I have GAMMEX Arcade Edition and before GAMEEX standard. In the standard there is a ArcadeVGA menu but not in arcade edition.
I must to configure Mame with no marque and stretch mode full screen but I  don't find the menu item.
Thank's.
It was removed as it no longer works with MAME.
Are you confusing ArcadeVGA mode with something else? It is for the old ArcadeVGA GPU graphics cards that are no longer sold and have been replaced with GroovyMAME and regular analog AMD cards?
Sorry I have a bad English.
In the Gamex standard I have the menu specifig for Ultimarc Arcade VGA (I have one of this): ARCADEVGA SETTING where the manu  have  the following
Stretch Res to X
Stretch Res to Y
Always stretch x*y
This option there isn't in the gameex arcade version and I don't find how setting Mame without Marque and with stretch mode full screen.
It still works by manually editing gameex.ini but it is no longer in the setup wizard as it uses directdraw which has not been in MAME for a long time now.
If you would like to invest in your rig I would suggest you look into GroovyMAME and buy a used AMD card of ebay. ArcadeVGA has gone the way of the dodo I am afraid.
21 hours ago, stefano.rabaglio said:
Thank's for reply. Now how I can set  "no marque" in gameex arcade configuration and set it full screen stretch?
Thank's.
Like I said, via manually setting the values in GameEx.ini (eg it still works for existing setups) otherwise the feature is no longer supported. Sorry.
If you want an easy workaround and if its still in regular GameEx like you say then install that, set it up, then install arcade edition over top. You will want the 32 bit version too.
