TurboGraphix16 CD - getting game to boot from GameEx problem
Hi,
I can't seem to get MagicEngine to boot CD games automatically.
I used the config from the sticky post but no luck.
GameEx loads but just leaves me with black screen until I ESC.
I tried from command line to mount in deamon tools and then run "pce.exe syscard3.pce" and the same thing!
here is what I try to do...
"C:\Program Files\D-Tools\daemon.exe" -mount 0,"C:\Documents and Settings\oneilbr\Desktop\PC Engine CD Roms\R-Type CD (Jap).nrg"
Seems to mount the image correctly.
Then i run ...
MagicEngine just loads up its main menu and I have to manually select boot cd and then the drive its mounted on before I get the game to run.
My MagicEngine cfg (pce.ini) is as it was when I installed it except I changed .... drive_letter to F: (which is what Deamon Tools uses)
# cd-rom settings
[cdrom]
; CD-ROM drive
; 1 -> first CD-ROM drive [default]
; 2 -> second CD-ROM drive
drive=
; CD-ROM drive letter
; (Windows 2000/XP only)
; D:
; E:
drive_letter=F:
; CD-ROM cache
; y -> enable [default]
; n -> disable
cache=
; CD-ROM cache size
; 0 .. 8192 KB [default = 512]
cache_size=
Thanks guys. Your help would be greatly appreciated.
Cheers,
Brian.
A more complete ini
Thanks. The only diff between our ini files is the ...
[cdrom]
; CD-ROM drive
drive=
I tried 1 through 4 and tried it. No luck. Still won't auto load the CD game :(
Wouldn't this section be of more importance?
default_system_card=
# path settings
[path]
; system card paths
system_card_1=
system_card_2=
system_card_3=
system_card_4=
Also to boot the CD directly shouldn't the commandline be
pce.exe -cd
# path settings
[path]
; system card paths
system_card_1=
system_card_2=
system_card_3=
system_card_4=
pce.exe -cd
I have the syscard stuff. I only posted a small part of my ini.
I tried "pce.exe -cd" with the image mounted. And it still just loads MagicEngine & no game. Appreciate the help.
Thanks Nologic. I got the syscard3.pce and now it works :)
Deamon tools mounts the image. then "pce.exe syscard3.pce -cd" ... works a charm :)
Thanks again for your help.
