O.K. i´ve tried to get the epsxe and gba Emu get working ; but it doesn´t work.
For example here is the batchfile from PSX
start/wait D:\PSXCD3\PS1Emu\ePSXe.exe -nogui -loadbin
Exit
When i ran this outside Gameex it tolds me theres an error and it must beclosed.I didn´t know the error?
When i´m watching thelogfile that appears in gameex theres a comment about Pause and to push a button to continue. When i do this _> black Screen and it returns to gameex.
It´s the same situation as it is with the gba.
Sorry about my poor english.
I need help.
I think i´m getting crazy
Stormbringer
Check the "user submitted config" thread above. It's a really good place to learn how to launch the emulators. Chances are if you're having a problem someone else has had it and fixed it or someone else is doing it a better way.
Scott
Is there noone that has epsxe and vba and other nintendo emulators running in gameex and could help me?
I can´t believe this :angry:
I hope that someome could help me to get them running
cheers
Stormbringer
cheers
Stormbringer
It sounds like you are using another seperate batch file to launch epsxe. Why??
Tom I´velooked at the usersuggested configs and thats my batch file
Exit
Maybe I´m silly but you asked me why I used this batch file?
Didn´t I need to use it?
Is there a way to get the epsxe running (maybe another?)
Stormbringer
o.k. i`m coming a little bit closer now.
Under command line I choose the ePSXe.exe and added in the line -nogui -loadbin "[ROMPATH]\[RomFile]"
Debug is set to No
and I got a black Screen.
So I send Debug to Yes and the window told me to press any key to continue. I press "A" and it worked fine.
So I write under "send keys" [ENTER] A and set debug to No
I will got a black screen , too. I press any Key and nothing happened.
How could we go on further ?
Thanks for helping
Stormbringer
Debug is set to No
Thanks for helping
Stormbringer
First Turn off debug. Then do either of the following:
Set ShowDesktop to true for this emulator in GameEx (this should deffinitly work).
Or
Make epsxe run full screen with DirectX
For GBA i'm using 1.7 -sdl version and my config is
[Emulator_1]
StartPageName=GameBoy Advance
TitleText=GBA
StartPageLogo=gameboyadvance
RomFilter=*.zip
RomsInFolders=False
ROMPath=C:\Emuladores\Consolas\Nintendo\GBAdvance\roms
SnapPath=C:\Emuladores\Consolas\Nintendo\GBAdvance\snap
WorkingPath=C:\Emuladores\Consolas\Nintendo\GBAdvance
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=False
Capitals=False
RemoveBrackets=False
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=
OLDatZip=
Command=visualboyadvance-sdl.exe "[ROMPath]\[RomFile]"
TitlePath=C:\Emuladores\Consolas\Nintendo\GBAdvance\titles
BoxPath=C:\Emuladores\Consolas\Nintendo\GBAdvance\boxscans
LaunchBefore=
LaunchAfter=
CartPath=
This works ok
[Emulator_1]
        TitleText=GBA
        RomFilter=*.zip
        RomsInFolders=False
        MapKeys=True
        WaitBeforeKeys=
        SendKeys=
        ReplaceDash=False
        ReplaceUnder=False
        Capitals=False
        AlsoLaunch=
        ShowDesktop=False
        Debug=False
        MapFile=
OLDatZip=
LaunchBefore=
LaunchAfter=
CartPath=
This works ok
o.k thanks very much , i will have a look and will tell you the results.
Stormbringer
Did you use them succesfully??
O.K. to ePSXe :I set debug off and turned Show Desktop to TRUE. And it will work. It looks not pretty good to have the Desktop before your eyes. When i exit with esc. it took a while and the emu seems to close and go back to game ex. When i start another game I see that the previus Game is still running!?
When i set Debug to ON ; and Show Desktop to false ; í will have to push another key to start and it works fine.Closing with esc works fine to. So Tom wrote to start ePSXe in fullscreen with direcct X -----How????
@sydarora. The gba doesnt´t work.I will have alook at it later.I think i made a mistake somewhere.I will reply later (maybe tomorrow)
What Version of GameEx did you use? I´m using 3.6...
Maybe you could post other Emulator settings? Like Nes , Snes , N64....
