Hi,
firstly like to say GameEx Rocks
I have been using GameEx for some time now without problems
I have constantly kept up with updates and have not had a problem untill now
last working version for me is 4.01
soon as I updated to 4.03 GameEx hanged at startup
I even tried 4.04 and the same thing happends
if I reinstall 4.01 no problem, everything works fine
i figured out that to stop GameEx hanging was to take out the .exe away from advancemame.exe in the setting
but when i do this, Mame is not showing on the Start page, everything else is there such as dvd, jukebox, othere emulators etc etc
and yes i have made sure that mame is selected to show up on screen
the strange thing is that without changing any settings and reinstall 4.01 everything works fine
so what im wondering, has something majorly changed from 4.01 to 4.03 and 4.04
or is it something new added to make AdvanceMame work in new version :blink:
im confussed as to why all of a sudden mame not working
ususally just do an update and everything work fine from version to version
does anyone have a sollution or simular problem or just me?
my advancemame is on D:\Mame
and no, im not going to put it on C drive
  jjnet2005 said:
Hi,
Please post your log file.
to the administrator
as requested this is my log
this is my current log on working vesrion 4.01
19:51:34.1 31/05/2005: GameEx: Version 4.01: Starting Log
19:51:34.1 31/05/2005: Operating System Platform ID: Win32NT
19:51:34.1 31/05/2005: Operating System Version: 5.1
19:51:34.1 31/05/2005: Running Randomize()
19:51:34.1 31/05/2005: Running Misc startup tasks
19:51:34.1 31/05/2005: Hiding Cursor
19:51:34.1 31/05/2005: Setting Menu types
19:51:34.1 31/05/2005: Opening Configuration File
19:51:34.1 31/05/2005: Getting Configuration Values
19:51:34.1 31/05/2005: Using Theme: Default - Default
19:51:34.1 31/05/2005: Checking for alternate Image Directory for Theme: Default - Default
19:51:34.1 31/05/2005: Applying Language/Text
19:51:34.2 31/05/2005: Snap Delay set to: 6
19:51:34.2 31/05/2005: Is Media Center running?
19:51:34.2 31/05/2005: Check Media Center Exit/Start Mode
19:51:34.2 31/05/2005: Media Center Mode 2
19:51:34.2 31/05/2005: Get other settings
19:51:34.2 31/05/2005: Mouse Input is disabled
19:51:34.2 31/05/2005: SlikStik support enabled
19:51:34.2 31/05/2005: Using DirectInput for keyboard input
19:51:34.2 31/05/2005: Launching HideOS.exe
19:51:34.9 31/05/2005: Hiding Taskbar
19:51:34.9 31/05/2005: Start work for Form
19:51:34.9 31/05/2005: Getting Original Screen Size
19:51:34.9 31/05/2005: Loading ICON
19:51:34.9 31/05/2005: Initializing Component
19:51:35.0 31/05/2005: Using General Font: Trebuchet MS
19:51:35.0 31/05/2005: Using Title Font: Trebuchet MS
19:51:35.0 31/05/2005: Initialising DirectDraw
19:51:35.0 31/05/2005: Applying GameEx is Loading Image
19:51:35.0 31/05/2005: Creating DirectDraw Device
19:51:35.1 31/05/2005: Setting Resolution to 800x600 32 bit color
19:51:35.1 31/05/2005: Creating DirectDraw Surfaces
19:51:35.1 31/05/2005: Creating Primary Surface - Full Screen Mode
19:51:35.1 31/05/2005: Creating Back Buffer
19:51:35.1 31/05/2005: Loading graphic surfaces
