[RESOLVED] Attract mode Crash in 18.15 & 18.17
Hi Guys,
I updated to 18.15 and my attract mode would start and soon after GameEx would crash back to the desktop. I updated to 18.17 (18.16 was a separate issue) and its still doing it.
I've attached a few log files to see if there is something in common (I can decipher some stuff in the log but a lot is over my head)
Hope it helps.
Thanks in advance
log - Copy - Copy.txt log - Copy (2).txt log - Copy.txt log.txt
Oh really? Ok then that may be one of my scripts that I use to swap controllers doing it. But Its worked before (not sure at what version I'll have to try older ones this weekend) But any idea why GameEx crashes completely when it happens? And do you see if its always happening at a specific Emulator?
Thanks for you time Tom
It appears to be an issue when it tries to run a non MAME game from what I can see. Is there anything in the event viewer?
The .net 4 version (xp/32 bit) likely won't hard crash like that. You can try it until I figure this out.
Seems to be working now. Thanks Tom! As usual you provide the best service out there.
  • Thanks 1
  • Draco1962 changed the title to [RESOLVED] Attract mode Crash in 18.15 & 18.17
