I have a Athlon 4000+ 2gb ram 6800gt. My PS1 games run too fast. Is there a way to slow these down somehow so they play properly on the computer?
Limit the frame rate in the graphics plugin.
That's odd that you would have to do that... I use Auto Frame Rate with a similar CPU and I have no problems.
Does it stutter or is it just too fast? Does it work properly outside of GameEx?
Also, to clarify... There's no graphics plugin for pSX. It's self-contained. You can limit the framerate however within the Configurations menu. I assume PSX games means the pSX emu is having problems... If you're using ePSXe then disregard my post.