19:51:36.1 31/05/2005: Creating Fonts
19:51:36.1 31/05/2005: Creating Menu Font
19:51:36.2 31/05/2005: Creating Game Font
19:51:36.4 31/05/2005: Creating Menu Font Standard Size
19:51:36.8 31/05/2005: Creating Font Black
19:51:36.9 31/05/2005: Creating Font Black Small
19:51:37.0 31/05/2005: Creating Game Font Faded
19:51:37.1 31/05/2005: Creating Title Font
19:51:37.3 31/05/2005: Initialising Windows Media Player Component
19:51:37.3 31/05/2005: MAME Path is: D:\mame
19:51:37.4 31/05/2005: AdvanceMAME Path is: D:\mame
19:51:37.4 31/05/2005: AdvanceMAME EXE file is: advmame.exe
19:51:37.4 31/05/2005: Use AdvanceMAME on. advmame.exe will launch games
19:51:37.4 31/05/2005: MAME EXE file is: advmame.exe
19:51:37.4 31/05/2005: ROM Path is: D:\mame\rom
19:51:37.4 31/05/2005: Catver.ini is located at: D:\mame\data\catver.ini
19:51:37.4 31/05/2005: controls.ini is located at: D:\mame\data\controls.ini
19:51:37.4 31/05/2005: History.dat is located at: D:\mame\data\history.dat
19:51:37.4 31/05/2005: nplayers.ini is located at: D:\mame\data\nplayers.ini
19:51:37.4 31/05/2005: MAMEinfo.dat is located at: D:\mame\data\mameinfo.dat
19:51:37.4 31/05/2005: Loading Controls.ini map file
19:51:37.4 31/05/2005: Loading Custom Emulators
19:51:37.4 31/05/2005: Loading Emulator 3: Pinball Games
19:51:37.5 31/05/2005: Validating: Emulator_3: Snap Path: D:\pinball\snap
19:51:37.5 31/05/2005: Validating: Emulator_3: Title Snap Path:
19:51:37.5 31/05/2005: Warning: Emulator_3: Title Snap Path Does not exist
19:51:37.5 31/05/2005: Validating: Emulator_3: Box Art Path:
19:51:37.5 31/05/2005: Warning: Emulator_3: Box Art Path Does not exist
19:51:37.5 31/05/2005: Validating: Emulator_3: Cart Art Path:
19:51:37.5 31/05/2005: Warning: Emulator_3: Cart Art Path Does not exist
19:51:37.6 31/05/2005: Snap Path is: D:\mame\snap
19:51:37.6 31/05/2005: AVI Snap Path: Not Found
19:51:37.6 31/05/2005: Flyer Path: Not Found
19:51:37.6 31/05/2005: Cabinet Path: Not Found
19:51:37.6 31/05/2005: Title Path: Not Found
19:51:37.6 31/05/2005: Panel Path: Not Found
19:51:37.6 31/05/2005: Icon Path is: D:\mame\icons
19:51:37.6 31/05/2005: Marquee Path: Not Found
19:51:37.6 31/05/2005: Attempting to load game list
19:51:37.7 31/05/2005: Loading last used Game List
19:51:37.9 31/05/2005: Initialising Bass Audio Library
19:51:38.3 31/05/2005: Creating DirectSound Device
19:51:38.3 31/05/2005: Trying: Primary Sound Driver
19:51:38.3 31/05/2005: Loading Sound Files
19:51:38.3 31/05/2005: DirectSound Device Created Successfully
19:51:38.3 31/05/2005: Creating ICONS
19:51:39.8 31/05/2005: Gamepad/Joystick disabled
19:51:39.8 31/05/2005: Initialising DirectInput for Keyboard support
19:51:39.8 31/05/2005: Playing Startup Video
19:51:39.8 31/05/2005: Playing intro sound file
19:51:39.8 31/05/2005: Initialization OK! Starting GameEx!
19:51:39.8 31/05/2005: Testing Main Loop Once: Processing Frame
19:51:39.8 31/05/2005: Testing Main Loop Once: Getting Tick count
19:51:40.0 31/05/2005: Testing Main Loop Once: Checking for song change
19:51:40.0 31/05/2005: Testing Main Loop Once: Checking Keyboard for Input
19:51:40.0 31/05/2005: Testing Main Loop Once: Front buffer exists?
