I posted about this before, but I'm still having problems in attract mode. After a few games, I get a .NET framework error, all my desktop icons disappear (along with half of my start menu) and the only way I can successfully shut down is through the task manager.
Any ideas as to what causes this?
Simple as it sounds, I would reinstall the .NET if it happens all the time. How much investigating have you done with the issue? Does it do it like every 5 games, or every 5 minutes? Or does it appear random? Does it happen when you're inside GameEx, playing a game, or only during the Attract Mode? It might be something simple like a newly installed emulator that's flaky and whenever GameEx tries to access it, everything crashes. Try and narrow it down before just reinstalling .NET.
Exactly.
Well, the issue is that I'm not running attract mode unless I'm away. I just found it hard to swallow that out of all the things I use that rely on .NET framework that GameEx's attract mode is the only thing that causes this problem. I have reinstalled framework (of course I did this before I posted the first time) and I have not made a single change in GameEx to cause this to happen. All I know is when I leave for work or hit the sack, everything's peachy. It seems to be a totally random thing.
I will re-install the .NET framework again, but I'm confident that this will not resolve the issue. Any other suggestions?
Thanks Kaze. I'll try that. :)
Also your log, so we can see if its a particular emulator. When I said exactly I was referring to that not .net framework install, but that its probably an emulator messing up and needing a lot more details.
As for the black screen is this hideos.exe perhaps? Have you tried ALT-F4 on it_
Is GameEx.exe still running? What is the .net error?
Really need much more info.
Another question is do you have Attract mode running purely with Mame games or are you running other emu's as well? If it's the latter try switching to Mame only and see if it crashes again.
OK. Here goes nothing. :)
Originally, I had a command line argument in MAME to run two screens: -numscreens 2 ; that was working OK up until a week or so ago. I took the command-line argument out hoping that would fix the problem. Now, instead of getting a framework error like I was before, the game will boot up and load, then after about 30 seconds GameEx detects a phantom key press and exits back to the menu. This is happening before I was getting the .NET framework error because usually the error comes after a few minutes of Attract Mode running. That means I might have a whole new problem and once it is solved the .NET error might still be lurking.
I was running pSX, ZSNES and NEStopia in the screensaver, but I took these out when I had originally started having the .NET error. I am using vanilla MAME version 0.111 with updated and verified ROM sets.
My log will show several instances of GameEx detecting a keypress, so I'll post it here.
05:00:21.4  12/22/2006:  GameEx: Version 7.09: Starting Log
05:00:21.5 12/22/2006: Operating System Platform: Win32NT
05:00:21.5 12/22/2006: Operating System Name: Windows XP
05:00:21.5 12/22/2006: Operating System Version: 5.1.2600
05:00:21.5 12/22/2006: Checking for versions of .net Framework installed
05:00:21.5 12/22/2006: .net Framework 1.1 Installed
05:00:21.5 12/22/2006: .net Framework 2.0 Installed
05:00:21.5 12/22/2006: AMD Sempron(tm) 3000+
05:00:21.5 12/22/2006: 2Ghz
05:00:21.5 12/22/2006: Running Randomize()
05:00:21.5 12/22/2006: Loading PlugIns
05:00:21.7 12/22/2006: Checking for applications to Launch On Startup
05:00:21.7 12/22/2006: Initialising Video/MNG DLL's
05:00:21.7 12/22/2006: Running Misc startup tasks
05:00:21.7 12/22/2006: Setting Menu types
05:00:21.7 12/22/2006: Opening Configuration File
05:00:21.7 12/22/2006: Getting Configuration Values
05:00:21.7 12/22/2006: Using Theme: Default - BlueGlass - 1024x768
05:00:21.7 12/22/2006: Checking for alternate Image Directory for Theme: Default - BlueGlass - 1024x768
05:00:21.7 12/22/2006: Launching HideOS.exe
05:00:21.7 12/22/2006: Hiding Taskbar
05:00:21.7 12/22/2006: Is Media Center running?
05:00:21.8 12/22/2006: Checking/Creating LCD Registry values
05:00:21.8 12/22/2006: Check Media Center Exit/Start Mode
05:00:21.8 12/22/2006: Media Center Mode 2
05:00:21.8 12/22/2006: Text/Language: Custom
05:00:21.8 12/22/2006: Applying Language/Text
05:00:22.2 12/22/2006: Custom Game Device Input enabled: Getting custom codes
05:00:22.3 12/22/2006: Snap Delay set to: 1
05:00:22.3 12/22/2006: Get other settings
05:00:22.4 12/22/2006: Set: Find emulator artwork on best match basis
05:00:22.5 12/22/2006: Start work for Form
05:00:22.5 12/22/2006: Getting Original Screen Size
05:00:22.5 12/22/2006: Loading ICON
05:00:22.5 12/22/2006: Initializing Component
05:00:22.5 12/22/2006: Initialising Bass Audio Library
05:00:22.8 12/22/2006: Loading default loading screen
05:00:22.8 12/22/2006: Loading Custom Emulators
05:00:22.8 12/22/2006: Loading Emulator 1: Pinball (Visual Pinball)
05:00:22.9 12/22/2006: Loading Emulator 2: Playstation (pSX)
05:00:23.0 12/22/2006: Loading Emulator 3: N64 (PJ64)
05:00:23.1 12/22/2006: Loading Emulator 4: SNES (ZSNES)
05:00:23.2 12/22/2006: Loading Emulator 5: NES (NEStopia)
05:00:23.3 12/22/2006: Loading Emulator 6: Gameboy Advance (VBA)
05:00:23.4 12/22/2006: Loading Emulator 7: Gameboy Color / Mono (VBA)
05:00:23.5 12/22/2006: Loading Emulator 9: Genesis (KEGA)
05:00:23.6 12/22/2006: Loading Emulator 10: Master System (KEGA)
05:00:23.7 12/22/2006: Loading Emulator 11: Game Gear (KEGA)
05:00:23.7 12/22/2006: Loading Emulator 12: PC Engine (MagicEngine)
05:00:23.9 12/22/2006: Loading Emulator 13: Neo-Geo (NeoRageX)
05:00:24.0 12/22/2006: Loading Emulator 14: Neo-Geo Pocket (NeoPop)
05:00:24.1 12/22/2006: Loading Emulator 15: Jaguar (VJ)
05:00:24.2 12/22/2006: Loading Emulator 16: 7800 (MESS)
05:00:24.3 12/22/2006: Loading Emulator 17: 5200 (MESS)
05:00:24.4 12/22/2006: Loading Emulator 18: 2600 (Stella)
05:00:24.5 12/22/2006: Loading Emulator 19: Lynx (Handy)
05:00:24.6 12/22/2006: Loading Emulator 20: Colecovision (MESS)
05:00:24.7 12/22/2006: Loading Emulator 21: M.U.G.E.N. (WinMugen)
05:00:24.8 12/22/2006: Loading Emulator 23: Intellivision (Nostalgia)
05:00:25.2 12/22/2006: Using 3D Alpha Blended Animations. This could be slow
05:00:25.2 12/22/2006: Using General Font: Microsoft Sans Serif
05:00:25.2 12/22/2006: Using Title Font: Microsoft Sans Serif
05:00:25.2 12/22/2006: Starting GameExtender on: 127.0.0.1:8383
05:00:25.3 12/22/2006: Initialising DirectDraw
05:00:25.3 12/22/2006: Applying GameEx is Loading Image
05:00:25.4 12/22/2006: Creating DirectDraw Device
05:00:25.4 12/22/2006: Using Device: RADEON 9550
05:00:25.7 12/22/2006: Setting Resolution to 1024x768 32 bit color
05:00:25.7 12/22/2006: Creating DirectDraw Surfaces
05:00:25.7 12/22/2006: Creating Primary Surface - Full Screen Mode
05:00:25.8 12/22/2006: Creating Back Buffer
05:00:25.8 12/22/2006: Version 2 Theme being used. Loading.
