Hi all, thanks in advance.
Registered version of gameex. Win XP sp2 up to date patch-wise.
Any time I open an emulator other than mame32, game ex will switch resolutions and go to it fine. When I exit the game, gameex returns as it should. When I try to play a second game, however, either in the same emulator or in another, Gameex goes to a black screen, flickers a few times, and then returns to gameex window. If I shut down gameex and reopen it, I still cannot open a game. Essentially, I am limited to opening one game through gameex before I have to reboot.
I'm using an Nvidea graphics card hooked up to a television. When I have the computer hooked up to a regular monitor, this problem ceases.
Has anyone had a similar problem? And if so, any solutions or ideas on where to start? I would hate to have to return to mamewah simply due to this reason (especially after paying the fee).
Thanks again.
Can you post you log file?
START -> All Programs -> GameEx -> Log File
Here's the log file you requested. Hope it makes more sense to you than it does to me. In this instance, I started contra, played for a second or two. quit. tried to start it again, but it wouldn't load. I then selected a sega game which also wouldn't load. I know the paths are correct, because gameex will boot these same games the first time I select them every time. It's when I exit out and return they won't load. Also, this only happens when I have the comp hooked up to my tv. Since it's running in a cab, this is important to me. It seems like it may have trouble switching resolutions or something (flickers and then goes black, then returns to gameex)
Thanks again,
01:00:58.4 12/15/2006: GameEx: Version 7.09: Starting Log
01:00:58.4 12/15/2006: Operating System Platform: Win32NT
01:00:58.4 12/15/2006: Operating System Name: Windows XP
01:00:58.4 12/15/2006: Operating System Version: 5.1.2600
01:00:58.4 12/15/2006: Checking for versions of .net Framework installed
01:00:58.4 12/15/2006: .net Framework 1.1 Installed
01:00:58.4 12/15/2006: .net Framework 2.0 Installed
01:00:58.4 12/15/2006: Intel® Pentium® 4 CPU 2.00GHz
01:00:58.5 12/15/2006: 2Ghz
01:00:58.5 12/15/2006: Running Randomize()
01:00:58.5 12/15/2006: Loading PlugIns
01:00:58.5 12/15/2006: Checking for applications to Launch On Startup
01:00:58.5 12/15/2006: Initialising Video/MNG DLL's
01:00:58.5 12/15/2006: Running Misc startup tasks
01:00:58.5 12/15/2006: Setting Menu types
01:00:58.5 12/15/2006: Opening Configuration File
01:00:58.5 12/15/2006: Getting Configuration Values
01:00:58.5 12/15/2006: Using Theme: Default - GameEx - Animated
01:00:58.5 12/15/2006: Checking for alternate Image Directory for Theme: Default - GameEx - Animated
01:00:58.5 12/15/2006: Using Images from theme: Default - GameEx\MEDIA\
01:00:58.5 12/15/2006: Launching HideOS.exe
01:00:58.5 12/15/2006: Hiding Taskbar
01:00:58.5 12/15/2006: Is Media Center running?