19:51:40.0 31/05/2005: Testing Main Loop Once: Surfaces need restore?
19:51:40.0 31/05/2005: Testing Main Loop Once: Checking Joystick for input
19:51:40.0 31/05/2005: Testing Main Loop Once: Drawing Background
19:51:40.1 31/05/2005: Testing Main Loop Once: Flipping Surfaces
19:51:40.1 31/05/2005: Testing Main Loop Once: Main Loop ran successfully
19:51:48.4 31/05/2005: Exiting GameEx!
19:51:48.4 31/05/2005: Saving Settings
19:51:48.5 31/05/2005: Writing Game List to disk
Now here is the log after installing version 4.05
I didnt change any settings from previous version 4.01
just did an update as i normally have in the past
and gameEx is hung
19:56:53.8 31/05/2005: GameEx: Version 4.05: Starting Log
19:56:53.8 31/05/2005: Operating System Platform: Win32NT
19:56:53.8 31/05/2005: Operating System Name: Windows XP
19:56:53.8 31/05/2005: Operating System Version: 5.1.2600
19:56:53.8 31/05/2005: Running Randomize()
19:56:53.8 31/05/2005: Running Misc startup tasks
19:56:53.8 31/05/2005: Hiding Cursor
19:56:53.8 31/05/2005: Setting Menu types
19:56:53.8 31/05/2005: Opening Configuration File
19:56:53.8 31/05/2005: Getting Configuration Values
19:56:53.8 31/05/2005: Using Theme: Default - Default
19:56:53.8 31/05/2005: Checking for alternate Image Directory for Theme: Default - Default
19:56:53.8 31/05/2005: Applying Language/Text
19:56:53.9 31/05/2005: Snap Delay set to: 6
19:56:53.9 31/05/2005: Is Media Center running?
19:56:53.9 31/05/2005: Check Media Center Exit/Start Mode
19:56:53.9 31/05/2005: Media Center Mode 2
19:56:53.9 31/05/2005: Get other settings
19:56:53.9 31/05/2005: Mouse Input is disabled
19:56:54.0 31/05/2005: SlikStik support enabled
19:56:54.0 31/05/2005: Using DirectInput for keyboard input
19:56:54.0 31/05/2005: Launching HideOS.exe
19:56:54.7 31/05/2005: Hiding Taskbar
19:56:54.7 31/05/2005: Start work for Form
19:56:54.7 31/05/2005: Getting Original Screen Size
19:56:54.7 31/05/2005: Loading ICON
19:56:54.7 31/05/2005: Initializing Component
19:56:54.7 31/05/2005: Using General Font: Trebuchet MS
19:56:54.7 31/05/2005: Using Title Font: Trebuchet MS
19:56:54.7 31/05/2005: Initialising DirectDraw
19:56:54.7 31/05/2005: Applying GameEx is Loading Image
19:56:54.8 31/05/2005: Creating DirectDraw Device
19:56:54.8 31/05/2005: Setting Resolution to 800x600 32 bit color
19:56:54.8 31/05/2005: Creating DirectDraw Surfaces
19:56:54.8 31/05/2005: Creating Primary Surface - Full Screen Mode
19:56:54.8 31/05/2005: Creating Back Buffer
19:56:54.8 31/05/2005: Loading graphic surfaces
19:56:55.9 31/05/2005: Creating Fonts
19:56:55.9 31/05/2005: Creating Menu Font
19:56:56.0 31/05/2005: Creating Game Font
19:56:56.2 31/05/2005: Creating Menu Font Standard Size
19:56:56.6 31/05/2005: Creating Font Black
19:56:56.7 31/05/2005: Creating Font Black Small
19:56:56.7 31/05/2005: Creating Game Font Faded
19:56:56.8 31/05/2005: Creating Title Font
19:56:57.2 31/05/2005: Initialising Windows Media Player Component
19:56:57.2 31/05/2005: MAME Path is: D:\mame
19:56:57.2 31/05/2005: AdvanceMAME Path is: D:\mame
19:56:57.2 31/05/2005: AdvanceMAME EXE file is: advmame.exe
19:56:57.2 31/05/2005: Use AdvanceMAME on. advmame.exe will launch games
19:56:57.2 31/05/2005: MAME EXE file is: advmame.exe