05:00:25.9 12/22/2006: Loading Button Data
05:00:25.9 12/22/2006: Loading Font Data
05:00:25.9 12/22/2006: Loading Layout Data
05:00:25.9 12/22/2006: Loading Taskbar Data
05:00:25.9 12/22/2006: Loading graphic surfaces
05:00:26.0 12/22/2006: Creating Surfaces Misc and Dialogs
05:00:26.0 12/22/2006: Creating Surface Volume
05:00:26.0 12/22/2006: Creating Surfaces Arrows
05:00:26.0 12/22/2006: Creating Surfaces GameEXlogo Text
05:00:26.0 12/22/2006: Creating Surfaces Toolbar
05:00:26.1 12/22/2006: Creating Surfaces Backgrounds
05:00:26.4 12/22/2006: Creating Surfaces Toolbar Controls
05:00:26.4 12/22/2006: Creating Surfaces GameEx Logo
05:00:26.4 12/22/2006: Creating Surfaces Home & Exit
05:00:26.5 12/22/2006: Creating Surfaces Snaps
05:00:26.5 12/22/2006: Creating Surfaces Menu and List Bars
05:00:26.6 12/22/2006: Creating Fonts
05:00:26.6 12/22/2006: Creating Menu Font
05:00:26.7 12/22/2006: Creating Game Font
05:00:26.9 12/22/2006: Creating Font Black
05:00:27.1 12/22/2006: Creating Font Black Small
05:00:27.2 12/22/2006: Creating Game Font Faded
05:00:27.3 12/22/2006: Creating Title Font
05:00:27.4 12/22/2006: Restoring Title Font From Cache
05:00:27.5 12/22/2006: Fonts Created Succesfully
05:00:27.5 12/22/2006: Creating Radio Station Genres
05:00:27.6 12/22/2006: Succesfully created station genres
05:00:27.6 12/22/2006: Initialising Windows Media Player Component
05:00:27.7 12/22/2006: MAME Path is: L:\mame
05:00:27.7 12/22/2006: Model 2 Path Path is: C:\EMULATORS\Model 2
05:00:27.7 12/22/2006: Model 2 EXE file is: emulator.exe
05:00:27.7 12/22/2006: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
05:00:27.7 12/22/2006: ZiNc Path is: C:\EMULATORS\ZiNc
05:00:27.7 12/22/2006: ZiNc EXE file is: ZiNc.exe
05:00:27.7 12/22/2006: Use ZiNc on. ZiNc.exe will launch PSX games
05:00:27.7 12/22/2006: MAME EXE file is: mame.exe
05:00:27.7 12/22/2006: ROM Path is: L:\extras\roms
05:00:27.7 12/22/2006: Catver.ini is located at: L:\extras\folders\Catver.ini
05:00:27.7 12/22/2006: controls.ini Not Found
05:00:27.7 12/22/2006: History.dat is located at: L:\extras\dats\history.dat
05:00:27.7 12/22/2006: nplayers.ini is located at: L:\extras\folders\Multiplayer.ini
05:00:27.7 12/22/2006: MAMEinfo.dat is located at: L:\extras\dats\mameinfo.dat
05:00:27.8 12/22/2006: Loading Controls.ini map file
05:00:27.8 12/22/2006: Snap Path is: L:\extras\snap
05:00:27.8 12/22/2006: AVI Snap Path: Not Found
05:00:27.8 12/22/2006: Flyer Path is: L:\extras\flyers
05:00:27.8 12/22/2006: Cabinet Path is: L:\extras\cabinets
05:00:27.8 12/22/2006: Title Path is: L:\extras\titles
05:00:27.9 12/22/2006: Panel Path is: L:\extras\cpanel
05:00:27.9 12/22/2006: Icon Path is: L:\extras\icons
05:00:27.9 12/22/2006: Marquee Path is: L:\extras\marquees
05:00:27.9 12/22/2006: MAME CMD options: -triplebuffer -nowindow -joy -video d3d -noswitchres
05:00:27.9 12/22/2006: Attempting to load game list
05:00:28.2 12/22/2006: Loading last used Game List
05:00:28.2 12/22/2006: Setting Music Volume
05:00:28.2 12/22/2006: Creating DirectSound Device
05:00:28.3 12/22/2006: Trying: Primary Sound Driver
05:00:28.3 12/22/2006: Loading Sound Files
05:00:28.4 12/22/2006: DirectSound Device Created Successfully
05:00:28.4 12/22/2006: Creating ICONS
05:00:28.5 12/22/2006: Recreating ICONS
05:00:29.4 12/22/2006: Initialising DirectInput for Gamepad support
05:00:29.4 12/22/2006: Using Device SmartJoy PLUS USB Adapter
05:00:29.4 12/22/2006: Playing intro sound file
05:00:29.5 12/22/2006: Initializing MCE Remote
05:00:29.5 12/22/2006: Initialization OK! Starting GameEx!
