I am very upset at the moment. I started off very excited to get version 1.10 of mame; love teh GamEX fron END, etc...
Then I noticed the -scanlines option does not work anymore with mame. The games look terrible in my opinion without them. I tried using the method in the mame32 gui, but it looks like bad....
What can I do? Any suggestions?
I want to use mamepp from teh command line if I can. I looked into advanceMame a bit but I am thoroughly confused with that.
Any and all suggestions are appreciated :(
Zip
Zip
I take it you read my post which directed you to a thread on mame.net? Might want to give a stab there. I don't use scanlines so I can't offer any suggestions.
Yeah I did read it. It is just such a huge disappointment. It worked so well and looked so great before. Maybe someone else will have some insight.
Zip
Zip
Try this
scanlines have been removed as a switchable option, whoever you can type the
> string:
> -prescale 2 -effect scanlines
> and you'll get a similar effect to that of the old MAMEs.
Try this
> string:
I just added to my config. Trying now
Thanks, I will let you know.
Zip
Zip
It gav ethe lines in a very similar way. The good news. However, it seemed to run slower.... and the sound skipped a bit. Maybe I will play with tyeh order and other commands. Thank you so much
Zip
Zip
Are you using direct draw or D3D? Try them both. D3D should be faster.
I tried d3d by specifying it in teh command line. No difference then from without it there. I will keep digging.
Lastly, what was the last version of mame that supported the scanlines (the old way -scanlines)
Can I use a rom set frm 1.10 with an older executable?
Zip
Zip
1.6 I believe. Yes you can use the new romset. Some games may fail to work though.
