Hi!!!
I have emuzwin working on my ARCADE under Gameex in fullscreen.
But Everytime i launch the emulator in gameex ,a dos box appears with the command line proccess ,cd commnads , echo commands and one PAUSE command that is making me crazy ,prompting me to press a key ,when i press a key ,all goes like a charm and i can play fullscreen.I want to avoid this dos comments and the pause issue.
any suggestions?
This emulator is superb because it allows you to keymap the gamekeys for each game in separate files,so you dont have to worry about the keys in the games ,you are going to be able to control all the games you want perfectly with your arcade joystick and buttons,it doesn´t matter if the keys are different.
See ya!
This is what gameex shows when i launch the emulator:
c:\programfiles\gameex>c:
c:\programfiles\gameex>cd "c:\emuzwin26"
ECHO
emuzwin jetpac.z80 /fullscreen /escexit
ECHO
c:\emuzwin26>PAUSE
Press any key to continue
(and when i press a key,this line appears and the emulator runs well)
c:\emuzwin26\emuzwin jetpac.z80 /fullscreen /escexit
The ini file for this emu in gameex is as follow:
[Emulator_10]
STARTPAGENAME=ZX-SPECTRUM
TITLETEXT=ZX-Spectrum
StartPageLogo=
ROMFilter=*.z80
RomsInFolders=False
RomPath=C:\EmuZWin26
SnapPath=
WorkingPath=C:\EmuZWin26
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=True
MAPFile=
AlsoLaunch=
Command=emuzwin [romfile] /PAUSE /FULLSCREEN /ESCEXIT
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
PlayInScreenSaver=False
LastGame=False|10|Jetpac|Jetpac.z80|Jetpac|ZX-Spectrum|15
Turn "Debug Mode" OFF under your emulater settings in GameEx.
FIXED!!! I changed this setting and others and it works fine!!!!
But ,how can i hide the dos commands that shows up before enter the emulator , is not important , but would be nice not to have this coding in your arcade monitor before starting the emulator.
Thank you very much.
And remember ,use emuzwin 2.26 ,not 2.27.
Changue dirs and you are done!!!!
Enjoy!!
[Emulator_10]
StartPageLogo=
ROMFilter=*.z80
RomsInFolders=False
SnapPath=
MapKeys=True
WaitBeforeKeys=3000
SendKeys={enter}
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=c:\emuzwin26\emuzwin c:\emuzwin26\[RomFile] /FULLSCREEN /ESCEXIT
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
snip...
Try turning off show desktop in your emulator config inside gameex. It may prevent your emulator from showing.
In your display settings in gameex. You can also turn on hide desktop.
  • 5 months later...
I've Just started with EmuZWin26 in gameex, but every time I pick a game off the list, EmuZWin loads the last game I ran outside of gameex , I.E it remebers the last game ran and reloads it reguardless of what game I pick in gameex spectrum menu :( . Also I've remapped the keyboard within Emuzwin to my arcade control J-pac keys and works fine, but when I close the Emuzwin it goes back to the default setting and I have to reload them, is there anyway to auto load them by default ?
Edit** It Seem's to be the autosave that's causing the problems, can't find how to disable it yet though :angry:
Edit** Don't worry I've Sorted it :lol:
Here is my gameEx settings:
[Emulator_10]
StartPageLogo=
ROMFilter=
RomsInFolders=False
RomPath=D:\Spectrum48k\Game Zips
SnapPath=
WorkingPath=D:\Spectrum48k
MapKeys=True
WaitBeforeKeys=3000
SendKeys={enter}
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=D:\Spectrum48k\emuzwin D:\Spectrum48k\Game Zips\[RomFile]/FULLSCREEN /ESCEXIT
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
My game files are .TAP in Zip format.
