Can pinballX main screen (playfield) runs on a secondary monitor in full screen mode ?
I setup my two monitors as standard (playfield then backglass top aligned), but put the backglass monitor as primary.
As the playfield is rotated, I setup backglass primary intentionally
playfield is /Display0 and backglass is /Display1
When I run pinballX in Full screen mode, despite monitor=0 in pinballX.ini, playfield goes on backglass monitor over backglass and dmd
When I run in windowed mode, I can move it on secondary monitor with windowx=-1920 but I cannot remove the title bar and the backglass + dmd are then no more correctmy displayed
I run on version 6.58 of pinballX
PinballX.iniFetching info...
Thanks for the windowed mode, I forget it :)
Then I tested all monitor=[0, 5], no way to push on th eother screen
I also forgot to mention I have two GPUs
00:15:18.62  29/01/2025:  GPU 1: Intel(R) HD Graphics 4600   => backglass
00:15:18.62  29/01/2025:  GPU 2: NVIDIA GeForce GT 1030     => playfield
00:15:18.62  29/01/2025:  Displays: 2
This may be the cause ?
then would be awesome to support two GPUs as I have exhausted all possibilities and cannot manage to move the pinballX playfield on my rotated screen
Or have another way to reference monitor such as =0 (screen index) or @0 (pixel x coord) like in screenres.txt
Thanks a lot
Edited by leprinco
