i know creating avi snaps is for registered user. but i recently DL an awsome Kinst video and want to see how it looks displayed in gameex. im not getting it to work. so i assume that showing videos also is only for registered users? (in contrast to creating avi snaps)
so is showing avi snaps also for registered users?
just a quick and easy question.
peace all n keep up the great work
if you have set the video snap dir to the correct place in the emu config
then yes i would think it is for reg'd users not 100% what is for reg'd users
hmm ok so you dont know if showing avi snaps is for non registred users? i guess its only for registered users then?
If I read this correctly I'd assume that avi snaps are for all to use.
Actually if I recall correctly when I didn't have GameEx regged...I could in fact watch avi's...tho the nag screen was enough to make me reg in and of its self as I was setting up a butt load of emu's...any ways back on topic...you should be able to watch avi's.
thx for the reply, and i really will register soon.
could it be for me that the avi is not working cause its a wmv? or that my gameex is 5 months old?
i specifyed the video snap path, renamed the WMV to kinst (the same as the rom)
it should work?
wmv...no clue...but it should play avi and mpeg.
Your build of GameEx should be fine...think thats about the same time I started to play with it as well.
The size of the video file shouldn't make a differnce.
I don't know of any real rez the avi's are suppose to be at...but I'd make sure they are at least 320x240...or really damn close to that...any thing above should be fine.
Sounds to me like you don't have FFDShow installed...
