Not sure, I havn't had a chance to look into it yet, but if you can't do it from command line I will probably write a wrapper to do it when I get around to setting it up on my cab.
You can set the sendkeys option to use ALT + Enter when the emulator loads...
Try this...
Page 2 of your Handi configuration:
Wait Before Keys: 500
Keys To Send: %(~)
Works great. :)
If you have troubles, just increase the wait time.
Try this...
Keys To Send: %(~)
Works great. :)
Thankyou Adultery. Works fine. I never thought about going that route.
