Hi, i want uninstall instant sheller, because i have a problem, and i need to configure my gameex, i can´t do nothing in window so i can´t configure gameex. plz tell how i can do to return to my windows 2000 and configure y gameex.
i have a error in gameex, the log file tell error 5 in the end. plz help
PD: sorry for my bad english. ;)
Press CTRL-ALT-DEL.. then Task Manager.. File->New Task (Run...) then type "explorer.exe".
That should get you back to your shell, then you can run Instant Sheller again to undo the changes.
