Hi all , just upgraded to 7.52 and GameEx stops with a Error: 5 - Error in the application ?
Heres my log, and thanks.
01:44:12.2 02/02/2007: GameEx: Version 7.52: Starting Log
01:44:12.2 02/02/2007: Operating System Platform: Win32NT
01:44:12.2 02/02/2007: Operating System Name: Windows XP
01:44:12.2 02/02/2007: Operating System Version: 5.1.2600
01:44:12.2 02/02/2007: Checking for versions of .net Framework installed
01:44:12.2 02/02/2007: .net Framework 2.0 Installed
01:44:12.2 02/02/2007: AMD Athlon 64 Processor 4000+
01:44:12.2 02/02/2007: 2.4Ghz
01:44:12.2 02/02/2007: Running Randomize()
01:44:12.2 02/02/2007: Loading PlugIns
01:44:12.2 02/02/2007: Checking for applications to Launch On Startup
01:44:12.2 02/02/2007: Initialising Video/MNG DLL's
01:44:12.2 02/02/2007: Running Misc startup tasks
01:44:12.2 02/02/2007: Setting Menu types
01:44:12.2 02/02/2007: Opening Configuration File
01:44:12.2 02/02/2007: Getting Configuration Values
01:44:12.2 02/02/2007: Using Theme: Default - Soul Calibur
01:44:12.2 02/02/2007: Checking for alternate Image Directory for Theme: Default - Soul Calibur
01:44:12.2 02/02/2007: Arcade Mode is on
01:44:12.2 02/02/2007: Launching HideOS.exe
01:44:12.2 02/02/2007: Hiding Taskbar
01:44:12.4 02/02/2007: Using Cabinet Friendly Control System
01:44:12.4 02/02/2007: Is Media Center running?
01:44:12.4 02/02/2007: Checking/Creating LCD Registry values
01:44:12.4 02/02/2007: Check Media Center Exit/Start Mode
01:44:12.4 02/02/2007: Media Center Mode 2
01:44:12.5 02/02/2007: Snap Delay set to: 2
01:44:12.5 02/02/2007: Get other settings
01:44:12.5 02/02/2007: Set: Find emulator artwork on best match basis
01:44:12.5 02/02/2007: Using DirectInput for keyboard input
01:44:12.5 02/02/2007: Start work for Form
01:44:12.5 02/02/2007: Getting Original Screen Size
01:44:12.5 02/02/2007: Initializing Component
01:44:12.6 02/02/2007: MAME Path is: C:\Program Files\mame
01:44:12.6 02/02/2007: daphne Path is: C:\Daphne
01:44:12.6 02/02/2007: daphne EXE file is: Daphne.exe
01:44:12.6 02/02/2007: Use daphne on. Daphne.exe will launch games
01:44:12.6 02/02/2007: MAME EXE file is: mame32FXpp.exe
01:44:12.6 02/02/2007: ROM Path is: C:\Program Files\mame2\roms
01:44:12.6 02/02/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
01:44:12.6 02/02/2007: History.dat is located at: C:\Program Files\Mame\history.dat
01:44:12.6 02/02/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
01:44:12.6 02/02/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
01:44:12.6 02/02/2007: Loading Controls.ini map file
01:44:12.6 02/02/2007: Snap Path is: C:\Program Files\Mame\snap
01:44:12.6 02/02/2007: AVI Snap Path: Not Found
01:44:12.6 02/02/2007: Flyer Path is: C:\Program Files\Mame\flyers
01:44:12.6 02/02/2007: Cabinet Path is: C:\Program Files\Mame\cabinets
01:44:12.6 02/02/2007: Title Path is: C:\Program Files\Mame\titles
01:44:12.6 02/02/2007: Panel Path: Not Found
01:44:12.6 02/02/2007: Manual Path: Not Found
01:44:12.6 02/02/2007: Icon Path is: C:\Program Files\Mame\icons
01:44:12.7 02/02/2007: Marquee Path is: C:\Program Files\Mame\marquees
01:44:12.7 02/02/2007: Loading Custom Emulators
01:44:12.7 02/02/2007: Loading Emulator 1: Nintendo NES
01:44:12.7 02/02/2007: Loading Emulator 2: Super Nintendo
01:44:12.7 02/02/2007: Loading Emulator 3: Nintendo 64
01:44:12.7 02/02/2007: Loading Emulator 4: Nintendo GameBoy
01:44:12.8 02/02/2007: Loading Emulator 5: Nintendo GameBoy Colour
01:44:12.8 02/02/2007: Loading Emulator 6: Nintendo GameBoy Advance
01:44:12.8 02/02/2007: Loading Emulator 7: Colecovision
01:44:12.9 02/02/2007: Loading Emulator 8: Atari 2600
01:44:12.9 02/02/2007: Loading Emulator 9: Atari 5200
01:44:12.9 02/02/2007: Loading Emulator 10: Atari 7800
01:44:12.9 02/02/2007: Loading Emulator 12: Sega Megadrive
01:44:13.0 02/02/2007: Loading Emulator 13: Automation Menus
01:44:13.0 02/02/2007: Loading Emulator 14: Medway Boys Menus
01:44:13.0 02/02/2007: Loading Emulator 15: Pompey Pirates
01:44:13.1 02/02/2007: Using 3D Alpha Blended Animations. This could be slow
01:44:13.1 02/02/2007: Using General Font: HandelGothic BT
01:44:13.1 02/02/2007: Using Title Font: HandelGothic BT
01:44:13.1 02/02/2007: Initialising DirectDraw
01:44:13.1 02/02/2007: Applying GameEx is Loading Image
01:44:13.2 02/02/2007: Creating DirectDraw Device
01:44:13.2 02/02/2007: Using Device: Ultimarc ArcadeVGA
01:44:13.2 02/02/2007: Setting Resolution to 640x480 32 bit color
01:44:13.2 02/02/2007: Creating DirectDraw Surfaces
01:44:13.2 02/02/2007: Creating Primary Surface - Full Screen Mode
01:44:13.2 02/02/2007: Creating Back Buffer
01:44:13.3 02/02/2007: Loading graphic Surfaces
01:44:13.3 02/02/2007: Creating Surfaces Misc and Dialogs
01:44:13.4 02/02/2007: Creating Surfaces Volume
01:44:13.4 02/02/2007: Creating Surfaces Arrows
01:44:13.4 02/02/2007: Creating Surfaces GameEXlogo Text
01:44:13.4 02/02/2007: Creating Surfaces Toolbar
01:44:13.4 02/02/2007: Creating Surfaces Backgrounds
01:44:14.6 02/02/2007: Error: 5 - Error in the application.
01:44:16.4 02/02/2007: ERRORS DETECTED: EXITING
I'm pretty sure this is because of the theme your using (Soul Calibur). This error normally happens when it cannot load video backgrounds. Normally because codecs are not installed.
Errrm It should be fine as its the same theme i have been using with 7.50 for ages , i have gone used and used your edited 7.51
and all is fine again ??, bit to late to boot my cab up now , I will change the theme tommorrow but i dont think its that ??
Ta for quick reply though
Sorry, not sure Im with you there. 7.50 was only released this week. What is my edited 7.51?
Sorry its late, I mean been using 7.09 for ages , I have download the GameEx.exe from this topic
http://www.gameex.info/forums/index.php?showtopic=3199 and all is well again but its the 7.51 version
Btw tom goto bed its 03.24 now !!
Yeah Im heading there ;) There really is next to no difference between that version and 7.52. That version is basically 7.5199 if you get my meaning. I think maybe you just had a one off problem there, probably just needed a reboot.
