Hey Tom.. I know your busy with other stuff, but I wanted to ask if you add up another couple half dozen or 2 lines of code for more systems to be added. I've been working on downloading a whole bunch of complete rom sets from (hah, like I would tell you). I've got almost 40 now, and a lot of them run in MESS. I'm already using up 23 of the systems for the high-end systems. But there's just so many out there, GameEx can't list them all! Perhaps you should reconsider the programming for added emulators and figure out a way to have it be infinite instead of a set number. I remember when it was 20, then 25 and now what is it...33? Heh I want more systems and more games! :)
Actually GameEx can currently support up to about 300. There just not available in the configuration application. You can add them manually though in the ini file.
Ah, so just type in the information.. I get it. Thanks! :)
