  • 1 month later...
Sorry you did not get a reply until now but to answer you question, at this time there is a utility included with most GameEx variations called the "Setup Wizard". You basically use this tool to setup your emulators and rom path. Its pretty easy. Select the system then folder to your roms. You normally don't need to worry about anything else or artwork etc for most systems. its automatic.