You have to setup emulator trough visualboyadvance.cfg config archive because it hasn't any gui,here's my config file:
# All numeric values are in hexadecimal
# Use TAB or EQUAL sign to separate name from value
# Key configuration (all numbers are in hexadecimal!)
# Keys values are in the format YXXX where Y is the device number. 0 means
# keyborad and XXX is the SDL define for the desired key (read SDL_keysym.h).
# If Y is greater than 0, it means joystick number Y-1 and it uses the
# following format for XXX:
# - if XXX < 20, XXX is the axis number multiplied by 2. An even number means
# movement to the negative side (on the X axis, it means left). An odd
# number means movement to the positive side (on the X axis, it mean
# right). For the Y axis, negative means up and positive means down.
# X axis is usally axis number 0 and Y is axis number 1.
# - if 20 >= XXX > 30, then XXX is the HAT number multiplied by 4 plus the
# direction: 0 for up, 1 for down, 2 for right and 3 for left. Example:
# 0021 is HAT 0 down, 0026 is HAT 1 right.
# - if 80 >= XXX > 100, XXX is the joystick button number (XXX-080).
# Default key configuration is (value in parenthesis):
# Left Left Arrow (0114)
# Right Right Arrow (0113)
# Up Up Arrow (0111)
# Down Down Arrow (0112)
# A Z (007a)
# B X (0078)
# L A (0061)
# R S (0073)
# Start ENTER (000d)
# Select BACKSPACE (0008)
# Speed up SPACE (0020)
# Capture F12 (0125)
Joy0_Left=1000
Joy0_Right=1001
Joy0_Up=1002
Joy0_Down=1003
Joy0_A=1080
Joy0_B=1081
Joy0_L=1084
Joy0_R=1085
Joy0_Start=1086
Joy0_Select=1087
Joy0_Speed=0021
Joy0_Capture=0125
# Motion support keys. Same format as above
# Default keys are (value in parenthesis):
# Left Numeric Pad 4 (0104)
# Right Numeric Pad 6 (0106)
# Up Numeric Pad 8 (0108)
# Down Numeric Pad 2 (0102)
Motion_Left=0104
Motion_Right=0106
Motion_Up=0108
Motion_Down=0102
# Frame skip setting. Allowed values are from 0 to 5 only.
frameSkip=2
# Gameboy Frame skip setting. Allowed values are from 0 to 5 only.
gbFrameSkip=0
# Video setting. 0=1x, 1=2x, 2=3x, 3=4x.
video=3
# Use fullscreen mode. 0=false, any other value means true
fullScreen=1
# Disables MMX support
disableMMX=0
# Use bios file. 0=false, any other value means true
useBios=0
# Bios file full path and name (ZIP not supported)
biosFile=none
# Filter to use. 0=no filter, 1=TV Mode, 2=2xSaI, 3=Super 2xSaI, 4=Super Eagle
# 5=Pixelate, 6=Motion Blur, 7=AdvanceMAME Scale2x, 8=Simple 2x,
# 9=Bilinear, A=Bilinear Plus, B=hq2x, C=lq2x
filter=0
# Disable status messages. 0=false, any other value means true
disableStatus=1
# Enable Gameboy border. 0=false, any other value means true
borderOn=0
# Gameboy emulator type. 0=automatic, 1=CGB/GBC, 2=SGB, 3=GB, 4=GBA, 5=SGB2
emulatorType=1
# Enable washed colors. 0=false, any other value means true
colorOption=1
# Directories. Not setting one them makes the file go the rom directory.
# Save state directory
#saveDir=
# Screen shot Capture directory
#captureDir=
# Battery directory
#batteryDir=
# Screen capture format
# 0=PNG, anything else for BMP
captureFormat=0
# Sound quality
# 1=44 Khz, 2=22Khz, 4=11Khz
soundQuality=2
# Sound Echo
# 0=false, anything else for true
soundEcho=0
# Sound Low pass filter
soundLowPass=0
# Sound reverse stereo
soundReverse=0
# Remove GBA intros (not supported anymore)
# removeIntros=0
# Save Type
# 0=automatic, 1=EEPROM, 2=SRAM, 3=Flash, 4=EEPROM+Sensor, 5=NONE
saveType=0
# Flash size
# 0=64K Flash, 1=128K Flash
flashSize=0
# Sound volume
# 0=1x, 1=2x, 2=3x, 3=4x
soundVolume=0
# Interframe blending
# 0=none, 1=motion blur, 2=smart
ifbType=0
# Show emulation speed
# 0=none, 1=percentage, 2=detailed
showSpeed=0
# Show speed in transparent mode
# 0=normal, anything else for transparent
showSpeedTransparent=1
# Enable/Disable auto frameskip
# 0=disable, anything else to enable
autoFrameSkip=0
# Sets the desired throttle
# 0=disable, 5...1000 valid throttle speeds
throttle=0
# Pauses the emulator when the window is inactive
pauseWhenInactive=0
# Enables AGBPrint support
agbPrint=0
# Enables GBA RTC support
rtcEnabled=0
# Sound OFF flag
# 0=sound on, anything else turns off sound
soundOff=0
# Sound Enable
# Controls which channels are enabled: (add values)
# 1 - Channel 1
# 2 - Channel 2
# 4 - Channel 3
# 8 - Channel 4
# 100 - DirectSound A
# 200 - DirectSound B
# 30f=all enabled, 0=mute all
soundEnable=30f
# Controls automatic SGB border
# 0=disable, anything else enables automatic SGB border display
borderAutomatic=0
# Skip bios code
# 0=disable, anything else skips BIOS code
skipBios=0
# The interval between the rewind saves
# Minimum of 0 seconds to disable rewind support,
# Maximum of 60 minutes. Value in seconds (hexadecimal numbers)
rewindTimer=0
# Enable enhanced save type detection
# 0=disable, anything else to enable (no longer used)
#enhancedDetection=1
look that I'm using a joypad to play games on emulator
I use various frontends to run emulators because I like to config them.