05:00:29.5 12/22/2006: Testing Main Loop Once: Processing Frame
05:00:29.9 12/22/2006: Testing Main Loop Once: Main Loop ran successfully
05:00:41.6 12/22/2006: Starting Attract Mode
05:00:41.8 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe xeviousb -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
05:00:42.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:00:43.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:00:44.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:00:45.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:00:45.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:00:58.1 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
05:01:23.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe xeviousb -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -bezel -artwork_directory artwork
05:12:07.3 12/22/2006: Starting Attract Mode
05:12:07.5 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe fitegol2 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
05:12:08.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:12:09.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:12:10.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:12:10.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:12:12.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:12:24.3 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
05:22:30.8 12/22/2006: Starting Attract Mode
05:22:31.0 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe sbrkout -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
05:22:31.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:22:32.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:22:33.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:22:34.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:22:35.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:22:47.2 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
05:32:53.7 12/22/2006: Starting Attract Mode
05:32:53.8 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe nametune -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
05:32:54.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:32:55.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:32:56.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:32:57.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:32:58.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:33:10.6 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
05:43:17.0 12/22/2006: Starting Attract Mode
05:43:17.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe kof2002 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
05:43:17.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:43:18.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:43:19.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:43:20.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:43:21.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:43:33.8 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
05:53:56.4 12/22/2006: Starting Attract Mode
05:53:56.6 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe gng -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
05:53:57.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:53:58.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:53:59.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:54:00.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:54:01.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
05:54:13.5 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
06:04:19.8 12/22/2006: Starting Attract Mode
06:04:20.0 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe umk3r11 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
06:04:21.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:04:22.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:04:23.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:04:24.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:04:25.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:04:38.2 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
06:14:44.6 12/22/2006: Starting Attract Mode
06:14:44.8 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe growl -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
06:14:45.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:14:46.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:14:47.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:14:48.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:14:49.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:15:02.0 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
06:25:09.4 12/22/2006: Starting Attract Mode
06:25:09.6 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe shocktro -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
06:25:10.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:25:11.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:25:12.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:25:13.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:25:14.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:25:30.3 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
06:35:36.7 12/22/2006: Starting Attract Mode
06:35:37.4 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe ikari -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
06:35:38.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:35:39.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:35:40.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:35:41.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:35:42.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:35:54.6 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
06:46:01.1 12/22/2006: Starting Attract Mode
06:46:01.3 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe hustlerb -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
06:46:01.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:46:02.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:46:03.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:46:05.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:46:06.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:46:19.2 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
06:56:25.9 12/22/2006: Starting Attract Mode
06:56:26.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe terracre -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
06:56:26.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:56:28.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:56:29.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:56:30.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:56:31.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
06:57:12.4 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
07:07:19.0 12/22/2006: Starting Attract Mode
07:07:19.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe regulus -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
07:07:20.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:07:21.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:07:22.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:07:23.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:07:24.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:07:36.4 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
07:17:42.8 12/22/2006: Starting Attract Mode
07:17:43.0 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe digdug2o -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
07:17:43.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:17:44.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:17:45.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:17:46.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:17:47.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:18:00.5 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
07:28:07.0 12/22/2006: Starting Attract Mode
07:28:07.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe solarwar -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
07:28:08.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:28:08.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:28:09.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:28:10.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:28:12.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:29:03.1 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
07:39:10.0 12/22/2006: Starting Attract Mode
07:39:10.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe superchs -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
07:39:10.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:39:11.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:39:12.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:39:13.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:39:14.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:39:27.5 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
07:49:34.0 12/22/2006: Starting Attract Mode
07:49:34.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe viper -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
07:49:35.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:49:35.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:49:36.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:49:37.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:49:38.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:49:51.2 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
07:59:57.5 12/22/2006: Starting Attract Mode
07:59:57.7 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe hthero95 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
07:59:58.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
07:59:59.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:00:00.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:00:02.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:00:03.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:00:16.4 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
08:10:23.2 12/22/2006: Starting Attract Mode
08:10:23.5 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe drmicro -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
08:10:24.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:10:25.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:10:26.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:10:27.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:10:28.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:11:13.2 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
08:21:20.0 12/22/2006: Starting Attract Mode
08:21:20.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe gwarrior -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
08:21:20.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:21:21.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:21:22.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:21:23.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:21:24.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:21:38.1 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
08:31:44.5 12/22/2006: Starting Attract Mode
08:31:44.7 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe spool3 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
08:31:45.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:31:46.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:31:47.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:31:48.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:31:49.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:32:02.5 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
08:42:10.0 12/22/2006: Starting Attract Mode
08:42:10.3 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe trackfld -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
08:42:11.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:42:12.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:42:12.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:42:13.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:42:15.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:42:53.5 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
08:53:00.2 12/22/2006: Starting Attract Mode
08:53:00.4 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe legend -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
08:53:01.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:53:01.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:53:02.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:53:03.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:53:04.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
08:53:44.2 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
09:03:51.0 12/22/2006: Starting Attract Mode
09:03:51.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe gberet -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
09:03:52.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:03:53.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:03:54.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:03:55.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:03:57.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:04:09.9 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
