Hey folks,
well i tryed everything.
Re-installing gameex, re-installing framework etc.
I am using wxp
I get
19:36:52.9 12/28/2006: ERROR: An error occured while checking for previous instance of GameEx
19:36:52.9 12/28/2006: This can be caused by a bad windows or .net framework install.
19:36:52.9 12/28/2006: GameEx will likely function incorrectly as it cannot check for running processes
19:36:52.9 12/28/2006: GameEx will now exit with errors
19:36:52.9 12/28/2006: This type of error normally requires a new windows install
19:36:52.9 12/28/2006: and there is no known fix
19:36:52.9 12/28/2006: Try uninstalling .net Framework 1.1 and ensure 2.0 is installed
19:36:52.9 12/28/2006: Check any software either malicious or genuine
19:36:52.9 12/28/2006: that may stop scanning for processes
19:36:52.9 12/28/2006: Error: 1 - Application-defined or object-defined error.
19:36:52.9 12/28/2006: ERRORS DETECTED: EXITING
The solution is to reinstall windows it says
what else can i do more?
Hey folks,
I am using wxp
I get
try reinstalling .net framework first, It usualy .net not wondows :)
Hey folks,
I am using wxp
I get
Make sure you uninstall all instances of net framework. Then reinstall 1.1 then 2.0.
Nope did everything you said, still the same error.
i mean wtf? :rolleyes:
it just stopped working 1 day :rolleyes:
Hi, thats actually incorrect what lp says. You should uninstall .net 1.1 completely and not reinstall and install 2.0. That is the known fix as far as I know.
Ahh I was under the impression 1.1 was needed to upgrade to 2.0. Seeing as how when I installed 2.0, 1.1 remained on my system.
eeem when i uninstall 1.1 gameex says that it needs 1.1 installed???
what am i missing here ?
2.0 is installed at that point
i get the same if i only install 2.0 without 1.1 being installed
on a fresh install i installed .net 2.0 thinkin it would all work fine but gameex asked me to install 1.1 :blink:
**Question** does gameex need 2.0? or is it jsut a case of its more stable? because my main gameex pc only has 1.1 and seem to work fine.
GameEx should install fine is 1.1 is not installed and 2.0 is. Not sure whats going on with that, maybe thats a bug or your using an old version.
Theres no real advantage to running 2.0 at this stage, although in a month or so GameEx is going to need it as Im upgrading it to it.
The main thing is it is this known fix as far as I am aware to this issue.
So no .net 1.1 installed at at all. .net 2.0 installed. No need to reinstall GameEx.
im sorry tom,
but as soon as i only install 2.0, gameex gives me an error that it misses 1.1.
so i cannot run gameex anymore at this point :(
im sorry tom,
Can you get the error for me please? Screen dump, log, whatever it is.
Thanks.
Tom.
im sorry tom,
i get the same error with only .net 2.0 installed
its a windows critical error msgbox, basicly asking you to install .net 1.1 with two build number for .net versions 1.1xxx
this was not using the gameex installer i just copied gameex folder form hdd before format and placed back on a fresh install of windows with all latest xp updates and .net 2.0, gameex verison 7.09
njay if you install .net 1.1, even over the top of 2.0 gameex should work again it worked for me
dotnet 1.1 download link
It does work with 2.0 on its own, but just realised its because your using an old install that been upgraded over time.
To fix go into the gameex folder and delete all files thae have the extensions *.exe.config.
That will do it.
Tom
That will do it.
Tom
yeh that makes it work :D
