I am having problems with the jukebox controlling the music. I do not have any controls to skip songs in the juke box. I have the setting set so to show the controls in the configuration. Also, I have a Niveus Media Remote and its media buttons do not get detected. They work with windows media player just fine though. Anyone have a clue as to why I cannot control the jukebox?
The controls should appear in the top right corner of the screen if the jukebox is playing, and enable controls is set. Are they not there? These controls are operated by the mouse. Can you post a screenshot with a jukebox track playing? The track name should also appear at the top of the screen in the toolbar. Perhaps you have the toolbar disabled? That could be why? They also dont show when in Arcade Mode or showing at ArcadeVGA low res resolutions. Could that be it?
The jukebox should accept the normal input keys for skip and previous plus Play/Pause. I have a little control on my Wireless bluetooth keyboard here, and they seem to work fine. I do know that when DirectInput for keyboard is enabled these keys do not work, and neither does my MCE remote. Could that be it perhaps?
