I was wondering how i would go about running iso, bin, and other images either emulated (sega cd /duo) or just pc with Alcohol 120%, not d. tools
sega cd dont need mounting in Kega emulator just use the image file as a normal rom file
ok cool, but how about turbo duo (pc engine) , or saturn? I saw the daemon tools setup in the gameex for a cmd setup i think, so how would that work for Alcohol 120% ?
(I see it as for "launch before" daemon.exe -mount 0,"[RomPath]\[RomFile]" )
Will a similar setup work for Alcohol 120% ?