01:00:58.6 12/15/2006: Checking/Creating LCD Registry values
01:00:58.6 12/15/2006: Check Media Center Exit/Start Mode
01:00:58.6 12/15/2006: Media Center Mode 2
01:00:58.7 12/15/2006: Text/Language: English
01:00:58.7 12/15/2006: Applying Language/Text
01:00:58.7 12/15/2006: Custom Keyboard Input enabled: Getting custom codes
01:00:58.7 12/15/2006: Snap Delay set to: 2
01:00:58.7 12/15/2006: Get other settings
01:00:58.7 12/15/2006: Mouse Input is disabled
01:00:58.8 12/15/2006: Desktop set to Hide ICONS and set Background to Black
01:00:58.8 12/15/2006: Backing up Registry Wallpaper Settings
01:00:58.8 12/15/2006: Set: Find emulator artwork on best match basis
01:00:58.8 12/15/2006: Using DirectInput for keyboard input
01:00:58.8 12/15/2006: Start work for Form
01:00:58.8 12/15/2006: Getting Original Screen Size
01:00:58.8 12/15/2006: Loading ICON
01:00:58.8 12/15/2006: Initializing Component
01:00:59.3 12/15/2006: Initialising Bass Audio Library
01:01:00.4 12/15/2006: Loading default loading screen
01:01:00.5 12/15/2006: Loading Custom Emulators
01:01:00.5 12/15/2006: Loading Emulator 1: Sega Genesis
01:01:00.6 12/15/2006: Loading Emulator 2: Super NES
01:01:00.7 12/15/2006: Loading Emulator 3: Nintendo NES
01:01:01.0 12/15/2006: Loading Emulator 5: Atari 2600
01:01:01.2 12/15/2006: Using 2D Animations
01:01:01.2 12/15/2006: Using Deadzone
01:01:01.2 12/15/2006: Using General Font: HandelGothic BT
01:01:01.2 12/15/2006: Using Title Font: HandelGothic BT
01:01:01.2 12/15/2006: Starting GameExtender Publisher
01:01:01.2 12/15/2006: Initialising DirectDraw
01:01:01.3 12/15/2006: Applying GameEx is Loading Image
01:01:02.2 12/15/2006: Creating DirectDraw Device
01:01:02.2 12/15/2006: Using Device: NVIDIA GeForce2 MX/MX 400
01:01:02.8 12/15/2006: Setting Resolution to 800x600 32 bit color
01:01:02.8 12/15/2006: Creating DirectDraw Surfaces
01:01:02.8 12/15/2006: Creating Primary Surface - Full Screen Mode
01:01:02.9 12/15/2006: Creating Back Buffer
01:01:03.3 12/15/2006: Loading graphic surfaces
01:01:03.7 12/15/2006: Creating Surfaces Misc and Dialogs
01:01:04.1 12/15/2006: Creating Surface Volume
01:01:04.1 12/15/2006: Creating Surfaces Arrows
01:01:04.1 12/15/2006: Creating Surfaces GameEXlogo Text
01:01:04.1 12/15/2006: Creating Surfaces Toolbar
01:01:04.2 12/15/2006: Creating Surfaces Backgrounds
01:01:05.2 12/15/2006: Creating Surfaces Toolbar Controls
01:01:05.3 12/15/2006: Creating Surfaces GameEx Logo
01:01:05.3 12/15/2006: Creating Surfaces Home & Exit
01:01:05.3 12/15/2006: Creating Surfaces Snaps
01:01:05.3 12/15/2006: Creating Surfaces Menu and List Bars
01:01:05.5 12/15/2006: Creating Fonts
01:01:05.5 12/15/2006: Creating Menu Font
01:01:08.1 12/15/2006: Creating Game Font
01:01:09.0 12/15/2006: Creating Font Black
01:01:09.3 12/15/2006: Creating Font Black Small
01:01:09.5 12/15/2006: Creating Game Font Faded
01:01:11.1 12/15/2006: Creating Title Font
01:01:11.2 12/15/2006: Restoring Title Font From Cache
01:01:11.7 12/15/2006: Fonts Created Succesfully
01:01:11.7 12/15/2006: Creating Radio Station Genres
01:01:11.7 12/15/2006: Error: Could not create station genres
01:01:11.8 12/15/2006: MAME Path is: C:\Mame32
01:01:11.8 12/15/2006: AdvanceMAME Path is: C:\Emulators\advancemame
01:01:11.8 12/15/2006: AdvanceMAME EXE file is: advmame.exe
01:01:11.8 12/15/2006: Use AdvanceMAME on. advmame.exe will launch games
01:01:11.8 12/15/2006: Model 2 Path Path is: C:\Emulators\Model2
01:01:11.8 12/15/2006: Model 2 EXE file is: emulator.exe
01:01:11.8 12/15/2006: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
01:01:11.8 12/15/2006: MAME EXE file is: Mame32.exe
