Good afternoon, I am configuring my kl25z to be able to use the keys in pinballx and obviously in vpinball, if I configure the keys when launching pinballx it hangs and the window closes without further ado, if I configure klz25 as a joystick it works fine. if I launch vpinballx directly they work fine klz25 with the keys, I pass someone something similar Thank you
It only affects at the time of starting pinballx, if I connect it once started it works perfectly, something I must do at the time of start the program
I keep investigating
It is the led pluguin, if I deactivate it it starts well, if I leave it activated it fails
I use ledwiz and klz, I like this plugin for the attraction mode, has this conflict solved?
Thank you
tanks
Good afternoon, only that you have a ledwiz and klz configured on the same computer causes the failure, if I disconnect the klz when starting pinballx or doing a test from the same plugin it fails
Thanks for everything
