Well I found this little tutorial for JoyToKey.
I also came across version 3.7.9...I guess from what I've heard around here most only have 3.7.4...not like there is much difference.
Just fingured I'd pass this along as it tends to be useful when it comes to emulation. :)
You're not confusing PPJoyKey with this app then, are you? ;)
Emph
@ NOLOGIC:
Nice find Nologic. :)
I was using 3.7.8 for a while, but there were issues with trying to disable that using the script that I run to kill it. I rolled back to the last stable version I was using (3.7.4) but it seems the bug was addressed and removed. Trying it now. :)
Thanks again!
@ EMPH: I don't know what PPJoyKey is... Is it a keyboard-to-joypad converter of some sort?
Yeah, pretty much. It's an app that let's you create Virtual GamePads. So if you're using an I-pac, J-pac or X-Arcade for example and wan't to configure controls for games like Virtua Tennis for PC, you'll need to use it. You can launch multiple instances of it (for example one for each player) and it supports command line for loading different settings.
Emph