09:14:17.1 12/22/2006: Starting Attract Mode
09:14:17.3 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe spacbatt -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
09:14:19.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:14:20.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:14:20.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:14:21.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:14:22.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:14:35.3 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
09:24:49.7 12/22/2006: Starting Attract Mode
09:24:49.9 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe hangonjr -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
09:24:50.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:24:51.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:24:52.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:24:53.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:24:54.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:25:30.3 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
09:35:37.0 12/22/2006: Starting Attract Mode
09:35:37.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe lifefrce -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
09:35:38.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:35:39.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:35:41.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:35:42.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:35:43.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:35:57.7 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
09:46:06.4 12/22/2006: Starting Attract Mode
09:46:06.6 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe ccboot -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
09:46:07.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:46:08.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:46:09.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:46:10.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:46:11.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:46:24.6 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
09:56:34.0 12/22/2006: Starting Attract Mode
09:56:34.3 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe victroad -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
09:56:35.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:56:36.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:56:36.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:56:37.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:56:38.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
09:56:50.7 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
10:06:57.0 12/22/2006: Starting Attract Mode
10:06:57.2 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe zerowing -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
10:06:57.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:06:58.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:06:59.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:07:00.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:07:01.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:07:15.2 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
10:17:21.4 12/22/2006: Starting Attract Mode
10:17:21.6 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe cavenger -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
10:17:22.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:17:23.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:17:24.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:17:25.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:17:26.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:17:38.0 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
10:27:44.3 12/22/2006: Starting Attract Mode
10:27:44.5 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe sunaq -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
10:27:45.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:27:46.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:27:47.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:27:48.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:27:49.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:28:01.0 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
10:38:07.3 12/22/2006: Starting Attract Mode
10:38:07.5 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe aliensy3 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
10:38:08.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:38:09.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:38:10.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:38:10.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:38:11.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:38:23.8 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
10:48:30.1 12/22/2006: Starting Attract Mode
10:48:30.3 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe blazstar -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
10:48:31.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:48:32.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:48:32.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:48:33.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:48:34.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:48:52.4 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
10:58:58.8 12/22/2006: Starting Attract Mode
10:58:59.0 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe sliksh16 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
10:58:59.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:59:00.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:59:01.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:59:01.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:59:03.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
10:59:15.0 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
11:09:21.3 12/22/2006: Starting Attract Mode
11:09:21.6 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe kangaroo -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
11:09:22.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:09:23.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:09:24.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:09:24.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:09:25.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:09:37.8 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
11:19:44.3 12/22/2006: Starting Attract Mode
11:19:44.5 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe arbalest -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
11:19:45.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:19:46.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:19:46.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:19:47.5 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:19:48.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:20:00.9 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
11:30:07.2 12/22/2006: Starting Attract Mode
11:30:07.4 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe vulgus2 -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32 -bezel -artwork_directory artwork
11:30:08.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:30:09.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:30:10.0 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:30:10.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:30:11.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:30:23.4 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
11:40:29.8 12/22/2006: Starting Attract Mode
11:40:30.0 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe rdaction -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
11:40:30.8 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:40:31.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:40:32.6 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:40:33.4 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:40:34.1 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:40:46.1 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
11:50:52.5 12/22/2006: Starting Attract Mode
11:50:52.7 12/22/2006: Running: cmd.exe /c L: L:\mame\mame.exe kikstart -rompath L:\extras\roms -triplebuffer -nowindow -joy -video d3d -noswitchres -volume -32
11:50:53.3 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:50:54.2 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:50:54.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:50:55.9 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:50:56.7 12/22/2006: Key/Joy press detected: Exiting Attract mode: 78:120
11:51:08.7 12/22/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
11:52:04.0 12/22/2006: Exiting GameEx!
11:52:04.1 12/22/2006: Saving Settings
11:52:12.2 12/22/2006: Disposing Plugins
11:52:12.2 12/22/2006: Checking for applications to Launch On Exit
I also watched my Memory widget (as per Kaze's suggestion) and my RAM is only running at about 50%. I'm nowhere near full capacity so that eliminates that problem.
The only emulator that has been changed / added since I started having the .NET issues was MUGEN, and I just added that yesterday (a week and a half after the problem started happening).
Hope that's enough info. If you need anythinr more let me know.
Ive actually had this same problem. It seems random. Only has happened a couple of times. Hasn't been that big of an issue. I do notice when starting Killer Instict and going straight into the input test menu. Player 2 Roundhouse kick is pressed several times in a row. Only for a few seconds. I doubt it has any relation but very weird. Ive even unpluged the switch on my cabinet cause I thought it was faulty.
Yeah occationally GameEx jumps out of Attract mode for me too. It's quite rare, but if I'm just leaving it running in Attract mode I can often walk past my cab and it's back on the menu.
This "keypress detected" error is driving me bananas! What the heck button is being pressed? I tried everything - even disabled my keyboard. I don't know what else to try. :(
Download my KeyCodes util and run it in the background. Then at least you can find out what the last key pressed is. Is this key mapped to your IPAC?
Perhaps then you can unplug your keyboard to see if it's registering the key from that, then try unplugging your IPAC and see if you get the same thing. Problem solving is a matter of elimination.
Finally if you have a wireless keyboard I would be highly suspicious of interference. I have a wireless mouse and when I am copying data over my 802.11g wireless network the mouse is unusable!
I do have a wireless keyboard actually. It was easier to mount in the cab that way. Never would have even thought of that! Went to a wired one... problem solved! Crazy!!
Much appreciated Kaze. Happy holidays bud. :)
Yeah, wireless kb's are nice but they always seem to cause more problems than they're worth. I've got a wireless kb/mouse combo that I use for my Media Center. When I first started setting up GameEx I was having a problem with it. It would be detecting keypresses when I wasn't even using it. Interesting thing for me, was that the keypress was the DOWN arrow key! I couldn't use the menu system of GameEx because it wouldn't stop moving before I could select the game. Hehe. I took the kb back because it was cheap $20 generic "wannabe". I ended up buying a super expensive $120 set and haven't had a problem since. So it all kinda depends on the quality of the device I guess. The 1st one I bought was a line of sight infrared that only worked when you had the thing pointing right at the receiver. What sucked about it was if you had a key pressed then moved the kb out of linesight, the receiver never gets the "release" command from the kb and assumes it's "still on". This new one I've had since is RF (radio frequency) and works great. If you decide to go back to wireless, for whatever reason, be a little investigative on the functionality and receiver end. RF is way better than infrared in this case. Remote controls are probably the same (better in rf than ir).
Team:
I am having a similiar issue here with the attract mode. Basically it will load be on the screen for 1-2 minutes and exit back to the original menu that it was on before going to attract. I have the Microsoft Sam voice on and he comes on saying "welcome back.." as if I have chosen to come back to the menu. In trying to deduce this I have tried all the methods mentioned above plus the following:
-Unplugged both I-pacs and ran screen saver
-Replaced wireless keyboard with wired
-Ran Key tracer from above
-Checked all wored leads from Ipcas
Not to draw conjecture but it seems with the last release there are allot of issues with this, games exiting, and "key mashing" lock ups..I wonder if there is any link between these or they are all independent. I have attachyed my log any help would be appreciated as I leave my cab up 24X7 and this is my screen saver :mellow: .