19:56:57.2 31/05/2005: ROM Path is: D:\mame\rom
19:56:57.2 31/05/2005: Catver.ini is located at: D:\mame\data\catver.ini
19:56:57.2 31/05/2005: controls.ini is located at: D:\mame\data\controls.ini
19:56:57.2 31/05/2005: History.dat is located at: D:\mame\data\history.dat
19:56:57.2 31/05/2005: nplayers.ini is located at: D:\mame\data\nplayers.ini
19:56:57.2 31/05/2005: MAMEinfo.dat is located at: D:\mame\data\mameinfo.dat
19:56:57.3 31/05/2005: Loading Controls.ini map file
19:56:57.3 31/05/2005: Loading Custom Emulators
19:56:57.3 31/05/2005: Loading Emulator 3: Pinball Games
19:56:57.3 31/05/2005: Validating: Emulator_3: Snap Path: D:\pinball\snap
19:56:57.3 31/05/2005: Validating: Emulator_3: Title Snap Path:
19:56:57.3 31/05/2005: Warning: Emulator_3: Title Snap Path Does not exist
19:56:57.3 31/05/2005: Validating: Emulator_3: Box Art Path:
19:56:57.3 31/05/2005: Warning: Emulator_3: Box Art Path Does not exist
19:56:57.3 31/05/2005: Validating: Emulator_3: Cart Art Path:
19:56:57.3 31/05/2005: Warning: Emulator_3: Cart Art Path Does not exist
19:56:57.4 31/05/2005: Snap Path is: D:\mame\snap
19:56:57.4 31/05/2005: AVI Snap Path: Not Found
19:56:57.4 31/05/2005: Flyer Path: Not Found
19:56:57.4 31/05/2005: Cabinet Path: Not Found
19:56:57.4 31/05/2005: Title Path: Not Found
19:56:57.4 31/05/2005: Panel Path: Not Found
19:56:57.4 31/05/2005: Icon Path is: D:\mame\icons
19:56:57.4 31/05/2005: Marquee Path: Not Found
19:56:57.4 31/05/2005: MAME CMD options:
19:56:57.4 31/05/2005: Attempting to load game list
19:56:57.5 31/05/2005: Running: advmame.exe -help
19:56:57.5 31/05/2005: Running: D: D:\mame\advmame.exe -help > D:\mame\help.txt
19:57:21.7 31/05/2005: Loading last used Game List
19:57:21.8 31/05/2005: Initialising Bass Audio Library
19:57:22.1 31/05/2005: Creating DirectSound Device
19:57:22.1 31/05/2005: Trying: Primary Sound Driver
19:57:22.1 31/05/2005: Loading Sound Files
19:57:22.1 31/05/2005: DirectSound Device Created Successfully
19:57:22.1 31/05/2005: Creating ICONS
19:57:22.2 31/05/2005: Restoring Cached ICONS from File
19:57:22.4 31/05/2005: Gamepad/Joystick disabled
19:57:22.4 31/05/2005: Initialising DirectInput for Keyboard support
Now this is a modification to the config
I deleted the .exe from the advmame.exe in the advanced mame cofig setting
and gameex goes into the start page and all is normal except, now No mame showing
there is no mame showing in the start page at all
20:07:53.9 31/05/2005: GameEx: Version 4.05: Starting Log
20:07:54.0 31/05/2005: Operating System Platform: Win32NT
20:07:54.0 31/05/2005: Operating System Name: Windows XP
20:07:54.0 31/05/2005: Operating System Version: 5.1.2600
20:07:54.0 31/05/2005: Running Randomize()
20:07:54.0 31/05/2005: Running Misc startup tasks
20:07:54.0 31/05/2005: Hiding Cursor
20:07:54.0 31/05/2005: Setting Menu types
20:07:54.0 31/05/2005: Opening Configuration File
20:07:54.0 31/05/2005: Getting Configuration Values
20:07:54.0 31/05/2005: Using Theme: Default - Default
20:07:54.0 31/05/2005: Checking for alternate Image Directory for Theme: Default - Default
20:07:54.0 31/05/2005: Applying Language/Text
20:07:54.1 31/05/2005: Snap Delay set to: 6
20:07:54.1 31/05/2005: Is Media Center running?
