Anyone have a working config for playing flash games inside gameex? I think a wrapper may be needed unless someone knows a flash player that uses command line options. Anyone?
  headkaze said:
Just a quick search on Google and I found this.
Let me know if it works, and post your config and I'll make an emulator download/config for the Wizard for it.
I think this will work. Thanks! I'll post back when I test it out.
Works great. I dl a flash game pack with over 500 games and all I tried seemed to work. Ive attached my ini file here.
Can I control my mouse with keyboard commands? I have gameex in a cabinet without a mouse. I have an I-Pac :(
SWF_Opener.zip
  TSpeirs said:
Yes, by creating an advanced emulator config.
Is there a doc on this I can read?
Just look at one of the existing configs. Just select one and click edit, its a setting in the emulator config. I'm pretty sure theres already one included with gameex for basic mouse control unless I neglected to include it in the install.
These are the files in the config/emulators folder.
IMPORT-EXPORT Folder
Project 64 V2.ini
Visual Pinball V2.ini
VKCodes.htm
ZSNES V2.ini
All these *.ini's say exactly the same thing.
# This is an advanced emulator configuration file. It does things such as allow keyboard only emulators to be operated by a gamepad, wait for additional processes to exit and map keys. If this file is used it overrides the MAPKeys setting for the emulator.
[GENERAL]
# Enabled. Use this.
#Make MCE Back button and X-ARCADE Escape and SlikStik Escape to close emulator process
MapBack=True
#Make Escape key close emulator process
MapEscape=False
I don't see anything that allows mouse movement controlled by keyboard or other means. Windows has a built in mouse emulation by keystrokes. But it is way to slow and not compatible with this flash player.
Another thing. The edit command is missing from the gameex wizard. Its only present in the old config menu. HK may need to look at this.
Yeah, you probably need to do a manual install of GameEx from the website. Auto-Update has had issues for a while, although its fixed for next version.
Fresh Install off of website. Checked folders and still have same issue. What exactly will I see in the folder when it is working correctly? :(
You should see the addition of "PC Mouse V3.ini", no?
I see that file but like all the rest. The description for each *ini. reads
Is this supposed to be the mouse emulation ini? I suppose it has the wrong description inside?
Scroll down and.........
[MOUSEMAPPING]
# For registered users, the ability to control the mouse with a gamepad and/or directional keys.
# For example for PC strategy games.
# Apparantly this functionality is similar to the software Pinnacle profiler. Remember you can setup an emulator
# as one PC game. Specify enabled, and mousespeed 0-20. 20 Being fastest. This setting overrides the directional
# mapping for the above and buttons 1 and 2 Button 1/CTRL becomes left mouse. Button 2/ALT Right mouse
[MOUSEMAPPING]
DOH!!
Ok found it. Atleast now I know when I need to help others. Heh. Now time to test out with the flash software.
Thanks Tom.
  TSpeirs said:
No problem, let us know how you get on.
Ok one small problem. I can emulate the movement with my I-PAC but the mouse clicks don't seem to work. The ini says Ctrl and Alt are used for mouse clicks. They don't seem to be working. I'm sure my noobish self is just not seeing something.
Well Its working now. Just restarted gameex and its working. Didn't change anything. Not sure why. On a side note. The speech plugin only says 4 games then quits working.
If you can post the log after a session where the speech stops working it would really help me out.
00:51:30.2 11/26/2006: GameEx: Version 7.03: Starting Log
00:51:30.2 11/26/2006: Operating System Platform: Win32NT
00:51:30.2 11/26/2006: Operating System Name: Windows XP
00:51:30.2 11/26/2006: Operating System Version: 5.1.2600
00:51:30.2 11/26/2006: Checking for versions of .net Framework installed
00:51:30.2 11/26/2006: .net Framework 1.1 Installed
00:51:30.2 11/26/2006: .net Framework 2.0 Installed
00:51:30.2 11/26/2006: AMD Athlon XP 3200+
00:51:30.2 11/26/2006: 2.2Ghz
00:51:30.2 11/26/2006: Running Randomize()
00:51:30.2 11/26/2006: Loading PlugIns
00:51:30.3 11/26/2006: Loaded Plugin:"Speak Game Name" Version 1.0 By Tom Speirs
00:51:30.3 11/26/2006: PlugIn: "Speak Game Name" Initialized OK
00:51:30.3 11/26/2006: Checking for applications to Launch On Startup
00:51:30.4 11/26/2006: Initialising Video/MNG DLL's
00:51:30.4 11/26/2006: Running Misc startup tasks
00:51:30.4 11/26/2006: Setting Menu types
00:51:30.4 11/26/2006: Opening Configuration File
00:51:30.4 11/26/2006: Getting Configuration Values
00:51:30.4 11/26/2006: Using Theme: Default - Arcade-Classic V2 800x600
00:51:30.4 11/26/2006: Checking for alternate Image Directory for Theme: Default - Arcade-Classic V2 800x600
00:51:30.4 11/26/2006: Arcade Mode is on
00:51:30.4 11/26/2006: Launching HideOS.exe
00:51:30.4 11/26/2006: Hiding Taskbar
00:51:30.4 11/26/2006: Is Media Center running?