Regards,
CP
LOG:
22:48:17.2 12/29/2006: GameEx: Version 7.09: Starting Log
22:48:17.2 12/29/2006: Operating System Platform: Win32NT
22:48:17.2 12/29/2006: Operating System Name: Windows XP
22:48:17.2 12/29/2006: Operating System Version: 5.1.2600
22:48:17.2 12/29/2006: Checking for versions of .net Framework installed
22:48:17.2 12/29/2006: .net Framework 1.0 Installed
22:48:17.2 12/29/2006: .net Framework 1.1 Installed
22:48:17.2 12/29/2006: .net Framework 2.0 Installed
22:48:17.2 12/29/2006: Intel® Pentium® 4 CPU 2.80GHz
22:48:17.2 12/29/2006: 2.8Ghz - 2 Cores or CPU's
22:48:17.2 12/29/2006: Running Randomize()
22:48:17.2 12/29/2006: Loading PlugIns
22:48:17.3 12/29/2006: Loaded Plugin:"Dig Dug" Version 1.0 By Tom Speirs
22:48:17.6 12/29/2006: PlugIn: "Dig Dug" Initialized OK
22:48:17.6 12/29/2006: Loaded Plugin:"Exit GameEx" Version 1.0 By Ben Baker
22:48:17.8 12/29/2006: PlugIn: "Exit GameEx" Initialized OK
22:48:17.8 12/29/2006: Loaded Plugin:"Speak Game Name" Version 1.3 By Tom Speirs
22:48:17.8 12/29/2006: PlugIn: "Speak Game Name" Initialized OK
22:48:17.9 12/29/2006: Checking for applications to Launch On Startup
22:48:17.9 12/29/2006: Initialising Video/MNG DLL's
22:48:17.9 12/29/2006: Running Misc startup tasks
22:48:17.9 12/29/2006: Setting Menu types
22:48:17.9 12/29/2006: Opening Configuration File
22:48:17.9 12/29/2006: Getting Configuration Values
22:48:17.9 12/29/2006: Using Theme: Default - Valhalla Default 1024x768
22:48:17.9 12/29/2006: Checking for alternate Image Directory for Theme: Default - Valhalla Default 1024x768
22:48:17.9 12/29/2006: Launching HideOS.exe
22:48:17.9 12/29/2006: Hiding Taskbar
22:48:17.9 12/29/2006: Using Cabinet Friendly Control System
22:48:17.9 12/29/2006: Is Media Center running?
22:48:17.9 12/29/2006: Checking/Creating LCD Registry values
22:48:17.9 12/29/2006: Check Media Center Exit/Start Mode
22:48:17.9 12/29/2006: Media Center Mode 0
22:48:17.9 12/29/2006: Text/Language: English
22:48:17.9 12/29/2006: Applying Language/Text
22:48:18.0 12/29/2006: Snap Delay set to: 6
22:48:18.0 12/29/2006: Get other settings
22:48:18.1 12/29/2006: Desktop set to Hide ICONS and set Background to Black
22:48:18.1 12/29/2006: Backing up Registry Wallpaper Settings
22:48:18.1 12/29/2006: SlikStik support enabled
22:48:18.1 12/29/2006: Using DirectInput for keyboard input
22:48:18.1 12/29/2006: Start work for Form
22:48:18.1 12/29/2006: Getting Original Screen Size
22:48:18.1 12/29/2006: Loading ICON
22:48:18.1 12/29/2006: Initializing Component
22:48:18.1 12/29/2006: Initialising Bass Audio Library
22:48:18.1 12/29/2006: Loading default loading screen
22:48:18.2 12/29/2006: Loading Custom Emulators
22:48:18.2 12/29/2006: Loading Emulator 1: MAME MisFit
22:48:18.2 12/29/2006: Loading Emulator 2: Nintendo SNES
22:48:18.2 12/29/2006: Loading Emulator 4: Nintendo NES
22:48:18.3 12/29/2006: Loading Emulator 5: Atari 2600
22:48:18.3 12/29/2006: Loading Emulator 6: Coleco Vision
22:48:18.3 12/29/2006: Loading Emulator 7: Sega Genesis
22:48:18.4 12/29/2006: Loading Emulator 8: Intellivision Games
22:48:18.4 12/29/2006: Loading Emulator 10: Nintendo 64
22:48:18.5 12/29/2006: Loading Emulator 11: Atari 7800
22:48:18.5 12/29/2006: Loading Emulator 12: NEC TurboGrafx 16
22:48:18.6 12/29/2006: Using 3D Alpha Blended Animations. This could be slow
22:48:18.6 12/29/2006: Using General Font: Trebuchet MS
22:48:18.6 12/29/2006: Using Title Font: Trebuchet MS
22:48:18.6 12/29/2006: Starting GameExtender on: 192.168.1.102:8383
22:48:18.6 12/29/2006: Initialising DirectDraw
22:48:20.6 12/29/2006: Creating DirectDraw Device
22:48:20.6 12/29/2006: Using Device: Ultimarc ArcadeVGA2
22:48:20.7 12/29/2006: Setting Resolution to 800x600 32 bit color
22:48:20.7 12/29/2006: Creating DirectDraw Surfaces
22:48:20.7 12/29/2006: Creating Primary Surface - Full Screen Mode
22:48:20.8 12/29/2006: Creating Back Buffer
22:48:20.8 12/29/2006: Version 2 Theme being used. Loading.