01:01:11.9 12/15/2006: ROM Path is: C:\Mame32\roms
01:01:11.9 12/15/2006: Catver.ini Not Found
01:01:11.9 12/15/2006: controls.ini Not Found
01:01:11.9 12/15/2006: History.Dat Not Found
01:01:11.9 12/15/2006: nplayers.ini Not Found
01:01:11.9 12/15/2006: MAMEinfo.Dat Not Found
01:01:12.0 12/15/2006: Loading Controls.ini map file
01:01:12.2 12/15/2006: Snap Path is: C:\Mame32\snap
01:01:12.2 12/15/2006: AVI Snap Path is: C:\Mame32\MAMEMNG\ingame
01:01:12.2 12/15/2006: Flyer Path is: C:\Mame32\flyers
01:01:12.2 12/15/2006: Cabinet Path is: C:\Mame32\cabinets
01:01:12.2 12/15/2006: Title Path is: C:\Mame32\titles
01:01:12.2 12/15/2006: Panel Path is: C:\Mame32\cpanel
01:01:12.2 12/15/2006: Icon Path is: C:\Mame32\icons
01:01:12.2 12/15/2006: Marquee Path is: C:\Mame32\marquees
01:01:12.2 12/15/2006: MAME CMD options: -triplebuffer -nowindow -joy
01:01:12.2 12/15/2006: Attempting to load game list
01:01:12.5 12/15/2006: Loading last used Game List
01:01:12.5 12/15/2006: Setting Music Volume
01:01:12.5 12/15/2006: Cannot Load Play List. Check Path and filename
01:01:12.6 12/15/2006: Creating DirectSound Device
01:01:12.6 12/15/2006: Trying: Primary Sound Driver
01:01:12.6 12/15/2006: Loading Sound Files
01:01:12.8 12/15/2006: DirectSound Device Created Successfully
01:01:12.8 12/15/2006: Creating ICONS
01:01:12.9 12/15/2006: Recreating ICONS
01:01:13.5 12/15/2006: Initialising DirectInput for Gamepad support
01:01:13.6 12/15/2006: Unable to create a joystick device
01:01:13.6 12/15/2006: Initialising DirectInput for Keyboard support
01:01:13.7 12/15/2006: Playing intro sound file
01:01:13.7 12/15/2006: Initializing MCE Remote
01:01:13.7 12/15/2006: Initialization OK! Starting GameEx!
01:01:13.7 12/15/2006: Testing Main Loop Once: Processing Frame
01:01:14.2 12/15/2006: Testing Main Loop Once: Main Loop ran successfully
01:01:22.2 12/15/2006: Validating: Emulator_1: Custom Background: C:\Mame32\GENESIS\sega snaps
01:01:22.2 12/15/2006: Warning: Emulator_1: Custom Background Does not exist
01:01:22.2 12/15/2006: Validating: Emulator_1: Snap Path: C:\Mame32\GENESIS\sega snaps
01:01:22.2 12/15/2006: Validating: Emulator_1: Database:
01:01:22.2 12/15/2006: Warning: Emulator_1: Database Does not exist
01:01:22.2 12/15/2006: Validating: Emulator_1: Title Snap Path:
01:01:22.2 12/15/2006: Warning: Emulator_1: Title Snap Path Does not exist
01:01:22.2 12/15/2006: Validating: Emulator_1: Box Art Path:
01:01:22.2 12/15/2006: Warning: Emulator_1: Box Art Path Does not exist
01:01:22.2 12/15/2006: Validating: Emulator_1: Cart Art Path:
01:01:22.2 12/15/2006: Warning: Emulator_1: Cart Art Path Does not exist
01:01:22.2 12/15/2006: Validating: Emulator_2: Custom Background: C:\Mame32\SNES\snes snaps
01:01:22.2 12/15/2006: Warning: Emulator_2: Custom Background Does not exist
01:01:22.2 12/15/2006: Validating: Emulator_2: Snap Path: C:\Mame32\SNES\snes snaps
01:01:22.3 12/15/2006: Validating: Emulator_2: Database: SNES
01:01:22.3 12/15/2006: Validating: Emulator_2: Title Snap Path:
01:01:22.3 12/15/2006: Warning: Emulator_2: Title Snap Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_2: Box Art Path:
01:01:22.3 12/15/2006: Warning: Emulator_2: Box Art Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_2: Cart Art Path:
01:01:22.3 12/15/2006: Warning: Emulator_2: Cart Art Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_3: Custom Background: C:\Mame32\NES\nes snaps
01:01:22.3 12/15/2006: Warning: Emulator_3: Custom Background Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_3: Snap Path: C:\Mame32\NES\nes snaps
01:01:22.3 12/15/2006: Validating: Emulator_3: Database: NES
