I was running PinballX - Version 4.34 x64, and I just installed the latest v5.39 x64 of PinballX. When I select a game it shows the loading video and then immediately goes back to the table selection screen. I rebooted, checked logs, and verified configurations. What could be causing VPinballX.exe from launching with this new version? I installed over the old version.
// UPDATE
I changed the relative paths (which worked fine in the older version) to direct paths and VPinballX launches. If I change them back to relative it fails. Is there a way to get back the relative paths?
I'm running in desktop mode on my PC.
11:20:06.91  2/6/2022:  PinballX Core - Version 5.39 x64
11:20:06.97  2/6/2022:  Microsoft Windows 10 Enterprise 64-bit (40GB)
11:20:08.98  2/6/2022:  CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
11:20:09.00  2/6/2022:  GPU 1: NVIDIA GeForce RTX 2060
Display1: 4k (table)
Display2: 1080p (backglass)