22:48:20.8 12/29/2006: Loading Button Data
22:48:20.8 12/29/2006: Loading Font Data
22:48:20.8 12/29/2006: Loading Layout Data
22:48:20.8 12/29/2006: Loading Taskbar Data
22:48:20.8 12/29/2006: Loading graphic surfaces
22:48:20.8 12/29/2006: Creating Surfaces Misc and Dialogs
22:48:20.8 12/29/2006: Creating Surface Volume
22:48:20.9 12/29/2006: Creating Surfaces Arrows
22:48:20.9 12/29/2006: Creating Surfaces GameEXlogo Text
22:48:20.9 12/29/2006: Creating Surfaces Toolbar
22:48:20.9 12/29/2006: Creating Surfaces Backgrounds
22:48:21.0 12/29/2006: Creating Surfaces Toolbar Controls
22:48:21.0 12/29/2006: Creating Surfaces GameEx Logo
22:48:21.0 12/29/2006: Creating Surfaces Home & Exit
22:48:21.0 12/29/2006: Creating Surfaces Snaps
22:48:21.0 12/29/2006: Creating Surfaces Menu and List Bars
22:48:21.1 12/29/2006: Creating Fonts
22:48:21.1 12/29/2006: Creating Menu Font
22:48:21.2 12/29/2006: Creating Game Font
22:48:21.3 12/29/2006: Creating Font Black
22:48:21.4 12/29/2006: Creating Font Black Small
22:48:21.5 12/29/2006: Creating Game Font Faded
22:48:21.5 12/29/2006: Creating Title Font
22:48:21.5 12/29/2006: Restoring Title Font From Cache
22:48:21.6 12/29/2006: Fonts Created Succesfully
22:48:21.6 12/29/2006: Creating Radio Station Genres
22:48:21.7 12/29/2006: Succesfully created station genres
22:48:21.7 12/29/2006: MAME Path is: D:\mame 1.00\Mame 100.4\Mame32
22:48:21.7 12/29/2006: daphne Path is: C:\Daphne
22:48:21.7 12/29/2006: daphne EXE file is: Daphne.exe
22:48:21.7 12/29/2006: Use daphne on. Daphne.exe will launch games
22:48:21.7 12/29/2006: Model 2 Path Path is: C:\Model2v0.1\autorun
22:48:21.7 12/29/2006: Model 2 EXE file is: emulator.exe
22:48:21.7 12/29/2006: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
22:48:21.7 12/29/2006: ZiNc Path is: C:\Zinc_v1.1
22:48:21.7 12/29/2006: ZiNc EXE file is: ZiNc.exe
22:48:21.7 12/29/2006: Use ZiNc on. ZiNc.exe will launch PSX games
22:48:21.7 12/29/2006: MAME EXE file is: Mame32.exe
22:48:21.7 12/29/2006: ROM Path is: D:\mame 1.00\Mame 100.4\Mame32\roms
22:48:21.7 12/29/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
22:48:21.7 12/29/2006: controls.ini is located at: D:\mame 1.00\Mame 100.4\Mame32\controls.ini
22:48:21.7 12/29/2006: History.dat is located at: D:\mame 1.00\Mame 100.4\Mame32\history.dat
22:48:21.7 12/29/2006: nplayers.ini is located at: D:\mame 1.00\Mame 100.4\Mame32\nplayers32.txt
22:48:21.7 12/29/2006: MAMEinfo.dat is located at: D:\mame 1.00\Mame 100.4\Mame32\mameinfo.dat
22:48:21.7 12/29/2006: Loading Controls.ini map file
22:48:21.7 12/29/2006: Snap Path is: D:\mame 1.00\Mame 100.4\Mame32\snap
22:48:21.7 12/29/2006: AVI Snap Path is: D:\mame 1.00\Mame 100.4\Mame32\video
22:48:21.7 12/29/2006: Flyer Path is: D:\mame 1.00\Mame 100.4\Mame32\flyers
22:48:21.7 12/29/2006: Cabinet Path is: D:\mame 1.00\Mame 100.4\Mame32\cabinets
22:48:21.7 12/29/2006: Title Path is: D:\mame 1.00\Mame 100.4\Mame32\titles
22:48:21.7 12/29/2006: Panel Path is: D:\mame 1.00\Mame 100.4\Mame32\cpanel
22:48:21.7 12/29/2006: Icon Path is: D:\mame 1.00\Mame 100.4\Mame32\icons
22:48:21.7 12/29/2006: Marquee Path is: D:\mame 1.00\Mame 100.4\Mame32\marquees
22:48:21.7 12/29/2006: MAME CMD options: -nowindow -joy
22:48:21.7 12/29/2006: Attempting to load game list
22:48:21.8 12/29/2006: Loading last used Game List
22:48:21.8 12/29/2006: Setting Music Volume
22:48:21.8 12/29/2006: Loading music on thread
22:48:21.9 12/29/2006: Creating DirectSound Device
22:48:21.9 12/29/2006: Trying: Primary Sound Driver
22:48:21.9 12/29/2006: Loading Sound Files
22:48:21.9 12/29/2006: DirectSound Device Created Successfully
22:48:21.9 12/29/2006: Creating ICONS
22:48:22.0 12/29/2006: Restoring Cached ICONS from File
22:48:22.1 12/29/2006: Initialising DirectInput for Gamepad support
22:48:22.1 12/29/2006: Looking for Device: Adaptoid
22:48:22.2 12/29/2006: Device Created
22:48:22.2 12/29/2006: Initialising DirectInput for Keyboard support
22:48:22.3 12/29/2006: Playing Startup Video
22:48:53.5 12/29/2006: Playing intro sound file
22:48:53.5 12/29/2006: Initializing MCE Remote
22:48:53.5 12/29/2006: Initialization OK! Starting GameEx!