01:01:22.3 12/15/2006: Validating: Emulator_3: Title Snap Path:
01:01:22.3 12/15/2006: Warning: Emulator_3: Title Snap Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_3: Box Art Path:
01:01:22.3 12/15/2006: Warning: Emulator_3: Box Art Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_3: Cart Art Path:
01:01:22.3 12/15/2006: Warning: Emulator_3: Cart Art Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_5: Custom Background: C:\Mame32\Stella\atari snaps
01:01:22.3 12/15/2006: Warning: Emulator_5: Custom Background Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_5: Snap Path: C:\Mame32\Stella\atari snaps
01:01:22.3 12/15/2006: Validating: Emulator_5: Database: ATARI2600
01:01:22.3 12/15/2006: Validating: Emulator_5: Title Snap Path:
01:01:22.3 12/15/2006: Warning: Emulator_5: Title Snap Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_5: Box Art Path:
01:01:22.3 12/15/2006: Warning: Emulator_5: Box Art Path Does not exist
01:01:22.3 12/15/2006: Validating: Emulator_5: Cart Art Path:
01:01:22.3 12/15/2006: Warning: Emulator_5: Cart Art Path Does not exist
01:01:22.4 12/15/2006: Restoring Emulator from Cache
01:01:22.7 12/15/2006: Restoring Emulator Database From Cache
01:01:28.9 12/15/2006: Running: cmd.exe /c C: fceu.exe "C:\Mame32\NES\nes roms\Contra (U) [!].nes"
01:03:00.5 12/15/2006: Escape Pressed, exiting emulator
01:03:14.2 12/15/2006: Running: cmd.exe /c C: fceu.exe "C:\Mame32\NES\nes roms\Contra (U) [!].nes"
01:03:17.2 12/15/2006: Escape Pressed, exiting emulator
01:03:48.7 12/15/2006: Running: cmd.exe /c C: gensfe.exe "C:\Mame32\GENESIS\Sega Roms\Desert Strike - Return to the Gulf.bin"
01:03:50.5 12/15/2006: Escape Pressed, exiting emulator
01:04:07.1 12/15/2006: Exiting GameEx!
01:04:07.2 12/15/2006: Saving Settings
01:04:13.0 12/15/2006: Disposing Plugins
01:04:13.0 12/15/2006: Checking for applications to Launch On Exit
Any way you can force resolution in the emulator so GameEx doesn't have to do it? NEStopia, for example, has an ini that I can specify the resolution in. If so, can you try that and let me know what happens?
It almost sounds to me like your emulator isn't terminating in the background.
I'll switch to nestopia, try it, and let you know.
Thanks again.
Try making sure GameEx doesn't switch resolutions. Its in the setup wizard under display settings turn on don't switch resolutions. If that doesn't work. Specify a certain resolution for GameEx to use. Something like 800x600. I'm not sure what your television can handle. May be a refresh rate problem between gameex and your tv. I use a Tv an have no problems. I'm also using an ATI card. Let us know how it goes.
Problem fixed.
XP, and likewise, Gameex, were running at 32bit color depth. FCEU was running at 16bit. When I loaded the game, the resolution stayed the same, but the depth switch caused the flickering. I have no idea why, but upon changing FCEU to 32bit color, I am now able to exit games and then return to them without any trouble. Also, no flicker.
Neither Zsnes or Gens have been causing me problems, but both still have the flicker. If they cause me problems in the future, at least now I'll have a starting point at which to check.
Thanks to everyone for the help.
Its been a while since i've fired up GameEx and have recently updated mame to 0.111.0.0 everything seems to be working flawlessly but when i try and load a mame title the process starts but then returns me back to the play this game screen. I have checked my config and am clueless as to why its happening. everything else is loading properly. If anyone has any suggestions id appreaciate it.
