Help! I updated to MAME 0.111 and for some reason I'm getting framework errors. Not sure if the two incidents are related. Any help would be great. :)
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: Unable to enumerate the process modules.
at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId)
at System.Diagnostics.Process.get_Modules()
at System.Diagnostics.Process.get_MainModule()
at System.Diagnostics.Process.get_ProcessName()
at GameEx.GameEx.mainform.RunScreenSaver(Boolean OverrideTimer)
at GameEx.GameEx.mainform.ScreenSaver_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
GameEx
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/GameEx/GameEx.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Microsoft.DirectX.DirectDraw
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.directdraw/1.0.2902.0__31bf3856ad364e35/microsoft.directx.directdraw.dll
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
Avi
Assembly Version: 1.0.2360.19080
Win32 Version: 1.0.2360.19080
CodeBase: file:///C:/Program%20Files/GameEx/Avi.DLL
Microsoft.DirectX.DirectInput
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.directinput/1.0.2902.0__31bf3856ad364e35/microsoft.directx.directinput.dll
Microsoft.DirectX.DirectSound
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.directsound/1.0.2902.0__31bf3856ad364e35/microsoft.directx.directsound.dll
ArtDownloader
Assembly Version: 1.0.2256.14300
Win32 Version: 1.0.2256.14300
CodeBase: file:///C:/Program%20Files/GameEx/ArtDownloader.DLL
Interop.WMPLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/GameEx/Interop.WMPLib.DLL
Microsoft.DirectX.AudioVideoPlayback
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.audiovideoplayback/1.0.2902.0__31bf3856ad364e35/microsoft.directx.audiovideoplayback.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/GameEx/AxInterop.SHDocVw.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
AxInterop.WMPLib
CodeBase: file:///C:/Program%20Files/GameEx/AxInterop.WMPLib.DLL
Microsoft.DirectX
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx/1.0.2902.0__31bf3856ad364e35/microsoft.directx.dll
Zip
Assembly Version: 0.9.0.1215
Win32 Version: 0.9.0.1215
CodeBase: file:///C:/Program%20Files/GameEx/Zip.DLL
Interop.AVGAComObj
CodeBase: file:///C:/Program%20Files/GameEx/Interop.AVGAComObj.DLL
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
