Hi,
i have got gameex running mame and love it. I am now trying to set up some emulators. I have a few NES emulators, and a lot of roms. The gameex setup wants me to point to an .ini file to set up the emulator, but i dont have an ini file or know how to get it. any help is appreciated greatly. thanks!
It's not looking for an ini... the command line is looking for your emulator program, followed by something like "[RomPath]\[RomFile]". Then you tell it where your roms are. Are you using the setup wizard? If you are, just use the download emulators utility. It automatically downloads and helps you setup the emulators. You just have to move your roms where they would go. Also, make sure you read the faq here.
Hi,
Nestopia IMO works great with gameex.