Here is my log
19:35:22.4 12/15/2006: GameEx: Version 7.09: Starting Log
19:35:22.4 12/15/2006: Operating System Platform: Win32NT
19:35:22.4 12/15/2006: Operating System Name: Windows XP
19:35:22.4 12/15/2006: Operating System Version: 5.1.2600
19:35:22.5 12/15/2006: Checking for versions of .net Framework installed
19:35:22.5 12/15/2006: .net Framework 1.0 Installed
19:35:22.5 12/15/2006: .net Framework 1.1 Installed
19:35:22.5 12/15/2006: .net Framework 2.0 Installed
19:35:22.5 12/15/2006: Intel® Pentium® 4 CPU 3.06GHz
19:35:22.5 12/15/2006: 3.07Ghz - 2 Cores or CPU's
19:35:22.5 12/15/2006: Running Randomize()
19:35:22.5 12/15/2006: Loading PlugIns
19:35:22.5 12/15/2006: Checking for applications to Launch On Startup
19:35:22.5 12/15/2006: Initialising Video/MNG DLL's
19:35:22.5 12/15/2006: Running Misc startup tasks
19:35:22.5 12/15/2006: Setting Menu types
19:35:22.5 12/15/2006: Opening Configuration File
19:35:22.5 12/15/2006: Getting Configuration Values
19:35:22.6 12/15/2006: Using Theme: Default - Custom V2 Default 800x600
19:35:22.6 12/15/2006: Checking for alternate Image Directory for Theme: Default - Custom V2 Default 800x600
19:35:22.6 12/15/2006: Launching HideOS.exe
19:35:22.6 12/15/2006: Hiding Taskbar
19:35:22.6 12/15/2006: Is Media Center running?
19:35:22.6 12/15/2006: Media Center is running
19:35:22.6 12/15/2006: Checking/Creating LCD Registry values
19:35:22.6 12/15/2006: Check Media Center Exit/Start Mode
19:35:22.7 12/15/2006: Media Center Mode 2
19:35:22.7 12/15/2006: Closing Media Center
19:35:27.8 12/15/2006: Text/Language: English
19:35:27.9 12/15/2006: Applying Language/Text
19:35:28.3 12/15/2006: Snap Delay set to: 1
19:35:28.3 12/15/2006: Get other settings
19:35:28.4 12/15/2006: Set: Find emulator artwork on best match basis
19:35:28.5 12/15/2006: Start work for Form
19:35:28.5 12/15/2006: Getting Original Screen Size
19:35:28.5 12/15/2006: Loading ICON
19:35:28.5 12/15/2006: Initializing Component
19:35:28.6 12/15/2006: Initialising Bass Audio Library
19:35:28.9 12/15/2006: Loading default loading screen
19:35:29.0 12/15/2006: Loading Custom Emulators
19:35:29.0 12/15/2006: Loading Emulator 1: Nintendo 64 Games
19:35:29.1 12/15/2006: Loading Emulator 2: Nintendo SNES Games
19:35:29.2 12/15/2006: Loading Emulator 3: Pinball Games
19:35:29.3 12/15/2006: Loading Emulator 4: Nintendo NES Games
19:35:29.4 12/15/2006: Loading Emulator 5: Atari 2600 Games
19:35:29.5 12/15/2006: Loading Emulator 6: Sega Genesis Games
19:35:29.6 12/15/2006: Loading Emulator 7: Gameboy ADVANCE
19:35:30.0 12/15/2006: Using 2D Animations
19:35:30.0 12/15/2006: Using General Font: Trebuchet MS
19:35:30.0 12/15/2006: Using Title Font: Trebuchet MS
19:35:30.0 12/15/2006: Starting GameExtender Publisher
19:35:30.0 12/15/2006: Initialising DirectDraw
19:35:30.1 12/15/2006: Applying GameEx is Loading Image
19:35:30.2 12/15/2006: Creating DirectDraw Device
19:35:30.2 12/15/2006: Using Device: RADEON 9800 PRO
19:35:30.3 12/15/2006: Setting Resolution to 800x600 32 bit color
19:35:30.3 12/15/2006: Creating DirectDraw Surfaces
19:35:30.3 12/15/2006: Creating Primary Surface - Full Screen Mode
19:35:30.4 12/15/2006: Creating Back Buffer
19:35:30.4 12/15/2006: Version 2 Theme being used. Loading.