20:07:54.1 31/05/2005: Check Media Center Exit/Start Mode
20:07:54.1 31/05/2005: Media Center Mode 2
20:07:54.1 31/05/2005: Get other settings
20:07:54.1 31/05/2005: Mouse Input is disabled
20:07:54.1 31/05/2005: SlikStik support enabled
20:07:54.1 31/05/2005: Using DirectInput for keyboard input
20:07:54.1 31/05/2005: Launching HideOS.exe
20:07:54.8 31/05/2005: Hiding Taskbar
20:07:54.8 31/05/2005: Start work for Form
20:07:54.8 31/05/2005: Getting Original Screen Size
20:07:54.8 31/05/2005: Loading ICON
20:07:54.8 31/05/2005: Initializing Component
20:07:54.8 31/05/2005: Using General Font: Trebuchet MS
20:07:54.8 31/05/2005: Using Title Font: Trebuchet MS
20:07:54.8 31/05/2005: Initialising DirectDraw
20:07:54.9 31/05/2005: Applying GameEx is Loading Image
20:07:54.9 31/05/2005: Creating DirectDraw Device
20:07:54.9 31/05/2005: Setting Resolution to 800x600 32 bit color
20:07:54.9 31/05/2005: Creating DirectDraw Surfaces
20:07:54.9 31/05/2005: Creating Primary Surface - Full Screen Mode
20:07:54.9 31/05/2005: Creating Back Buffer
20:07:54.9 31/05/2005: Loading graphic surfaces
20:07:56.0 31/05/2005: Creating Fonts
20:07:56.0 31/05/2005: Creating Menu Font
20:07:56.1 31/05/2005: Creating Game Font
20:07:56.2 31/05/2005: Creating Menu Font Standard Size
20:07:56.6 31/05/2005: Creating Font Black
20:07:56.7 31/05/2005: Creating Font Black Small
20:07:56.8 31/05/2005: Creating Game Font Faded
20:07:56.9 31/05/2005: Creating Title Font
20:07:57.2 31/05/2005: Initialising Windows Media Player Component
20:07:57.2 31/05/2005: MAME Path is: D:\mame
20:07:57.2 31/05/2005: AdvanceMAME Path is: D:\mame
20:07:57.2 31/05/2005: AdvanceMAME EXE file is: advmame
20:07:57.2 31/05/2005: Invalid AdvanceMAME Executable: MAME Disabled
20:07:57.2 31/05/2005: Cannot Find AdvanceMAME executable: MAME Disabled
20:07:57.2 31/05/2005: Use AdvanceMAME on. advmame will launch games
20:07:57.3 31/05/2005: Loading Controls.ini map file
20:07:57.3 31/05/2005: Loading Custom Emulators
20:07:57.3 31/05/2005: Loading Emulator 3: Pinball Games
20:07:57.3 31/05/2005: Validating: Emulator_3: Snap Path: D:\pinball\snap
20:07:57.3 31/05/2005: Validating: Emulator_3: Title Snap Path:
20:07:57.3 31/05/2005: Warning: Emulator_3: Title Snap Path Does not exist
20:07:57.3 31/05/2005: Validating: Emulator_3: Box Art Path:
20:07:57.3 31/05/2005: Warning: Emulator_3: Box Art Path Does not exist
20:07:57.3 31/05/2005: Validating: Emulator_3: Cart Art Path:
20:07:57.3 31/05/2005: Warning: Emulator_3: Cart Art Path Does not exist
20:07:57.4 31/05/2005: MAME CMD options:
20:07:57.4 31/05/2005: Attempting to load game list
20:07:57.5 31/05/2005: Loading last used Game List
20:07:57.7 31/05/2005: Initialising Bass Audio Library
20:07:58.1 31/05/2005: Creating DirectSound Device
20:07:58.1 31/05/2005: Trying: Primary Sound Driver
20:07:58.1 31/05/2005: Loading Sound Files
20:07:58.1 31/05/2005: DirectSound Device Created Successfully
20:07:58.1 31/05/2005: Gamepad/Joystick disabled
20:07:58.1 31/05/2005: Initialising DirectInput for Keyboard support
20:07:58.2 31/05/2005: Playing Startup Video
20:07:58.2 31/05/2005: Playing intro sound file
20:07:58.2 31/05/2005: Initialization OK! Starting GameEx!