22:48:53.5 12/29/2006: Testing Main Loop Once: Processing Frame
22:48:53.8 12/29/2006: Testing Main Loop Once: Main Loop ran successfully
22:49:05.6 12/29/2006: Starting Attract Mode
22:49:05.9 12/29/2006: Running: cmd.exe /c D: D:\mame 1.00\Mame 100.4\Mame32\Mame32.exe mouser -rompath D:\mame 1.00\Mame 100.4\Mame32\roms -nowindow -joy -artwork -artwork_directory artwork
22:49:06.6 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:49:07.2 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:49:07.9 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:49:08.6 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:49:09.2 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:49:21.2 12/29/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
22:49:47.7 12/29/2006: Validating: Emulator_1: Custom Background: D:\mame 1.00\Misfitmame\MisfitMame32\snap
22:49:47.7 12/29/2006: Validating: Emulator_1: Snap Path: D:\mame 1.00\Misfitmame\MisfitMame32\snap
22:49:47.7 12/29/2006: Validating: Emulator_1: Database:
22:49:47.7 12/29/2006: Warning: Emulator_1: Database Does not exist
22:49:47.7 12/29/2006: Validating: Emulator_1: Title Snap Path: D:\mame 1.00\Misfitmame\MisfitMame32\titles
22:49:47.7 12/29/2006: Validating: Emulator_1: Box Art Path:
22:49:47.7 12/29/2006: Warning: Emulator_1: Box Art Path Does not exist
22:49:47.7 12/29/2006: Validating: Emulator_1: Cart Art Path:
22:49:47.7 12/29/2006: Warning: Emulator_1: Cart Art Path Does not exist
22:49:47.7 12/29/2006: Validating: Emulator_2: Custom Background: C:\Arcade Machine\Console\Nintendo SNES\new
22:49:47.7 12/29/2006: Validating: Emulator_2: Snap Path: C:\Arcade Machine\Console\Nintendo SNES\new
22:49:47.7 12/29/2006: Validating: Emulator_2: Database: SNES
22:49:47.7 12/29/2006: Validating: Emulator_2: Title Snap Path: C:\Arcade Machine\Console\Nintendo SNES\new
22:49:47.7 12/29/2006: Validating: Emulator_2: Box Art Path: G:\zsnes\Boxscans_SNES_(USA)_28May04
22:49:47.7 12/29/2006: Warning: Emulator_2: Box Art Path Does not exist
22:49:47.7 12/29/2006: Validating: Emulator_2: Cart Art Path: G:\zsnes\CartScans SNES USA
22:49:47.7 12/29/2006: Warning: Emulator_2: Cart Art Path Does not exist
22:49:47.7 12/29/2006: Validating: Emulator_4: Custom Background: C:\Arcade Machine\Console\Nintendo NES\snaps\EmuMovies NES AVI Game Title Sequences
22:49:47.7 12/29/2006: Validating: Emulator_4: Snap Path: C:\Arcade Machine\Console\Nintendo NES\snaps\EmuMovies NES AVI Game Title Sequences
22:49:47.7 12/29/2006: Validating: Emulator_4: Database: NES
22:49:47.7 12/29/2006: Validating: Emulator_4: Title Snap Path: C:\Arcade Machine\Console\Nintendo NES\USA\titles
22:49:47.7 12/29/2006: Validating: Emulator_4: Box Art Path:
22:49:47.7 12/29/2006: Warning: Emulator_4: Box Art Path Does not exist
22:49:47.7 12/29/2006: Validating: Emulator_4: Cart Art Path:
22:49:47.7 12/29/2006: Warning: Emulator_4: Cart Art Path Does not exist
22:49:47.7 12/29/2006: Validating: Emulator_5: Custom Background: C:\Arcade Machine\Console\Atari 2600\Atari 2600 - snap
22:49:47.7 12/29/2006: Validating: Emulator_5: Snap Path: C:\Arcade Machine\Console\Atari 2600\Atari 2600 - snap
22:49:47.7 12/29/2006: Validating: Emulator_5: Database: ATARI2600
22:49:47.7 12/29/2006: Validating: Emulator_5: Title Snap Path: C:\Arcade Machine\Console\Atari 2600\Atari 2600 - snap
22:49:47.7 12/29/2006: Validating: Emulator_5: Box Art Path: C:\Arcade Machine\Console\Atari 2600\boxes
22:49:47.7 12/29/2006: Validating: Emulator_5: Cart Art Path: C:\Arcade Machine\Console\Atari 2600\cartridges\Good2600 - 0.999.9 Atari 2600 - cartridge
22:49:47.8 12/29/2006: Validating: Emulator_6: Custom Background: C:\Arcade Machine\Console\Colecovision\snap\Colico Vision Art\snap
22:49:47.8 12/29/2006: Warning: Emulator_6: Custom Background Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_6: Snap Path: C:\Arcade Machine\Console\Colecovision\snap\Colico Vision Art\snap
22:49:47.8 12/29/2006: Validating: Emulator_6: Database: COLECOVISION
22:49:47.8 12/29/2006: Validating: Emulator_6: Title Snap Path: C:\Arcade Machine\Console\Colecovision\snap\Colico Vision Art\tittle
22:49:47.8 12/29/2006: Validating: Emulator_6: Box Art Path:
22:49:47.8 12/29/2006: Warning: Emulator_6: Box Art Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_6: Cart Art Path:
22:49:47.8 12/29/2006: Warning: Emulator_6: Cart Art Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_7: Custom Background:
22:49:47.8 12/29/2006: Validating: Emulator_7: Snap Path:
22:49:47.8 12/29/2006: Warning: Emulator_7: Snap Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_7: Database: GENESIS
22:49:47.8 12/29/2006: Validating: Emulator_7: Title Snap Path:
22:49:47.8 12/29/2006: Warning: Emulator_7: Title Snap Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_7: Box Art Path:
22:49:47.8 12/29/2006: Warning: Emulator_7: Box Art Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_7: Cart Art Path:
22:49:47.8 12/29/2006: Warning: Emulator_7: Cart Art Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_8: Custom Background: C:\Arcade Machine\Console\Mattel Intellivision\snap
22:49:47.8 12/29/2006: Validating: Emulator_8: Snap Path: C:\Arcade Machine\Console\Mattel Intellivision\snap
22:49:47.8 12/29/2006: Validating: Emulator_8: Database: INTELLIVISION
22:49:47.8 12/29/2006: Validating: Emulator_8: Title Snap Path: g:\Offlinelist\imgs\int\titles
22:49:47.8 12/29/2006: Warning: Emulator_8: Title Snap Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_8: Box Art Path: C:\Arcade Machine\Console\Mattel Intellivision\Nostalgia\images
22:49:47.8 12/29/2006: Validating: Emulator_8: Cart Art Path:
22:49:47.8 12/29/2006: Warning: Emulator_8: Cart Art Path Does not exist
22:49:47.8 12/29/2006: Validating: Emulator_10: Custom Background: D:\N64
22:49:47.8 12/29/2006: Validating: Emulator_10: Snap Path: D:\N64
22:49:47.8 12/29/2006: Validating: Emulator_10: Database: N64
22:49:47.8 12/29/2006: Validating: Emulator_10: Title Snap Path: D:\N64\snap
22:49:47.9 12/29/2006: Warning: Emulator_10: Title Snap Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_10: Box Art Path: G:\zsnes\Boxscans_SNES_(USA)_28May04
