I just downloaded the newest version of GameEx and everything is fine, all themes work except for the Deep Purple theme. Any ideas.
06:38:24.6 06/15/2005: GameEx: Version 4.07: Starting Log
06:38:24.7 06/15/2005: Operating System Platform: Win32NT
06:38:24.7 06/15/2005: Operating System Name: Windows XP
06:38:24.7 06/15/2005: Operating System Version: 5.1.2600
06:38:24.7 06/15/2005: Running Randomize()
06:38:24.7 06/15/2005: Running Misc startup tasks
06:38:24.7 06/15/2005: Hiding Cursor
06:38:24.7 06/15/2005: Setting Menu types
06:38:24.7 06/15/2005: Opening Configuration File
06:38:24.7 06/15/2005: Getting Configuration Values
06:38:24.8 06/15/2005: Using Theme: Default - Deep Purple
06:38:24.8 06/15/2005: Checking for alternate Image Directory for Theme: Default - Deep Purple
06:38:24.8 06/15/2005: Applying Language/Text
06:38:25.1 06/15/2005: Snap Delay set to: 3
06:38:25.1 06/15/2005: Is Media Center running?
06:38:25.1 06/15/2005: Check Media Center Exit/Start Mode
06:38:25.2 06/15/2005: Media Center Mode 2
06:38:25.2 06/15/2005: Get other settings
06:38:25.2 06/15/2005: SlikStik support enabled
06:38:25.3 06/15/2005: Launching HideOS.exe
06:38:27.4 06/15/2005: Hiding Taskbar
06:38:27.4 06/15/2005: Start work for Form
06:38:27.5 06/15/2005: Getting Original Screen Size
06:38:27.5 06/15/2005: Loading ICON
06:38:27.5 06/15/2005: Initializing Component
06:38:27.6 06/15/2005: Arcade Mode is on
06:38:27.7 06/15/2005: Using General Font: Trebuchet MS
06:38:27.7 06/15/2005: Using Title Font: Trebuchet MS
06:38:27.7 06/15/2005: Initialising DirectDraw
06:38:27.7 06/15/2005: Applying GameEx is Loading Image
06:38:28.0 06/15/2005: Creating DirectDraw Device
06:38:28.2 06/15/2005: Setting Resolution to 800x600 16 bit color
06:38:30.7 06/15/2005: Creating DirectDraw Surfaces
06:38:30.8 06/15/2005: Creating Primary Surface - Full Screen Mode
06:38:30.8 06/15/2005: Creating Back Buffer
06:38:30.9 06/15/2005: Loading graphic surfaces
06:38:34.8 06/15/2005: ERRORS DETECTED: EXITING