The most I use is Mamewah and I make my owm page of layouts and configs.
Now I´m using GameEx and try to help people for use it.
Config in GameEx is very similar to Mamewah but it not has the professional appearance that GameEx looks, also configurations files are very similar.
I'll make the same configs I have in Mamewah into GameEx.
Greetings from Jaén (Spain)
Snes configuration file------
StartPageName=Nintendo SNES
TitleText=Super Nes
StartPageLogo=snes
RomFilter=*.zip
RomsInFolders=False
ROMPath=C:\Emuladores\Consolas\Nintendo\SNes\roms
SnapPath=C:\Emuladores\Consolas\Nintendo\SNes\snap
WorkingPath=C:\Emuladores\Consolas\Nintendo\SNes\
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=
OLDatZip=
Command=Zsnesw.exe "[ROMPath]\[RomFile]"
TitlePath=C:\Emuladores\Consolas\Nintendo\SNes\titles
BoxPath=C:\Emuladores\Consolas\Nintendo\SNes\Boxscans
LaunchBefore=
LaunchAfter=
CartPath=C:\Emuladores\Consolas\Nintendo\SNes\CartScans
I'm using 4.03 GameEx version
The Zsnesw emulator is from
http://www.screenshotarchive.com
Please visit my web
http://www.marcianitos.org/tutoriales/mame...g/mwdisenos.htm
Thanks a lot
look at your emu config.
my Zsnesw config is:
; ZSNES Configuration file
; Frame Skip = 0 .. 9
FrameSkip = 0
; Auto Frame Skip = 0 or 1 (1 = ON)
AutoFrameSkip = 1
; Player 1/2 Input Device. Use the GUI to set these values
; NOTE : Using this to select joysticks manually will NOT work!
Player1Device = 1
Player2Device = 1
; Keyboard Scancodes/Joystick Mappings for Keyboard 1 & 2
; In order of Right, Left, Down, Up, Start, Select, B, Y, A, X, L, R
; Use the GUI to set these values
ScanKey1 = 256, 257, 258, 259, 278, 279, 273, 275, 272, 274, 276, 277
ScanKey2 = 34, 32, 33, 19, 3, 7, 31, 30, 23, 17, 37, 16
; Share Player 3 and 4 control inputs with Player 1 and 2 to allow
; 2 devices to be shared on a single player. This feature automatically
; disables MultiTap (Multiplayer 5) support. Set this to 1 to enable.
