17/2005: Initialising DirectDraw
21:18:22.9 6/17/2005: Applying GameEx is Loading Image
21:18:23.0 6/17/2005: Creating DirectDraw Device
21:18:23.0 6/17/2005: Using Device: RADEON 9700 PRO
21:18:23.1 6/17/2005: Setting Resolution to 800x600 32 bit color
21:18:23.1 6/17/2005: Creating DirectDraw Surfaces
21:18:23.1 6/17/2005: Creating Primary Surface - Full Screen Mode
21:18:23.1 6/17/2005: Creating Back Buffer
21:18:23.1 6/17/2005: Loading graphic surfaces
21:18:23.3 6/17/2005: ERRORS DETECTED: EXITING
Hey,
I can't think of any reason why this would happen. Did it not happen with older versions? Have you changed the default theme at all, or installed any other software? Nothing much has changed where GameEx is failing for you in the last several versions.
Tom
It happened a couple of days in a row and then it just stopped. Now it loads fine. I think if I make it such that there is like a 2 second pause before it loads so the other boot items have time to finish, i wont have this problem again. Anyone know how to pause in the XP scripting language so I can make a .bat and run it instead?
You can use Sleep.exe which is included in the GameEx install. It's fixed at about 2-4 secs but you can call it more than once.