20:07:58.2 31/05/2005: Testing Main Loop Once: Processing Frame
20:07:58.2 31/05/2005: Testing Main Loop Once: Getting Tick count
20:07:58.3 31/05/2005: Testing Main Loop Once: Checking for song change
20:07:58.3 31/05/2005: Testing Main Loop Once: Checking Keyboard for Input
20:07:58.3 31/05/2005: Testing Main Loop Once: Front buffer exists?
20:07:58.3 31/05/2005: Testing Main Loop Once: Surfaces need restore?
20:07:58.3 31/05/2005: Testing Main Loop Once: Checking Joystick for input
20:07:58.3 31/05/2005: Testing Main Loop Once: Drawing Background
20:07:58.5 31/05/2005: Testing Main Loop Once: Flipping Surfaces
20:07:58.5 31/05/2005: Testing Main Loop Once: Main Loop ran successfully
20:08:04.4 31/05/2005: Exiting GameEx!
20:08:04.4 31/05/2005: Saving Settings
20:08:04.4 31/05/2005: Writing Game List to disk
hope this info will help
regards
jjnet2005
OK, now I can help!
You need to use a regular version of MAME in addition to AdvMAME. The normal MAME EXE and path should point to a recent supported normal MAME build. IE MAME.EXE and not ADVMAME.EXE
The change in the newer versions is the log does validation on the version of MAME, and displays its version. It triying to do this with AdvanceMAME which is coming up with an error in a dialog box. This is making the GameEx window loose focus, and therefore not able to initialise the Input, hence crash. Keep your advancmame settings but make sure the regular mame settings are pointing to a valid mame build.
That should do it.
Tom
dear admin
thank you so much for your fast response to my problem
Yippy :D it works
I pointed the mame exe to an official build and all seem fine now
so thank you for solving my problem
but may I ask why things had to change in the current versions of gameex
when it comes to using advancemame
what im basically trying to ask, is there any benifit by having the official build alongside advmame, why is the advmame exe nolonger valid, never needed it before.
anyway, the main thing is everything works again and thats the main thing
and if i have to have an official build alongside advancedmame then so be it
thank you for your assistance
and hope other advancemame users will find this info of benifit
thank you for a great front end, it Rocks once again
  jjnet2005 said:
dear admin
Yippy  :D  it works
GameEx was always meant to work with AdvanceMAME in that manner. You were using it in a way I never designed GameEx for. The main reason, AdvMAME does not support all the functionality and cmd line options MAME does, although it will play the games, but when trying to verify roms, update the list, and get output it does not implement all the options of MAME. At least it never used to. The updates in the new version had nothing to do with AdvanceMAME.
Thank you for the explaination about AdvanceMame and why the official build is needed
I understand now why and what i need to do to get it to work with GameEx
sorry for being a bit dumb :unsure: with this, but now im a lot wiser because of your assistence :) and hopefully anyone else with simular problem
Thank you once again for you time and help for helping out dumies like myself
GameEx Rocks, does everyone agree?
Thank you again