19:35:30.4 12/15/2006: Loading Button Data
19:35:30.4 12/15/2006: Loading Font Data
19:35:30.5 12/15/2006: Loading Layout Data
19:35:30.5 12/15/2006: Loading Taskbar Data
19:35:30.5 12/15/2006: Loading graphic surfaces
19:35:30.5 12/15/2006: Creating Surfaces Misc and Dialogs
19:35:30.6 12/15/2006: Creating Surface Volume
19:35:30.6 12/15/2006: Creating Surfaces Arrows
19:35:30.7 12/15/2006: Creating Surfaces GameEXlogo Text
19:35:30.7 12/15/2006: Creating Surfaces Toolbar
19:35:30.8 12/15/2006: Creating Surfaces Backgrounds
19:35:33.0 12/15/2006: Creating Surfaces Toolbar Controls
19:35:33.1 12/15/2006: Creating Surfaces GameEx Logo
19:35:33.1 12/15/2006: Creating Surfaces Home & Exit
19:35:33.2 12/15/2006: Creating Surfaces Snaps
19:35:33.2 12/15/2006: Creating Surfaces Menu and List Bars
19:35:33.4 12/15/2006: Creating Fonts
19:35:33.4 12/15/2006: Creating Menu Font
19:35:33.9 12/15/2006: Creating Game Font
19:35:34.0 12/15/2006: Creating Font Black
19:35:34.2 12/15/2006: Creating Font Black Small
19:35:34.3 12/15/2006: Creating Game Font Faded
19:35:34.4 12/15/2006: Creating Title Font
19:35:34.5 12/15/2006: Restoring Title Font From Cache
19:35:37.0 12/15/2006: Fonts Created Succesfully
19:35:37.0 12/15/2006: Creating Radio Station Genres
19:35:37.0 12/15/2006: Error: Could not create station genres
19:35:37.0 12/15/2006: Initialising Windows Media Player Component
19:35:37.2 12/15/2006: MAME Path is: D:\Mame32
19:35:37.2 12/15/2006: daphne Path is: E:\DAPHNE
19:35:37.2 12/15/2006: daphne EXE file is: Daphne.exe
19:35:37.2 12/15/2006: Use daphne on. Daphne.exe will launch games
19:35:37.3 12/15/2006: ZiNc Path is: D:\ZINC
19:35:37.3 12/15/2006: ZiNc EXE file is: zinc.exe
19:35:37.3 12/15/2006: Use ZiNc on. zinc.exe will launch PSX games
19:35:37.3 12/15/2006: MAME EXE file is: Mame32.exe
19:35:37.3 12/15/2006: ROM Path is: D:\Mame32\roms
19:35:37.3 12/15/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
19:35:37.3 12/15/2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
19:35:37.3 12/15/2006: History.dat is located at: D:\Mame32\datfiles\history.dat
19:35:37.3 12/15/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
19:35:37.4 12/15/2006: MAMEinfo.dat is located at: D:\Mame32\datfiles\MAME_0111.dat
19:35:37.4 12/15/2006: Loading Controls.ini map file
19:35:37.5 12/15/2006: Snap Path is: D:\Mame32\snap
19:35:37.5 12/15/2006: AVI Snap Path is: D:\Mame32\mame_videos_shrunk
19:35:37.5 12/15/2006: Flyer Path: Not Found
19:35:37.5 12/15/2006: Cabinet Path: Not Found
19:35:37.5 12/15/2006: Title Path: Not Found
19:35:37.5 12/15/2006: Panel Path: Not Found
19:35:37.5 12/15/2006: Panel Path is:
19:35:37.5 12/15/2006: Icon Path is: D:\Mame32\mamu icons
19:35:37.5 12/15/2006: Marquee Path: Not Found
19:35:37.5 12/15/2006: Using Ultimarc AradeVGA
19:35:37.5 12/15/2006: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
19:35:37.5 12/15/2006: Attempting to load game list
19:35:37.7 12/15/2006: Loading last used Game List
19:35:37.7 12/15/2006: Setting Music Volume
19:35:37.8 12/15/2006: Creating DirectSound Device
19:35:37.8 12/15/2006: Trying: Primary Sound Driver
19:35:37.8 12/15/2006: Loading Sound Files
19:35:37.9 12/15/2006: DirectSound Device Created Successfully
19:35:37.9 12/15/2006: Creating ICONS
19:35:38.0 12/15/2006: Restoring Cached ICONS from File
19:35:39.4 12/15/2006: Initialising DirectInput for Gamepad support
19:35:39.5 12/15/2006: Unable to create a joystick device
19:35:39.5 12/15/2006: Playing intro sound file
19:35:39.5 12/15/2006: Initializing MCE Remote
19:35:39.6 12/15/2006: Initialization OK! Starting GameEx!
