Used Gamex about 10 years ago.  building a Mame bartop for a friend and remembered how easy GE was to setup.  the new wizard has me a bit puzzled.  i don't have all my Mame folders setup yet; however, I have a bunch of working roms and my Mame FE works fine.  here's my log.  any help would be greatly appreciated.  probably something easy, I just seem to find the resolution.
20:23:06.40  7/7/2021:  Opening Configuration File
20:23:06.45  7/7/2021:  GameEx Arcade Edition x64: Version 16.97: Starting Log
20:23:06.79  7/7/2021:  Windows 10 Pro 64-bit
20:23:06.80  7/7/2021:  Aero running
20:23:06.80  7/7/2021:  Initializing Vista/Windows 7 volume control
20:23:06.83  7/7/2021:  Getting CPU and RAM info
20:23:06.84  7/7/2021:  AMD Athlon(tm) 5150 APU with Radeon(tm) R3, 3520MB
20:23:06.84  7/7/2021:  1.6Ghz - 4 Cores or CPU's
20:23:06.84  7/7/2021:  Running Randomize()
20:23:06.91  7/7/2021:  Loading PlugIns
20:23:06.93  7/7/2021:  Checking for applications to Launch On Startup
20:23:06.93  7/7/2021:  Setting default net connection limit to 25
20:23:06.94  7/7/2021:  Running Misc startup tasks
20:23:06.94  7/7/2021:  Setting Menu types
20:23:06.95  7/7/2021:  Getting Configuration Values
20:23:06.97  7/7/2021:  Using Theme: Default - Default
20:23:06.97  7/7/2021:  Checking for alternate Image Directory for Theme: Default - Default
20:23:06.98  7/7/2021:  Launching HideOS.exe
20:23:06.98  7/7/2021:  Initialising Video/MNG DLL's
20:23:06.98  7/7/2021:  GameEx will check for media insertion (may affect performance)
20:23:06.98  7/7/2021:  Hiding Taskbar
20:23:07.00  7/7/2021:  Is Media Center running?
20:23:07.01  7/7/2021:  Checking/Creating LCD Registry values
20:23:07.01  7/7/2021:  Check Media Center Exit/Start Mode
20:23:07.01  7/7/2021:  Media Center Mode 2
20:23:07.03  7/7/2021:  Video previews on. Warning: Only recommended on modern systems
20:23:07.03  7/7/2021:  Snap Delay set to: 7
20:23:07.03  7/7/2021:  Get other settings
20:23:07.03  7/7/2021:  Set: Find emulator artwork on best match basis
20:23:07.03  7/7/2021:  Start work for Form
20:23:07.03  7/7/2021:  Getting Original Screen Size
20:23:07.07  7/7/2021:  Opening Database Connection
20:23:07.07  7/7/2021:  Data Source=C:\GameEx Arcade Edition\DATA\data.db3;Pooling=true;FailIfMissing=true
20:23:07.57  7/7/2021:  Initializing Component
20:23:07.68  7/7/2021:  Alternate artwork download path set: C:\Program Files\Mame\artwork
20:23:07.68  7/7/2021:  MAME Path is: C:\Program Files\Mame
20:23:07.68  7/7/2021:  MAME EXE file is: mame64.exe
20:23:07.69  7/7/2021:  ROM Path is: C:\Program Files\Mame\roms
20:23:07.69  7/7/2021:  Catver.ini is located at: C:\GameEx Arcade Edition\DATA\catver.ini
20:23:07.69  7/7/2021:  controls.ini is located at: C:\GameEx Arcade Edition\DATA\controls.ini
20:23:07.84  7/7/2021:  History.dat is located at: C:\GameEx Arcade Edition\DATA\history.dat
20:23:07.85  7/7/2021:  nplayers.ini is located at: C:\GameEx Arcade Edition\DATA\nplayers.ini
20:23:07.85  7/7/2021:  command.dat is located at: C:\GameEx Arcade Edition\DATA\command.dat
20:23:07.85  7/7/2021:  MAMEinfo.dat is located at: C:\GameEx Arcade Edition\DATA\mameinfo.dat
20:23:07.85  7/7/2021:  Loading Controls.ini map file
20:23:07.86  7/7/2021:  Snap Path: Not Found
20:23:07.86  7/7/2021:  Database Snap Path: Not Found
20:23:07.86  7/7/2021:  Background Snap Path: Not Found
20:23:07.86  7/7/2021:  AVI Snap Path: Not Found
20:23:07.86  7/7/2021:  Video theme Path: Not Found
20:23:07.86  7/7/2021:  Video background Path: Not Found
20:23:07.86  7/7/2021:  Flyer Path: Not Found
20:23:07.86  7/7/2021:  Cabinet Path: Not Found
20:23:07.86  7/7/2021:  Cabinet 3D Path: Not Found
20:23:07.86  7/7/2021:  Title Path: Not Found
20:23:07.87  7/7/2021:  Title Path: Not Found
20:23:07.87  7/7/2021:  PCB Path: Not Found
20:23:07.87  7/7/2021:  Artwork Preview Path: Not Found
20:23:07.87  7/7/2021:  Panel Path: Not Found
20:23:07.87  7/7/2021:  Manual Path: Not Found
20:23:07.87  7/7/2021:  Icon Path: Not Found
20:23:07.87  7/7/2021:  Marquee Path: Not Found
20:23:07.87  7/7/2021:  --**--
20:23:07.87  7/7/2021:  Error: Access to the path 'C:\Program Files\Mame\artwork\MAME' is denied.
20:23:07.88  7/7/2021:     at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
20:23:07.89  7/7/2021:     at System.IO.Directory.InternalCreateDirectory(String fullPath, String path, Object dirSecurityObj, Boolean checkHost)
20:23:07.89  7/7/2021:     at System.IO.Directory.InternalCreateDirectoryHelper(String path, Boolean checkHost)
20:23:07.89  7/7/2021:     at GameEx.MainForm.a(Boolean A_0, String A_1, Boolean A_2)
20:23:07.89  7/7/2021:     at GameEx.MainForm..ctor()
20:23:07.90  7/7/2021:  Closing database connection
20:23:07.92  7/7/2021:  Disposing Plugins
20:23:07.92  7/7/2021:  GameEx is exiting with errors
20:23:10.25  7/7/2021:  ERRORS DETECTED: EXITING
20:23:10.32  7/7/2021:  Bye
The log is ptetty self explanatory here. Access is denied to that path. I would suggest moving stuff out of c:\program files.
It looks specifically like you set the alternate automatic download path to this. Windows by default doses not allow directories to be created here and that is why you are getting the error.
  • Draco1962 changed the title to [RESOLVED] Help
