Ok I read the forums and tried for quite sometime various ways to get this before posting.
I am using Daemon Tools V4.08HE Using SSF V.0.07 betaR6
SSF works 100% perfect out Gameex.
My gameex command lines are the following
C:\Program Files\DAEMON Tools\daemon.exe -mount 0,"[RomPath]\[RomFile]"
C:\Program Files\DAEMON Tools\daemon.exe -unmount 0
If I go into command prompt and do a manual daemon.exe -mount 0, D:\emulators\ssf\roms\casper.iso
It will mount the file with no problems or prompts. Unmounts fine also. So the commands do work
Now When I go into Gameex and start my game I get an error from SSF saying "CD ROM DRIVE NOT READY"
So I look and sure enough my game isnt mounted..
So what am I missing here?
"C:\Program Files\DAEMON Tools\daemon.exe" -mount 0,"[RomPath]\[RomFile]"
"C:\Program Files\DAEMON Tools\daemon.exe" -unmount 0
Your missing a butt load of double quotes.
If there is a space in a path....then it needs to be inclosed with double quotes.
I will try that. Tell that to the creator of game ex he put the paths in not me :)
Thanks worked.
The cue files when mounted say Track type not supported. There only mp3s..
