[RESOLVED] Mame displays cocktail screen in Gameex but not when running mame64 otherwise
Hi;
I messed up a single mame ROM file--where it now displays the screen for two-player, inverted as shown.  I've been back in the rom machine settings, where it is set as upright.  I have gone in to the mame nvram folder and deleted folders there, and there was nothing for this rom in the ini folder.  it seems this happened on a different rom when I had tried unselecting the cocktail mode on video settings for the rom itself.  I tried copying the rom over, and obviously this didn't fix the issue... Here is the screen that shows when I try playing the game selected from Gameex, but not when I'm simply running mame64.  Where do I look for settings to reset/delete?
Nevermind--found out that there was a config file in the original mame installation I had used (installed 0.221 in a separate folder) even though the Mame working directory in Gameex settings had been properly updated...Once I deleted that from the older mame installation, the problem was fixed...