22:49:47.9 12/29/2006: Warning: Emulator_10: Box Art Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_10: Cart Art Path: G:\zsnes\CartScans SNES USA
22:49:47.9 12/29/2006: Warning: Emulator_10: Cart Art Path Does not exist
22:49:47.9 12/29/2006: Warning: Emulator_10: MAPFile Does Not Exist
22:49:47.9 12/29/2006: Loading OfflineList Dat File for emulator: 10
22:49:47.9 12/29/2006: Cannot Find Offline List Dat File
22:49:47.9 12/29/2006: Validating: Emulator_11: Custom Background: E:\Graphic's\Snaps\Atari 7800
22:49:47.9 12/29/2006: Validating: Emulator_11: Snap Path: E:\Graphic's\Snaps\Atari 7800
22:49:47.9 12/29/2006: Warning: Emulator_11: Snap Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_11: Database: ATARI7800
22:49:47.9 12/29/2006: Validating: Emulator_11: Title Snap Path: E:\Graphic's\Titles\Atari 7800
22:49:47.9 12/29/2006: Warning: Emulator_11: Title Snap Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_11: Box Art Path: E:\Graphic's\Box\Atari 7800
22:49:47.9 12/29/2006: Warning: Emulator_11: Box Art Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_11: Cart Art Path: E:\Graphic's\Cartridge\Atari 7800
22:49:47.9 12/29/2006: Warning: Emulator_11: Cart Art Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_12: Custom Background: E:\Graphic's\Snaps\NEC TurboGrafx 16
22:49:47.9 12/29/2006: Validating: Emulator_12: Snap Path: E:\Graphic's\Snaps\NEC TurboGrafx 16
22:49:47.9 12/29/2006: Warning: Emulator_12: Snap Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_12: Database:
22:49:47.9 12/29/2006: Warning: Emulator_12: Database Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_12: Title Snap Path: E:\Graphic's\Titles\NEC TurboGrafx 16
22:49:47.9 12/29/2006: Warning: Emulator_12: Title Snap Path Does not exist
22:49:47.9 12/29/2006: Validating: Emulator_12: Box Art Path: E:\Graphic's\Box\NEC TurboGrafx 16
22:49:48.0 12/29/2006: Warning: Emulator_12: Box Art Path Does not exist
22:49:48.0 12/29/2006: Validating: Emulator_12: Cart Art Path: E:\Graphic's\Cartridge\NEC TurboGrafx 16
22:49:48.0 12/29/2006: Warning: Emulator_12: Cart Art Path Does not exist
22:50:05.6 12/29/2006: Restoring Emulator Database From Cache
22:50:12.3 12/29/2006: Restoring Emulator from Cache
22:50:12.4 12/29/2006: Restoring Emulator Database From Cache
22:50:21.2 12/29/2006: Restoring Emulator Database From Cache
22:50:26.6 12/29/2006: Restoring Emulator Database From Cache
22:50:30.4 12/29/2006: Restoring Emulator from Cache
22:50:30.4 12/29/2006: Restoring Emulator Database From Cache
22:52:21.1 12/29/2006: Restoring Emulator from Cache
22:52:24.7 12/29/2006: Restoring Emulator from Cache
22:53:19.3 12/29/2006: Starting Attract Mode
22:53:19.5 12/29/2006: Running: cmd.exe /c D: D:\mame 1.00\Mame 100.4\Mame32\Mame32.exe puyopuy2 -rompath D:\mame 1.00\Mame 100.4\Mame32\roms -nowindow -joy
22:53:20.1 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:53:20.9 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:53:21.5 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:53:22.2 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:53:22.9 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:53:34.9 12/29/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
22:54:37.1 12/29/2006: Starting Attract Mode
22:54:37.3 12/29/2006: Running: cmd.exe /c D: D:\mame 1.00\Mame 100.4\Mame32\Mame32.exe sdodgeb -rompath D:\mame 1.00\Mame 100.4\Mame32\roms -nowindow -joy
22:54:38.1 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:54:38.8 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:54:39.5 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:54:40.2 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:54:40.8 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:54:52.9 12/29/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
22:56:08.2 12/29/2006: Starting Attract Mode
22:56:08.4 12/29/2006: Running: cmd.exe /c D: D:\mame 1.00\Mame 100.4\Mame32\Mame32.exe trog -rompath D:\mame 1.00\Mame 100.4\Mame32\roms -nowindow -joy
22:56:09.0 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:56:09.7 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:56:10.4 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:56:11.1 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:56:11.7 12/29/2006: Key/Joy press detected: Exiting Attract mode: 4:4
22:56:24.0 12/29/2006: Key/Joy press detected: Exiting Attract mode, closing MAME
22:57:44.3 12/29/2006: Exiting GameEx!
22:57:44.3 12/29/2006: Saving Settings
22:57:57.8 12/29/2006: Disposing Plugins
22:57:57.8 12/29/2006: Checking for applications to Launch On Exit
I'm sure you read my thread through before posting, but for me it was some sort of interferance (sp?) between my wireless keyboard. Are you using anything wireless? ie network card?
I have a wireless bridge that talks to the rest of my netowrk. Why would this go haywire with this release only? It seems that something changed that started to cause these issues.
CP
I would have to agree, since I never had this issue before I updated to 7.09
But I'm no programmer so IDK for sure. *shrugs*
I have looked at this and cant see anything. This issue has come up in the post prior to this version, and GameEx does nothing like create wireless signals or anything crazy like that. If you search the forum yourll see its not a new issue. I am sorry I cant help more, but I can tell you these kind of issues are a lot less prevelant than they were. Basically Windows (not GameEx) thinks theres a key pressed. Im not sure what virtual key code 4 is, it may be something weird like F-Lock, I dont know. Maybe MAME is turning on LEDs or something similar perhaps?
Tom.
The issue is that wireless traffic interferes with wireless mouse and keyboards. I've seen it happen with my mouse during copying, basically it becomes unusable. So it's not really a GameEx issue at all, it's the fact that wireless devices are effected by 802.11x traffic and then GameEx is told there is a keypress or mouse movement.
Any way to set up GameEx so a specific key has to be pressed to exit attract mode? Not sure if it's even doable per se... Just thought it was a good idea for those of us who can't afford the Bluetooth technology. *shrugs*
I am OK with another wire in the cab, just was curious.