Pl34to12Share = 0
; Percent to Execute [50 .. 150]
Execute = 100
; Video Mode, 0 - 32
; 0 = 256x224 R WIN 1 = 256x224 R FULL
; 2 = 512x448 R WIN 3 = 512x448 DR WIN
; 4 = 640x480 S WIN 5 = 640x480 DS WIN
; 6 = 640x480 DR FULL 7 = 640x480 DS FULL
; 8 = 640x480 S FULL 9 = 768x672 R WIN
; 10 = 768x672 DR WIN 11 = 800x600 S WIN
; 12 = 800x600 DS WIN 13 = 800x600 S FULL
; 14 = 800x600 DR FULL 15 = 800x600 DS FULL
; 16 = 1024x768 S WIN 17 = 1024x768 DS WIN
; 18 = 1024x768 S FULL 19 = 1024x768 DR FULL
; 20 = 1024x768 DS FULL 21 = 1024x896 R WIN
; 22 = 1024x896 DR WIN 23 = 1280x960 S WIN
; 24 = 1280x960 DS WIN 25 = 1280x960 S FULL
; 26 = 1280x960 DR FULL 27 = 1280x960 DS FULL
; 28 = 1280x1024 S WIN 29 = 1280x1024 DS WIN
; 30 = 1280x1024 S FULL 31 = 1280x1024 DR FULL
; 32 = 1280x1024 DS FULL
VideoModeWin = 7
; Sound Emulation = 0 or 1 (1 = ON)
Sound = 1
; Sound Sampling Rate
; 0 = 8,000 Hz, 1 = 11,025 Hz, 2 = 22,050 Hz
; 3 = 44,100 Hz, 4 = 16,000 Hz, 5 = 32,000 Hz
; 6 = 48,000 Hz
SoundRate = 5
; Stereo (0 = off, 1 = on)
Stereo = 1
; Stereo Reversed. Swaps left channel with right. (0 = off, 1 = L <-> R)
ReverseStereo = 0
; GUI Disable (1 = Disable GUI, 0 = Enable GUI)
GUIDisable = 1
; New Graphics Engine (1 = Enable, 0 = Disable)
NewGfx = 1
; Scanlines (0 = Disable, 1 = Full, 2 = 25 3 = 50
Scanlines = 0
; Interpolation (1 = Enable, 0 = Disable)
Interpolation = 0
; VSync (1 = Enable, 0 = Disable) - Wait for Vertical Sync (Fast cpu reqd)
VSync = 0
; Disable Echo (1 = Yes, 0 = No)
EchoDisable = 0
; Sound Volume Level (0 .. 100)
; Note : Setting this too high can cause sound overflow which degrades quality
Volume = 100
; Set this to 1 if you do not want ZSNES to save the configuration files.
DontSave = 0
; Savefile directory. Leave it blank if you want the save files to be in the
; same directory as the games. It should be in a format like : C:\dir\dir
SaveDirectory =
; Game directory. This is the directory where the GUI starts at.
; ZSNES automatically writes the current directory here upon exit.
GameDirectory = C:\EMULADORES\CONSOLAS\NINTENDO\SNES\ROMS
o.K. here´s the log. I couldn´t see something. How about you?
11:39:47.6 30.05.2005: GameEx: Version 3.64: Starting Log
11:39:47.6 30.05.2005: Operating System Platform ID: Win32NT
11:39:47.6 30.05.2005: Operating System Version: 5.1
11:39:47.6 30.05.2005: Running Randomize()
11:39:47.6 30.05.2005: Running Misc startup tasks
11:39:47.6 30.05.2005: Hiding Cursor
11:39:47.6 30.05.2005: Setting Menu types
11:39:47.6 30.05.2005: Opening Configuration File
11:39:47.6 30.05.2005: Getting Configuration Values
11:39:47.6 30.05.2005: Using Theme: German - Default
11:39:47.6 30.05.2005: Checking for alternate Image Directory for Theme: German - Default
11:39:47.6 30.05.2005: Using Images from theme: Default - Default\MEDIA\
11:39:47.6 30.05.2005: Applying Language/Text
11:39:47.7 30.05.2005: Snap Delay set to: 1
11:39:47.8 30.05.2005: Launching HideOS.exe
11:39:49.2 30.05.2005: Hiding Taskbar
11:39:49.2 30.05.2005: Getting Original Screen Size
11:39:49.2 30.05.2005: Loading ICON
11:39:49.3 30.05.2005: Initializing Component
11:39:49.5 30.05.2005: Using General Font: Digiface
11:39:49.5 30.05.2005: Using Title Font: Digiface
11:39:49.5 30.05.2005: Initialising DirectDraw
11:39:49.9 30.05.2005: Applying GameEx is Loading Image
11:39:51.0 30.05.2005: Creating DirectDraw Device
11:39:53.1 30.05.2005: Setting Resolution to 800x600 32 bit color
11:39:58.9 30.05.2005: Creating DirectDraw Surfaces
11:39:58.9 30.05.2005: Creating Primary Surface - Full Screen Mode
11:39:59.5 30.05.2005: Creating Back Buffer
11:39:59.5 30.05.2005: Loading graphic surfaces
11:40:10.0 30.05.2005: Creating Fonts
11:40:10.0 30.05.2005: Creating Menu Font
11:40:10.6 30.05.2005: Creating Game Font
11:40:10.8 30.05.2005: Creating Menu Font Standard Size
11:40:11.2 30.05.2005: Creating Font Black
11:40:11.4 30.05.2005: Creating Font Black Small
