  On 11/16/2022 at 9:41 AM, Tom Speirs said:
Having thought about it probably the rom filter. Add the required file extension.
For rom filer I have *.zip amd for Naomi I have *.zip and look forn roms in folder. Now I think of it thats not needed for the chd games.
Its the 7-zip/goodmerge setting. If the emulator will read zip files you dont need it (like MAME). If there are image files in the zips and only those can be read by the emulator then you use the setting and pass the files within the zips.
Thanx Tom! that did the trick I didn't realize I turned it on. now I'ma search the forums for a map file maker so it looks nice
  • Draco1962 changed the title to [RESOLVED] Sega Naomi & Sammy Atomiswave
  • Draco1962 locked this topic