00:51:30.4 11/26/2006: Checking/Creating LCD Registry values
00:51:30.4 11/26/2006: Check Media Center Exit/Start Mode
00:51:30.4 11/26/2006: Media Center Mode 2
00:51:30.5 11/26/2006: Text/Language: English
00:51:30.5 11/26/2006: Applying Language/Text
00:51:30.6 11/26/2006: Snap Delay set to: 1
00:51:30.6 11/26/2006: Get other settings
00:51:30.6 11/26/2006: Set: Find emulator artwork on best match basis
00:51:30.6 11/26/2006: SlikStik support enabled
00:51:30.6 11/26/2006: Using DirectInput for keyboard input
00:51:30.7 11/26/2006: Start work for Form
00:51:30.7 11/26/2006: Getting Original Screen Size
00:51:30.7 11/26/2006: Loading ICON
00:51:30.7 11/26/2006: Initializing Component
00:51:30.7 11/26/2006: Initialising Bass Audio Library
00:51:30.8 11/26/2006: Loading default loading screen
00:51:30.9 11/26/2006: Loading Custom Emulators
00:51:30.9 11/26/2006: Loading Emulator 1: Nintendo 64 Games
00:51:30.9 11/26/2006: Loading Emulator 2: Nintendo SNES games
00:51:30.9 11/26/2006: Loading Emulator 4: Nintendo N.E.S
00:51:31.0 11/26/2006: Loading Emulator 9: Genesis
00:51:31.0 11/26/2006: Loading Emulator 10: WinKawaks
00:51:31.0 11/26/2006: Loading Emulator 11: Playstation Games
00:51:31.1 11/26/2006: Loading Emulator 12: Guilty Gear Isuka
00:51:31.1 11/26/2006: Loading Emulator 13: Dreamcast
00:51:31.1 11/26/2006: Loading Emulator 14: Atari Lynx
00:51:31.2 11/26/2006: Loading Emulator 15: Virtua Tennis
00:51:31.2 11/26/2006: Loading Emulator 16: Sega Master System
00:51:31.2 11/26/2006: Loading Emulator 17: GameBoy
00:51:31.3 11/26/2006: Loading Emulator 18: NEC TurboGrafx 16 (MagicEngine)
00:51:31.3 11/26/2006: Loading Emulator 19: SNK Neo Geo Pocket (NeoPop)
00:51:31.4 11/26/2006: Loading Emulator 20: Mattel Intellivision (Bliss)
00:51:31.4 11/26/2006: Loading Emulator 22: Atari 2600 (Stella)
00:51:31.4 11/26/2006: Loading Emulator 23: SWF Opener
00:51:31.5 11/26/2006: Using 3D Alpha Blended Animations. This could be slow
00:51:31.5 11/26/2006: Using General Font: Tahoma
00:51:31.5 11/26/2006: Using Title Font: ELLIS
00:51:31.6 11/26/2006: Initialising DirectDraw
00:51:31.6 11/26/2006: Applying GameEx is Loading Image
00:51:31.6 11/26/2006: Creating DirectDraw Device
00:51:31.6 11/26/2006: Using Device: RADEON 9800 XT
00:51:32.0 11/26/2006: Setting Resolution to 1024x768 32 bit color
00:51:32.0 11/26/2006: Creating DirectDraw Surfaces
00:51:32.0 11/26/2006: Creating Primary Surface - Full Screen Mode
00:51:32.1 11/26/2006: Creating Back Buffer
00:51:32.1 11/26/2006: Version 2 Theme being used. Loading.
