I think missed something, but i add radio stations where are they suppose to be in the gameex menu?
have you called the station a name, In the config app and also is it enabled. You have to do this for each station other than that im not sure
START -> All Programs -> GameEx -> Advanced Configuration -> Next Page -> Radio Stations.
Like Michael said, make sure you enable any stations you put in by selecting the tab that says Station XX Enabled - Yes.
no, you misunderstood, its setup, its labeled, its cfged, its enabled, it ready!
its Not in gameex! There is not "multimedia" in the menu like there should be, would it be in the default themes?
i only have in the menu, theme picker, blank space, export to mce, restart something...
and exit gameex that the only thing in my menu, i just want radio stations in there for now
Do you have flat menus enabled?
My radio stations show up on the first page but I may have changed a setting to get it to appear that way...
Just to see if it makes any difference I tried setting to flat menu on my dev machine (which has mostly default settings) and it just puts Radio on the start page instead of under Multimedia. So it must be some other setting or something.
