Hello,
I'm reporting a bug of InstantSheller 10.1 under Windows 10 190318-1202 build 18362. When you select Gameex executable to run instead of Windows shell, Windows is unable to launch it if there are spaces in folder/file name. I had to rename "Gameex Arcade Edition" in "gameex" in order to run it. Please advise.
I've tried 10.1 and noticed this error for the first time. Before, I used Instantsheller for years without any hassle.
9 minutes ago, Tom Speirs said:
Are you using the new shell launcher option? Any difference with/without?
Unfortunately not, it's the first thing I tried when it didn't work.
Tried on another machine, it doesn't work anymore on recent windows 10 versions (1909). Used other tools too (regedit or Kodi Launcher), no way. I suggest it's a Windows 10 issue.
I've spotted the error. For some reason, Instantsheller doesn't accept addresses different from "C:\gameex\gameex.exe" for shell application and it works only if you select "Change shell for current user only".
I cant see tha
I cant see that in the source code but will have a look at this shortly to actually see if there is an issue.
