Hello folks,
I've recently got GameEx setup on my HTPC and im loving it. I have a couple questions though.
Im not sure why this happens but if i launch GameEx from within media center, media center is minimized and GameEx starts up as usual... the strange thing is I get an error whenever i try to run genesis games (using Gens emulator). If i close media center first..and then launch GameEx on its own.. the genesis games run fine. Is there a way i can force media center to close whenever gameEx is launched (instead of it minimizing).
One more question...
I've used good tools to rename my roms. Is there any tool out there that can remove extra roms from my collection ? ie. remove alternate roms, clones, bad dumps, non US region, etc...
This would be a lot easier than manually removing them... since some goodsets have thousands of roms.
Thanx for the help. ;)
Hello folks,
Dont know about the second question, but GameEx should close Media Center when launching. Look under the 'tweaks Perfomance' settings, and make sure media center mode is set to the recommended setting.
