hi again i have a problem with snes rom when i put in the snes rom dir and i launch game ex the rom list appair in not normal mode i put a screenshot
the name of certain games appair 2 times and i dont have idea for resolve my problems
i have try to remove certain games and gameex without this games works perfect
this is the list of the games
anyone have an a idea ???
thanksssss
thanksssss
Nothing is wrong. It displays the last few games you have played at the top of the emulator list.
Not at the current time, sorry. :(
It really does more good than harm IMO.
ok now i think this
the most played games list maybe write in a ini files or txt or other files.
now if i change te files mode to read only the most played list cant write to file
now the problem is wath is the file ???
thanks in advance
Not sure, try doing a search in the GameEx folder for files containing the text of the last game played in the list?
ok now i have the solution !!!
to remove the most played list in snes or other emu is simply
you go to the dir data and find the .ini gamelist.ini
now open the file with notepad and delete all text inside now save and make the file in read only
with this you delete all the list of most played games
now go to the config dir and find the GameEx.ini open and search the last game you have played delete the
full line and save and make the file in read only ;)
with this you delete the last played games
this is my home made method ;)
