does anyone have geforce 6500 and use sega saturn emu ok
because my fullscreen dont work
so im trying to find the fault
and i thought it would be best to post it here as i usually get a quick reply
here are my specs
p4 3,0ghz hyperthreading
512 ram
geforce 6500 256mb pci express
and a 21" crt moniter
i also have problems seeing the game moorhuhn kart 2
i can here it but not see it
and in ssf emulator in fullscreen i just see changing colors as if i am seeing 1 big pixel
i have played around with resolution and new drivers
it works fine in windowed mode
any ideas
thanx
here are my specs
512 ram
any ideas
thanx
i have got it working on a 2800+ semptron (64bit) 512mb ram 6200 AGP 256mb gfx card it runs in full screen just not that good realy
here are my specs
512 ram
any ideas
thanx
One of my systems has a p4 3.0 gig with a geforce 6200, and it works fine with all screen options. You could try disabling or enabling Enforce Aspect Ratio, VSynch Wait, Direct Draw and Bilinear Filtering in the options for Screen. If it works in windowed mode, I would assume that one or more of these options for fullscreen is causing your problems.
i tryed everything,
but the derect 3d option crashed on me
and comes up with an error abuut direct draw 7 or something
and i have directx 9,c
i tryed everything,
i have tried a few more games and some games do eaxctly what you said yet others work in full screen fine
for instance street fighter zero Alpha works fine in full screen yet sega rally dosnt
my setup is pritty much default only thing changed is remove scan lines
i'll downlad street fighter zero Alpha and try that then,
hopefully that will work
What version of SSF are you guys using? With the most recent release (Ver0.08 alpha R5), all games that are supposed to work, work fine in full screen for me.
You should check this website for game compatibility http://www.segasaturn.org/
yes thats the version i use. I have noticed that all the games seem to work on my other pc. So im wondering if nvidia drivers because the pc it all works on is a lower spec pc.
I have 2 systems, both with the most recent Nvidia Drivers. Both systems work fine with all games that are supposed to work, in window mode or full screen.
System 1
Core2quad, Geforce 8800GTX
System 2
P4, 3ghz, Geforce 6200
Maybe it's your monitor refresh rate or resolution? I'm really not sure what else it could be.
System 1
System 2
no
i tryied every refresh rate my monitor could handle
60
71
75
85
and no luck
and resolution of 800,600
and 1024,768
no luck
that was the first thing i thought of
the thing is, is that cassini works in full screen but i can get it workin in gameex without using batch files and stuff
ive just tried the new alpha 6 and no luck still
