I have about got my HTPC set up just like I want but there is another question I have.
I have set up the plugin so I can exit Gameex with a combonation of buttons, but is it possible to setup button combo's to exit snes9x and nestopia and send me back to Gameex? I am sure it is but I cant seemed to get it figured out. The esc key on the keyboard is what I am having to hit.
Can someone send me some detailed info or point me to where I can find it?
Thanks for everyones help!
I'll see if I can come up with an answer for you this weekend.
Now are you trying to do this with the remote, game pad, remote keyboard,...hehe tho I would image the remote keyboard would be a cake walk. ;)
I should be putting mine together this weekend...but if all else fails I"ll just hook stuff up to my current system and give it a go.
Hopefully some one else will pop in with the answers you are needing.
I am using a gamepad. I am currently having to use the keyboard to exit out of the emulators and I would like to get rid of the keyboard.
Thanks for your help.
From your GameEx folder, browse to CONFIG\EMULATORS (full path is probably C:\Program Files\GameEx\CONFIG\EMULATORS). This is where Advanced Config's are located.
You will need to create an ini file for your gamepad. Lets call this gamepad.ini.
Place the following code in it...
[GAMEPADEXIT]
#MAP Gamepad controls to exit and make controls exit process
MapGamePadExit=true
#Flag the controls that exit a game by placing True next to each control. To not use the control as part of the combination use a 0
Left=True
Down=
Right=
Up=True
Button1=
Button2=
Button3=
Button4=True
Button5=True
Button6=True
Button7=
Button8=
Button9=
Button10=
The above will exit the game using Left + Button 4, 5 and 6 held down at once.
Next you need to go into your Emulator Setup and set the Advanced Config for each emulator you want to use the gamepad Advanced Config.
[GAMEPADEXIT]
MapGamePadExit=true
Left=True
Down=
Right=
Up=True
Button1=
Button2=
Button3=
Button4=True
Button5=True
Button6=True
Button7=
Button8=
Button9=
Button10=
Sorta off topic. But can the same be applied to exiting mame games? I had my son and his cousin playing on my cabinet tonight. One is 5 and the other 7. Both of them was smashing the 1st and 2nd player start button. This of course exits the game. Maybe something kid friendly?
