  TSpeirs said:
Name: Random Arcade Sound Plugin
Version: 1.0
Author: Tom Speirs
Description: Plays random arcade classic sounds fx every 10 to 40 seconds in GameEx.
Extract the file to the plugins directory, and enable in the plugin manager.
http://www.tomspeirs.com/gameex/download/R...ArcadeSound.zip
is there anyway of turning the volume down on the mp3s there seem realy loud
its all working fine though :D
You can turn it down by changing the Music Volume setting, but this will affect the Jukebox too.
Thanks for checking it out, it was really just for fun :)
Version: 1.1 (update)
Author: Tom Speirs
1.1 allows volume to be set in the plugin confirguration and fixes minor timing issues which means now should be up to 40 seconds between sounds.
Edit: Just realised the volume setting wont be functional until next version of GameEx. Sorry.
Author: Tom Speirs
the download link is dead so i guess it will be in next version gameex?
***edit*** seem to be working now
