Running Sega CD with games in sub directories possible?
I turned on roms in folders option for this, however if I put my images into folders gameex no longer recognizes any of them. Any command line trick for this or is it not yet working?
Not yet implemented. See my reply to your post in Feature requests thread for a temporary solution.
Emph
Well I think there is a different way to go about this, than what was suggested in the new features thread.
For now I'll pursume that you have things setup like so:
\Sega CD\
\Sega CD\Game 1\
\Sega CD\Game 2\
\Sega CD\Game 3\
\Sega CD\Game ...\
Basically all the game folders are in stored in a common primary folder.
Now you'll need to grab and install Link Shell Extension to do as I purpose.
Actually follow the instructions on that page for the shell extension...basically you'll just create a hardlink in the \Sega CD\ folder of the CUE file (or what ever the load file is) thats contained in folder \Game 1\, so on and so forth.
Then just make sure your Emu's "Luanch Before" and "Luanch After" entrys are correct...refer to GameEx Virtual CD Help post.
This should ideally work, tho I have to admit I have not tested this.
