Okay, I've just added another LEDWiz feature I need testing.
It's called "Speak Control Actions" and it's a tickbox at the bottom of the LCDTest window.
When you have it checked and select a game from the list it should hilight each button one by one and speak the action associated to it.
If that can be tested along with the other standard hilighting of a controls.
Ricci: I'm not 100% sure since there are a few different types of BetaBrites. I believe the USB ones are the ones we can't yet communicate to, and the others should have standard serial connections of some sort. I would contact BetaBrite and find out if we can do standard COM port serial communications with your model.
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Headkaze
The buttons and controls all seem to light up the right way now.
The Speak Control Actions feature works good except it stops on the last button/control, It would be nice if it would light the buttons and controls for the game back up.
The audio mode flashes some of the buttons then lights them all up. it also turns the inside of the ledtest window red. (see post #40)
Bob
Thanks ourgrace, I will fix up the speak actions thing, just needed to see if it worked.'
The audio mode won't do anything until the audio is setup to record the Stereo Mix out and the level is set right. The red around the boarder is the colour it's trying to set the colour LED's when music is playing. If you play a song on your PC and that colour dosn't change according to the music, it won't be working for your LED's either.
A little more testing and I'm putting LedWiz on the cab! Can't wait for the plugin's official release! :)
Headkaze
Ok, all is good with the audio mode. I didn't realize how sensetive the adjustment for the sterio mix out is, but it is working good now.
I am thinking of changing all my led's to three color, is there some way to set the color of the buttons and controls to a certin color when lighting them up for the game being played, (I.E. only red). then using all the colors for the other modes?
I'll post another clip of the audio mode today.
Bob