11:40:11.5 30.05.2005: Creating Game Font Faded
11:40:11.6 30.05.2005: Creating Title Font
11:40:11.9 30.05.2005: MAME Path is: C:\Dokumente und Einstellungen\Familie xxxxxx\Desktop\Mame\Mame32 V91\Mame32
11:40:12.0 30.05.2005: MAME EXE file is: Mame32.exe
11:40:12.1 30.05.2005: ROM Path is: C:\Dokumente und Einstellungen\Familie xxxxxx\Desktop\Mame\Mame32 V91\Mame32\roms
11:40:12.1 30.05.2005: Catver.ini is located at: C:\Programme\GameEx\DATA\catver.ini
11:40:12.1 30.05.2005: controls.ini is located at: C:\Programme\GameEx\data\controls.ini
11:40:12.1 30.05.2005: History.dat is located at: C:\Programme\GameEx\DATA\history.dat
11:40:12.1 30.05.2005: nplayers.ini is located at: C:\Programme\GameEx\DATA\nplayers.ini
11:40:12.1 30.05.2005: MAMEinfo.dat is located at: C:\Programme\GameEx\DATA\mameinfo.dat
11:40:12.1 30.05.2005: Loading Controls.ini map file
11:40:12.2 30.05.2005: Loading Custom Emulators
11:40:12.2 30.05.2005: Loading Emulator 7: Gameboy Advance Spiele
11:40:12.2 30.05.2005: Loading Emulator 8: Playstation
11:40:12.4 30.05.2005: Snap Path is: C:\Dokumente und Einstellungen\Familie xxxxxx\Desktop\Mame\Mame32 V91\Mame32\snap
11:40:12.4 30.05.2005: AVI Snap Path: Not Found
11:40:12.5 30.05.2005: Flyer Path: Not Found
11:40:12.5 30.05.2005: Cabinet Path: Not Found
11:40:12.5 30.05.2005: Title Path: Not Found
11:40:12.5 30.05.2005: Panel Path: Not Found
11:40:12.5 30.05.2005: Icon Path is: C:\Dokumente und Einstellungen\Familie xxxxxx\Desktop\Mame\Mame32 V91\Mame32\icons
11:40:12.5 30.05.2005: Marquee Path: Not Found
11:40:12.5 30.05.2005: Attempting to load game list
11:40:12.7 30.05.2005: Loading last used Game List
11:40:12.9 30.05.2005: Initialising Bass Audio Library
11:40:13.3 30.05.2005: Cannot Load Play List. Check Path and filename
11:40:13.4 30.05.2005: Creating DirectSound Device
11:40:13.4 30.05.2005: Trying: Primärer Soundtreiber
11:40:13.4 30.05.2005: Loading Sound Files
11:40:13.6 30.05.2005: DirectSound Device Created Successfully
11:40:13.6 30.05.2005: Creating ICONS
11:40:14.1 30.05.2005: Initialising DirectInput for Gamepad support
11:40:14.2 30.05.2005: Playing Startup Video
11:40:32.2 30.05.2005: Playing intro sound file
11:40:32.2 30.05.2005: Initialization OK! Starting GameEx!
11:40:32.2 30.05.2005: Testing Main Loop Once: Processing Frame
11:40:32.3 30.05.2005: Testing Main Loop Once: Getting Tick count
11:40:32.3 30.05.2005: Testing Main Loop Once: Checking for song change
11:40:32.4 30.05.2005: Testing Main Loop Once: Front buffer exists?
11:40:32.4 30.05.2005: Testing Main Loop Once: Surfaces need restore?
11:40:32.4 30.05.2005: Testing Main Loop Once: Checking Joystick for input
11:40:32.4 30.05.2005: Testing Main Loop Once: Drawing Background
11:40:32.7 30.05.2005: Testing Main Loop Once: Flipping Surfaces
11:40:32.8 30.05.2005: Testing Main Loop Once: Main Loop ran successfully
11:40:47.8 30.05.2005: Running: cmd.exe /c C: c:\dokumente und einstellungen\familie xxxxxx\desktop\gba\visualboyadvance-1.7.2-sdl-win32\visualboyadvance-sdl.exe "C:\Dokumente und Einstellungen\Familie xxxxxx\Desktop\GBA\Kingdom Hearts - Chain of Memories (E).zip"
Hi.
There's two things I see straight away.
Your running an old version of GameEx. Its very difficult to support older versions, because things get fixed with newer versions, that can solve peoples issues. Thats software for you!
The main problem I see though that could cause you problems with a lot of command line emultors, is that you seem to have everything dumped on your desktop.
This results is very long paths that some emus genuinly cant cope with. I suggest moving these files to something like C:\EMUS rather than that really long path you have now.
Installed new Version , Put the Emu and Rom Folder on C
And IT WORKS. F++king great.
I think this would be my Problem with PSXe , too?
I will test it and will tell you
Now are you not glad you didnt switch to another Front End B)
