Quick question on setting up Visual pinball to run from GameEx. I've looked at the settings that people are using from previous posts but am wondering what the vpauto.exe app is. I have Visual Pinball installed and running with roms. Right now the way I have it configured, when I select a table from GameEx it runs Visual Pinball and then says loading table. The table runs full screen but the Visual Pinball application is still in front. Does vpauto remove the window?
Thanks!
Thanks!
Yes it does. Its a compiled auto-it script (Which can be decompiled by the way). It does set the focus for the window. It also allows exiting with just the escape. It also bypasses all the disclaimer and default setup screen for PinMAME. It was written by me a while back.
Tom,
I haven't done a search yet to see if the script is part of your install for GameEx, is it included or available online?
Thanks!