00:51:32.1 11/26/2006: Loading Button Data
00:51:32.1 11/26/2006: Loading Font Data
00:51:32.1 11/26/2006: Loading Layout Data
00:51:32.1 11/26/2006: Loading Taskbar Data
00:51:32.1 11/26/2006: Loading graphic surfaces
00:51:32.2 11/26/2006: Creating Surfaces Misc and Dialogs
00:51:32.2 11/26/2006: Creating Surface Volume
00:51:32.2 11/26/2006: Creating Surfaces Arrows
00:51:32.2 11/26/2006: Creating Surfaces GameEXlogo Text
00:51:32.2 11/26/2006: Creating Surfaces Toolbar
00:51:32.2 11/26/2006: Creating Surfaces Backgrounds
00:51:32.4 11/26/2006: Creating Surfaces Toolbar Controls
00:51:32.4 11/26/2006: Creating Surfaces GameEx Logo
00:51:32.4 11/26/2006: Creating Surfaces Home & Exit
00:51:32.4 11/26/2006: Creating Surfaces Snaps
00:51:32.4 11/26/2006: Creating Surfaces Menu and List Bars
00:51:32.5 11/26/2006: Creating Fonts
00:51:32.5 11/26/2006: Creating Menu Font
00:51:33.4 11/26/2006: Creating Game Font
00:51:34.1 11/26/2006: Creating Font Black
00:51:34.3 11/26/2006: Creating Font Black Small
00:51:34.4 11/26/2006: Creating Game Font Faded
00:51:35.2 11/26/2006: Creating Title Font
00:51:35.2 11/26/2006: Restoring Title Font From Cache
00:51:35.2 11/26/2006: Fonts Created Succesfully
00:51:35.3 11/26/2006: Creating Radio Station Genres
00:51:35.4 11/26/2006: Succesfully created station genres
00:51:35.4 11/26/2006: Initialising Windows Media Player Component
00:51:35.4 11/26/2006: MAME Path is: C:\Program Files\Emu\Mame\Mame32
00:51:35.4 11/26/2006: daphne Path is: C:\Program Files\Emu\daphne-0.99.7-win32
00:51:35.4 11/26/2006: daphne EXE file is: Daphne.exe
00:51:35.4 11/26/2006: Use daphne on. Daphne.exe will launch games
00:51:35.5 11/26/2006: Model 2 Path Path is: C:\Program Files\Emu\m2emulator
00:51:35.5 11/26/2006: Model 2 EXE file is: emulator.exe
00:51:35.5 11/26/2006: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
00:51:35.5 11/26/2006: ZiNc Path is: C:\Zinc
00:51:35.5 11/26/2006: ZiNc EXE file is: zinc.exe
00:51:35.5 11/26/2006: Use ZiNc on. zinc.exe will launch PSX games
00:51:35.5 11/26/2006: MAME EXE file is: Mame32.exe
00:51:35.5 11/26/2006: ROM Path is: C:\Program Files\Emu\Mame\Mame32\roms
00:51:35.5 11/26/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
00:51:35.5 11/26/2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
00:51:35.5 11/26/2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
00:51:35.5 11/26/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
00:51:35.6 11/26/2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
00:51:35.7 11/26/2006: Loading Controls.ini map file
00:51:35.7 11/26/2006: Snap Path is: C:\Program Files\Emu\Mame\Mame32\snap
00:51:35.7 11/26/2006: AVI Snap Path is: C:\Program Files\Emu\Mame\Mame32\mng
00:51:35.7 11/26/2006: Flyer Path is: C:\Program Files\Emu\Mame\Mame32\flyers
00:51:35.7 11/26/2006: Cabinet Path is: C:\Program Files\Emu\Mame\Mame32\cabinets
00:51:35.7 11/26/2006: Title Path is: C:\Program Files\Emu\Mame\Mame32\titles
00:51:35.7 11/26/2006: Panel Path is: C:\Program Files\Emu\Mame\Mame32\cpanel
00:51:35.7 11/26/2006: Icon Path is: C:\Program Files\Emu\Mame\Mame32\icons
00:51:35.7 11/26/2006: Marquee Path is: C:\Program Files\Emu\Mame\Mame32\marquees
00:51:35.7 11/26/2006: MAME CMD options: -triplebuffer -nowindow -joy
00:51:35.7 11/26/2006: Attempting to load game list
00:51:36.2 11/26/2006: Loading last used Game List
00:51:36.2 11/26/2006: Setting Music Volume
00:51:36.2 11/26/2006: Creating DirectSound Device
00:51:36.2 11/26/2006: Trying: Primary Sound Driver
00:51:36.2 11/26/2006: Loading Sound Files
00:51:36.2 11/26/2006: DirectSound Device Created Successfully
00:51:36.2 11/26/2006: Creating ICONS
00:51:36.2 11/26/2006: Restoring Cached ICONS from File
00:51:36.5 11/26/2006: Initialising DirectInput for Gamepad support
00:51:36.5 11/26/2006: Unable to create a joystick device
00:51:36.5 11/26/2006: Initialising DirectInput for Keyboard support
00:51:36.6 11/26/2006: Playing Startup Video
00:51:36.7 11/26/2006: Playing intro sound file
00:51:36.7 11/26/2006: Initializing MCE Remote
00:51:36.7 11/26/2006: Initialization OK! Starting GameEx!