19:35:39.6 12/15/2006: Testing Main Loop Once: Processing Frame
19:35:39.9 12/15/2006: Testing Main Loop Once: Main Loop ran successfully
19:35:59.1 12/15/2006: Running: cmd.exe /c D: D:\Mame32\Mame32.exe 1941 -rompath D:\Mame32\roms -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy -resolution 352x256 -hwstretch -effect sharp
19:36:14.5 12/15/2006: Exiting GameEx!
19:36:14.5 12/15/2006: Saving Settings
19:36:17.9 12/15/2006: Disposing Plugins
19:36:17.9 12/15/2006: Checking for applications to Launch On Exit
19:36:17.9 12/15/2006: Launching Media Center
I had a similar issue trying to use Daphne a while back but the issue then was something Tom had to input on a following rls of GameEx. I have also adjusted the rez with no luck. Is anyone else experiencing the same problem ??
Issue resolved : ) I didnt think to check the FAQ's (user error)
Thanks Tom
I just set up GE and all the emulators do this. I have game lists showing, just GE tries to play then craps out. I didn't see this in the FAQ - what did you do?
Thanks Tom
Q: I'm using a recent version of MAME (.106 or newer), I'm a registered user and I've read all the other suggestions but games do not run it just returns to GameEx. On closer inspection it appears that only vertical games do not run such as Pac Man.
A: You can fix this by turning off the "Use Bezel" option under "Basic MAME Settings" in the configuration application.
Q: I've been using GameEx a while and just upgraded my version of MAME. Every time I launch a game it just returns to GameEx,
A: Certain command line options were removed from MAME in recent versions. Go into GameEx configuration > Advanced MAME Configuration. Look at the line that says CMD/Command options and remove the text that says -skip_disclaimer.
No, I saw those. But I went ahead and looked. 1) I already have no bezels selected. 2) I don't even see that other thing - but I ain't running advmame, anyway. a) it's not just vertical games - it's all games. b ) it ain't just mame - it's VP, O2EM, etc.
Its not for advance mame emu. Its advanced settings. ;)
Okay. I still don't see anything, on any of the three pages in that config menu, that says, either, CMD/Command options, or a box with -skip_disclaimer in it..
Dude, that's over the top. I was going through the configuration utility within GE, itself, which has all the same options. Being literal, I thought CMD/Command was a title to look for in the list. (You can tell I don't do command line.) Still, in the vid, it looked like you just sort of reselected what was already there in those two boxes. So I did that, and I got a very fast squiggle of video-something, before it defaulted back to the game's start page. I dunno.....
Incidentally, I haven't any longer, for about a day or so, had MAME on the start page, even though it's selected in the parametres. I then changed it so it'd be in the line-up - nothing. Changed it back - nothing. Maybe I'm just not supposed to use this.
I didn't mean for you to just click the boxes. I was just showing you where they were. You need to edit them to suit your needs. I'm a little tired now, but in one of the options you can have Mame on the start page or not. You of course have somehow turned it off. Just go into the setup wizard. Click Advanced. Just take your time and browse through all the pages. Make sure to click on the "?" to the right of the boxes for explanations. If you still can't find it. I do another flash for you.