00:51:36.7 11/26/2006: Testing Main Loop Once: Processing Frame
00:51:37.0 11/26/2006: Testing Main Loop Once: Main Loop ran successfully
00:52:10.3 11/26/2006: PlugIn: "Speak Game Name" caused an exception and is being disabled.
00:52:10.3 11/26/2006: Exception has been thrown by the target of an invocation.
00:52:10.3 11/26/2006: at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess)
00:52:10.3 11/26/2006: at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess)
00:52:10.3 11/26/2006: at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
00:52:10.3 11/26/2006: at System.RuntimeType.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParameters)
00:52:10.3 11/26/2006: at GameEx.PlugIns.InvokeMethod(Object obj, String sProperty, Object oValue)
00:52:10.3 11/26/2006: at GameEx.PlugIns.InvokeMethod(Object obj, String sProperty, Game_Info oValue)
00:52:10.3 11/26/2006: at GameEx.PlugIns.Event_GameShowInfo(Game_Info gi)
00:52:16.6 11/26/2006: Exiting GameEx!
00:52:16.6 11/26/2006: Saving Settings
00:52:21.3 11/26/2006: Disposing Plugins
00:52:21.3 11/26/2006: Checking for applications to Launch On Exit
Tom I see the mistake here..
You should be calling it using an IntPtr..
Game_Info Info;
Info.GameData.Category = "Category";
Info.GameData.Year = "Year";
Info.GameData.Developer = "Developer";
Info.GameData.Description = "Description";
Info.MameInfo.Players = "Players";
Info.MameInfo.Control = "Control";
Info.MameInfo.ParentRom = "ParentRom";
Info.EmulatorName = "EmulatorName";
Info.GameName = "GameName";
Info.ROMPath = "ROMPath";
Info.ROMName = "ROMName";
IntPtr InfoPtr = Marshal.AllocCoTaskMem(Marshal.SizeOf(typeof(Game_Info)));
Marshal.StructureToPtr(Info, InfoPtr, false);
InvokeMethod(oApp, "Event_GameShowInfo", InfoPtr);
Marshal.FreeCoTaskMem(InfoPtr);
Thanks Ben but that's not it.
That proc is in GameEx not the plugin, that gets called from elsewhere within GameEx itself so it does not use an intpr.
It seems the error is actually generated within the plugin by the look of the stack trace and message.
Are you sure? Check out the log..
  Quote
See above your calling InvokeMethod with GameEx.PlugIns.Event_GameShowInfo(Game_Info gi). That is where the exception is occuring and the reason is because the Game_info struct is not what that method is expecting as a parameter, it's expecting an IntPtr.
The code I posted before is what should be in GameEx, not the plugin. You have to send the struct to the plugin's method using an IntPtr.
No
It does this, see the void, thats the start of the stack trace in the log above.
void Event_GameShowInfo(Game_Info gi)
gi.GameData.Category = "Category";
gi.GameData.Year = "Year";
gi.GameData.Developer = "Developer";
gi.GameData.Description = "Description";
gi.MameInfo.Players = "Players";
gi.MameInfo.Control = "Control";
gi.MameInfo.ParentRom = "ParentRom";
gi.EmulatorName = "EmulatorName";
Marshal.StructureToPtr(gi, InfoPtr, false);
Yeah sorry for confusing you, thats an overloaded function that takes Game_Info but it then takes it converts it to an intptr and calls InvokeMethod again, see 3rd line.
